CF-104D Triple Sick
This is looking great. And I thought I built SLOW!
Carl, the 104 is always a model I intended to buy, both single and two seaters, but I never did figure out which versions I needed to be able to properly do the two versions of the CF-104.  I really like the classic original version with highly polished fuselage and anti flash wings for its tactical nuclear strike role.
Not so much slow as I keep getting onto other projects. Plus kids and a puppy conspire to reduce my bench time.
The Italeri kits aren't bad. Some details are a bit soft but this is my second one. I did a single seater as an Italian Tiger Meet one.
If you start with the G/S kit, you should be able to turn that into an early RCAF plane. The cockpit and the burner can are probably the weakest parts of the kit detail wise. Lots of AM options out there for both but avoid the Aires 'pit. It's as wide as the exterior of the fuselage so no idea how you're supposed to make it fit inside.
Looking so good and you're so close to priming the full bird. Which primer did you use as in the photograph it appears to be a polished aluminum?
I'm pretty much with Ernie and always wanted to build the Starfighter, just never got around to doing one. Note to self, add the 104 to the build schedule down the road.
Last thing I did last night was spray the nose and a panel on the vertical tail in Voodoo Grey. I figure this will help minimize the amount of masking I have to do over top of the NMF.
I then masked off and sprayed the anti-glare panel.
This goes all the way up to the co-pilot's canopy.
Then I masked that off in preparation for the black base coat.
Here's the black base coat on. I did the intakes at the same time. This stuff is shiny!
Awesome work, Carl!
I bought out all the Voodoo Grey I could find when MM went down.  Are there other sources for it now, or just the old MM?
I’ve heard that some sell a grey called ADC Grey, which is supposedly close to the Voodoo Grey.
34 minutes ago, Clunkmeister said:
Awesome work, Carl!
Hataka makes a Voodoo Grey in both acrylic and lacquer. I have their acrylic version.
With the masking involved, I wanted to use a lacquer to reduce any chance of paint lifting. I noticed I had Mr Color 376 JASDF Radome Gray. In comparing the two, they looked close so that's what I went with. You can see the comparison below.
22 hours ago, Peterpools said:
it's hard to tell on my end. Just do a quick test and compare the two bottles before moving on. It's seems lately, it's always something.
Thankfully, the real plane was that shiny so I'm all good. Just wasn't expecting polished aluminium to be so bright.
Hit a small setback. The tape I was using on the tail has decided it really liked being there. It's basically shredded in trying to get it off. So needless to say, some of the paint has come with it.
Thankfully it's all just on the tail so I'm going to let the paint dry a bit longer, it back and start over.
  • Sad 2
