antonio argudo Posted July 19, 2020 Posted July 19, 2020 that's looking sweet, I really like the final color mix! 3 1
Administrators JeroenPeters Posted July 20, 2020 Author Administrators Posted July 20, 2020 Thnx! just sprayed the overpainted spanish markings: 8
joeg Posted July 20, 2020 Posted July 20, 2020 O am really looking forward to this built........got the kit in my stash too 4
Administrators JeroenPeters Posted July 22, 2020 Author Administrators Posted July 22, 2020 Disaster... again problems with my primer. This was the last time. Mig one shot. Well, i wont give it another shot!! Simply Touching this primer will cause it to give. I will never use it again. Besides: i should have known better since i had the same problems with the Buchon and this primer. 4 1
Administrators JeroenPeters Posted July 22, 2020 Author Administrators Posted July 22, 2020 Managed to fix it. Kind of.. The balkenkreuzen with Miracle paint masks went fine. 8
GazzaS Posted July 24, 2020 Posted July 24, 2020 I know you're building a model and it looks fantastic! But do you know if the vanes on the wings actually did anything? I had a short dance with acrylic primer. the worst paint lift in my life! 5
BlrwestSiR Posted July 24, 2020 Posted July 24, 2020 Really nice work Jeroen and a good recovery from the paint lifting too. I think the worst paint for lifting was Model Master acrylic. It constantly came off in chunks. Gave up on it pretty quick. 5
Administrators JeroenPeters Posted July 24, 2020 Author Administrators Posted July 24, 2020 9 hours ago, GazzaS said: I know you're building a model and it looks fantastic! But do you know if the vanes on the wings actually did anything? I had a short dance with acrylic primer. the worst paint lift in my life! I read that the vanes had to do with the underwing rockets. I’ll look it up again. i only read good reviews about the primer i used, but it’s shit. Probably quite literally too... i found a way to take the masks off safe. Keep them under warm water. 3 1
GazzaS Posted July 24, 2020 Posted July 24, 2020 5 hours ago, JeroenPeters said: I read that the vanes had to do with the underwing rockets. I’ll look it up again. i only read good reviews about the primer i used, but it’s shit. Probably quite literally too... i found a way to take the masks off safe. Keep them under warm water. Thanks, Jeroen! So... you dip the model into a tub of water and then pull the mask? 3
Administrators JeroenPeters Posted July 25, 2020 Author Administrators Posted July 25, 2020 11 hours ago, GazzaS said: Thanks, Jeroen! So... you dip the model into a tub of water and then pull the mask? I keep the mask under a thin stream if warm water. Dont want the water in the model itself. 7 1
Administrators JeroenPeters Posted July 26, 2020 Author Administrators Posted July 26, 2020 Small steps. Pretty happy with numeral and swastika maskings. After some thought i will use a decal for the nose emblem. Pulling off paint again helped me with this decision. 7
Administrators JeroenPeters Posted July 26, 2020 Author Administrators Posted July 26, 2020 Doing some research in what stencils were on this plane. So far i can only discern the yellow fuel type triangle, handhold stencils, fuselage footstep stencils and NO nicht anfassen markings on the rudder taps. The props are interesting. The rear should be anti glare black. The front aluminium. In some photos the rear shows yellow tips. In some they do not. The instructions tell you that the black dot on the spinner was painted on to create the idea of a cannon. If you look closely you see the tip of the spinner is a little black disc with a screw in the center. Indeed painted black. 4 1
Administrators JeroenPeters Posted July 27, 2020 Author Administrators Posted July 27, 2020 Small progress with panel line washes 8
DocRob Posted July 28, 2020 Posted July 28, 2020 The pre shading makes the otherwise dull grey coating look interesting, great job with the painting. Cheers Rob 3 1
BlrwestSiR Posted July 28, 2020 Posted July 28, 2020 Looks really good, especially on the base. Carl 2 1
Grant Posted July 28, 2020 Posted July 28, 2020 Brilliant work, as always, Jeroen! Looking forward to following this to the end (Almost like old times watching your work) Grant 2 1
Administrators JeroenPeters Posted July 28, 2020 Author Administrators Posted July 28, 2020 3 hours ago, Grant said: Brilliant work, as always, Jeroen! Looking forward to following this to the end (Almost like old times watching your work) Grant Kind words Grant! It’s been too long for us not to chat. Hope you are in good health! 3
Grant Posted July 30, 2020 Posted July 30, 2020 On 7/28/2020 at 6:16 PM, JeroenPeters said: Kind words Grant! It’s been too long for us not to chat. Hope you are in good health! Absolutely- way too long. I’ll give you a call via Messenger if that’s ok and bring you up to speed on what’s what. Speak soon 4
Administrators JeroenPeters Posted August 1, 2020 Author Administrators Posted August 1, 2020 The model recieved a Gunze matt coat and is now ready for pencil weathering. I love these AK pencils... Just started. This should keep me busy for a few days 4 1
DocRob Posted August 1, 2020 Posted August 1, 2020 3 hours ago, JeroenPeters said: I love these AK pencils Have you ever tried them dampened, that is an area, where I like them even more, than in dry use. You can work with them like a multi colored wash, amazing. Cheers Rob 2 1
Administrators JeroenPeters Posted August 1, 2020 Author Administrators Posted August 1, 2020 3 hours ago, DocRob said: Have you ever tried them dampened, that is an area, where I like them even more, than in dry use. You can work with them like a multi colored wash, amazing. Cheers Rob Thnx Rob, works like a charm! Still lots to do.. 3
Administrators JeroenPeters Posted August 1, 2020 Author Administrators Posted August 1, 2020 Slowly... 7
Administrators JeroenPeters Posted August 16, 2020 Author Administrators Posted August 16, 2020 Homestretch. Chipping, small oil washes, exhaust stains. Added a metal rod for the propeller. 4
