Bomber_County Posted December 13, 2021 Posted December 13, 2021 Tim , are you sure this is not 1:1 and the bench is the model…….stunning…. 1 2
Axeman Posted December 13, 2021 Author Posted December 13, 2021 My wife always asks, does it actually run…. 😆 1 3
Axeman Posted December 14, 2021 Author Posted December 14, 2021 Did a test fit of the majority of the hull interior. Not shown but tested the support bar for the floor plating and needed to remove the fire suppression connection (will relocate it). Good thing I tested it before any painting. Just need to work on the generator around the transmission area and the drive shaft. After that I think I can start painting the individual items. Tim 7 2
Bomber_County Posted December 14, 2021 Posted December 14, 2021 13 hours ago, Kaireckstadt said: Amazing work Tim! I’m flashed! Careful now Kai…..😮 3 1
Peterpools Posted December 14, 2021 Posted December 14, 2021 Right with Kai and Phil Keep 'em comin Peter 2
Axeman Posted January 3, 2022 Author Posted January 3, 2022 Back from my holiday vacation. Worked on replacing the belt in the engine area. I will see if I want to use it or not when I go to install it and see how visible it is. The reason I want to change it is that it has two bands but the kit part is only shows one. I am just not 100% feeling good about the scratch built part. Planning on starting to paint individual interior parts next weekend. Tim 5 1
Peterpools Posted January 3, 2022 Posted January 3, 2022 Two part belts look excellent and far better then the kit part. The only thing I see is the larger pulley needs a. bit of clean up at the top and that's it.. Keep 'em comin Peter 2
Martinnfb Posted January 4, 2022 Posted January 4, 2022 The level of detailing and research behind this build is unprecedented, followiiiiing Cheers Martin 2
Axeman Posted January 11, 2022 Author Posted January 11, 2022 Added detail lines for the Priming pump and Hand Throttle. Replaced the hand throttle as the kit part went flying into the abyss. I think it looks better than the kit part did. Then spent two evenings cleaning up one set of tracks. Finally, parts cleaned and ready for painting and then primed. Hopefully I can get some white put down over the next week. I need to start painting so I can get this done by the end of March in time for the local IPMS contest. Tim 7
Peterpools Posted January 11, 2022 Posted January 11, 2022 Tim Incredible work ... amazing progress. Keep ‘em comin Peter 2
harv Posted January 11, 2022 Posted January 11, 2022 Good God man ! Your work is always incredible....harv 🏆 2
Martinnfb Posted January 11, 2022 Posted January 11, 2022 I’m really enjoying this level of obsession:) Cheers M. 2
