Administrators JeroenPeters Posted April 10, 2024 Author Administrators Posted April 10, 2024 This is my favorite part. Adding life to the pit. Still a long way to go. 7 1
Administrators JeroenPeters Posted April 14, 2024 Author Administrators Posted April 14, 2024 Slowly getting there. Next up: HGW seatbelts 11
Bomber_County Posted April 14, 2024 Posted April 14, 2024 Stunning, one day when I’m older I might get close but I doubt it……… 2 1
Spitfire Posted April 15, 2024 Posted April 15, 2024 It's modelling Jim, but not as we know it. Absolutely amazing. Cheers Dennis 4 1 2
Administrators JeroenPeters Posted April 15, 2024 Author Administrators Posted April 15, 2024 Working on the Seat going by reference material. You can see how the early sutton harness is attached to the seat. I love using the AK weathering pencils to get a worn look. The leather will get some more lighter areas along the edges. 7
Administrators JeroenPeters Posted April 16, 2024 Author Administrators Posted April 16, 2024 Busy with the HGW harnesses. This usually takes me three evenings. Almost done. Just need to drape and glue the straps into position. And then seal it all in with matt varnish, followed by a wash. The drawing shows an early Sutton harness and how it was attached. No Whirlwind but probably quite similar. 10
Administrators JeroenPeters Posted April 17, 2024 Author Administrators Posted April 17, 2024 After some matt varnish. Perfect for some additional washes and scratches. Getting close to closing the fuselage. 9
BlrwestSiR Posted April 17, 2024 Posted April 17, 2024 Truly stunning work. Think I'll join Martin in basket weaving. 3 1
Administrators JeroenPeters Posted April 18, 2024 Author Administrators Posted April 18, 2024 Pit as good as done. One thing missing from the Quinta set is the oxy regulator on the right sidewall. I took that of the Kitsworld set. 11
Administrators JeroenPeters Posted April 22, 2024 Author Administrators Posted April 22, 2024 Building the whirlwind next to the tempest required more room. Cees Broere said: get a second desk. So i made a corner desk. If i had the room i’d get a third desk. 9 1
Spitfire Posted April 23, 2024 Posted April 23, 2024 The more room you have the more you fill it. Cheers Dennis 4 1
Administrators JeroenPeters Posted April 23, 2024 Author Administrators Posted April 23, 2024 Question for Gunnar. The teardrop inlet for the radio wore that goes to the TR9D radio on the model is wrong so i deleted it. First of all it should be offset to the port side so it would fit between two stringers. And the shape is off. Looking at pics it has a flat rear and seems to have a flange. A lower inset. If that makes sense. Do you have a proper drawing or photo? 6
GunnarO Posted April 24, 2024 Posted April 24, 2024 Unfortunately, we don’t have any good photos or drawings of the antenna wire inlet. But it looks different on later planes without the wire. 3
KevinM Posted April 24, 2024 Posted April 24, 2024 On 4/22/2024 at 3:02 PM, JeroenPeters said: Building the whirlwind next to the tempest required more room. Cees Broere said: get a second desk. So i made a corner desk. If i had the room i’d get a third desk. That's a Nice view Jeroen! 3
Administrators JeroenPeters Posted April 25, 2024 Author Administrators Posted April 25, 2024 First sketch of the antenna wire fairing 7
Administrators JeroenPeters Posted April 26, 2024 Author Administrators Posted April 26, 2024 This will do. 6
Administrators JeroenPeters Posted April 28, 2024 Author Administrators Posted April 28, 2024 Done. The spine seam is as smooth as a baby’s bottom. Time to reapply some rivets and deepen a few panellines. 10
Administrators JeroenPeters Posted May 3, 2024 Author Administrators Posted May 3, 2024 Needed a distraction so i started on guns. 9
Administrators JeroenPeters Posted May 4, 2024 Author Administrators Posted May 4, 2024 This nose section is intricate, delicate, tight fitting and precise. Just came from the cinema and sushi with one wine too many. Not a good idea to proceed. 8
Administrators JeroenPeters Posted May 5, 2024 Author Administrators Posted May 5, 2024 Getting there. The instrument panel is now in. The rear of the hispano guns appear to be too long at the back, making them stick against the instrument panel. Might have to shorten these, but they won’t be visible anyway. Also the firewall behind the guns appears to be a little too wide. We’ll see 6
