New project.
What im going to build only difrent color
What do i have to start
A donor kit for the engine and a few other parts
chassis kit from A&N models
Another cabin that i have in the stash for more than 2 years already painted for a part
Also some other aftermarket but that will be for later
first up will be the pe chassis and parts for the cabin
Mark
Mark
Nice choice for your new build and I'll be following all the way. :popcorn:
Lot's more to building big rigs then I ever thought - loads of resin and PE - Holy Smokes, going to be fun for sure
Ooh...   PE frame!  I'd be running for cover.  My father likes truck models.  Me...   not so much.  But I will be looking in.
1 hour ago, Peterpools said:
Mark
Nice stat on the PE chassis and our soldering skills looks mighty good. Did you use CCA to tak the parts in place or did you make a jig?
The frame is bended other parts just solderd in place
thecross beam whas the last to put in.
I have used toothpics in the holes to line it out side by side and workd well for me.
I stil have a lot to learn about soldering
now only one problem my soldering iron dondt work any more but replament underway
Mark
Me too!
Mark, you're doing a great job. Nice tip on using toothpicks to help line everything up.
Thanks Mrk - appreciate the information.
I've done a lot of soldering in my model railroad days and yours look next to perfect. I normally use a Weller - nothing fancy and one with a soldering station for the sponge and replaceable tips. No temp control.
Looking so good
37 minutes ago, Peterpools said:
Mark
So glad you're having all this fun and the results are looking mighty good.
Thanks Peter
and yes its a lot off fun at the moment.just a relax build for me
Mark
I have been following on FB. But just found it here. Just blows my mind Mark ! Following for sure!....harv
front axel
in place
And a part off the drive train(i hope this is the right name for it) in place
Next up rear axel
Mark
Great work Mark, love the soldered frame. Absolutely not my cup of tea, but interesting nontheless.
Yes its not that easy to get i allright al the PE
But you can always going the hard way and build it your self
Its just a try out
Mark
30 minutes ago, Peterpools said:
Mark
Awesome progress - looking mighty good. I hope you're going to finish Arocs as showroom new. Just love well maintained and good looking trucks.
Yes Peter almost brand New it will be
Mark
