GazzaS Posted February 4, 2019 Posted February 4, 2019 Hello fellow travellers!  Russia month continues with a sprightly look at the T-34. Coming to a fortification near you!  Thanks for looking!  Gaz 6
BlrwestSiR Posted February 4, 2019 Posted February 4, 2019 This should be fun. Can't wait to see more. Carl 4
GazzaS Posted February 4, 2019 Author Posted February 4, 2019 3 hours ago, Martinnfb said: That's a great pic! I bet that guy saw the Lubyanka in his future. 3
GazzaS Posted February 10, 2019 Author Posted February 10, 2019 Back again, Everyone!   I spent a lot of time on the resin tracks. Saved 50 bucks over buying Friuls.... but I don't know if the aggravation was worth it... anyway...here's where I am now: After completing the tracks it was time to test-fit how I wanted everything to look. The tracks are tautened by the position of all of the rollers. No sag, yet everything here is only dry-fitted.   Here, the idler arms are all glued into place. The wheels only dry fitted. I also primed the track. Next up is painting all of the wheels and tracks then weathering em'... And I have to complete the base, too....  Thanks fer lookin!  Gaz   7
harv Posted February 10, 2019 Posted February 10, 2019 1 hour ago, Martinnfb said: Definitely worth the effort  ! Yep.....harv 3
Peterpools Posted February 11, 2019 Posted February 11, 2019 Gaz Agree with the guys - well worth it Keep 'em coming Peter 4
GazzaS Posted February 16, 2019 Author Posted February 16, 2019 As I'm working on a winter scene, I needed some snow. But not so much that it obliterated the details. What do you think? There'll be more blobs of snow on the inside of the tracks that I'll place strategically once the roadwheels and all are in place.  Gaz 6
Peterpools Posted February 16, 2019 Posted February 16, 2019 Gaz Nice work on tne tracks; looking mighty good Keep ‘em comin Peter 4
DocRob Posted February 16, 2019 Posted February 16, 2019 Looks good to me, you can add more later and more appropriate to the scenery if needed. I have the same process ahead with my mud, snow and ice covered T-90, so I'm in your footsteps. Cheers Rob 5
BlrwestSiR Posted February 16, 2019 Posted February 16, 2019 Looks good to me as well Gaz. You can always add a bit later once they're installed like Rob said.  Carl 4
Bomber_County Posted February 16, 2019 Posted February 16, 2019 Gaz, Â completely missed your build, Â I like the idea of the diorama. What did use as snow? 4
GazzaS Posted February 16, 2019 Author Posted February 16, 2019 8 hours ago, Peterpools said: Gaz Nice work on tne tracks; looking mighty good Keep ‘em comin Peter Thank you, Peter! 7 hours ago, DocRob said: Looks good to me, you can add more later and more appropriate to the scenery if needed. I have the same process ahead with my mud, snow and ice covered T-90, so I'm in your footsteps. Cheers Rob Thank you! Funnily enough, I didn't even think of adding more later... thanks for the tip! I have a little vegetation I have to work in, too. 7 hours ago, BlrwestSiR said: Looks good to me as well Gaz. You can always add a bit later once they're installed like Rob said.  Carl Thanks, Carl! 6 hours ago, Bomber_County said: Gaz,  completely missed your build,  I like the idea of the diorama. What did use as snow? Thank you! For the tracks, I dabbed on thinned white glue then covered it with bi-carb soda then brushed away the excess. I have some diorama snow for the base, but I didn't want to use it just yet.  Gaz 2
GazzaS Posted February 17, 2019 Author Posted February 17, 2019 I've got the base as good as it's gonna get. I'll have to add more snow around the tracks once the tank is fixed in place. But I've dryfitted everything to give me a complete idea of where I am right now. The pre-shading helps the the bas a little, but further attempts will be required. The wheels and hull are painted in my rendition of 4BO. I found the recipe and fudged a copy of it... sortta....  The ummm... infantryman's view....    I want to leave the tank green... surely they didn't all get whitewashed.  Gaz  5
GazzaS Posted February 19, 2019 Author Posted February 19, 2019 Sometimes you're looking for a certain aspect of a vehicle and you come upon a surprise: Â 3
Kais Posted February 19, 2019 Posted February 19, 2019 GazzaS, that chain should be 4BO,....surely!! 3
Peterpools Posted February 19, 2019 Posted February 19, 2019 Gaz Awesome progress and there are unexpected rewards for intense research Keep ‘em comin Peter 3
