Peter, the newer sets of individual link tracks go together much easier these days. A bunch let you put several together at the same time and include jigs which speeds things up. For example, the Rye Field Panther tracks have the pins all evenly spaced so you glue in several at once.
IMG_20190615_131112-600x450.jpg IMG_20190615_131148-600x450.jpg IMG_20190615_131303-600x450.jpg
The kit tracks aren't bad from an assembly point. It's just they don't have the duckbills on the end. At least I can use them on an Achilles.
Well it took a couple nights at the bench but the tracks are done. Once I got into a rhythm, it went fairly smoothly, if a bit repetitive.
I left off a few random duckbills as they tended to get knocked off and  you can see the odd one missing in pics.
Looking great Carl, didn’t one general berate a US crew for adding extra armour etc........was it Patton?.........the most weird is the applied concrete armour........
Looking gorgeous Carl!
Nice idea with leaving off some of the duckbills!
Correct!
Thanks Gaz!
I spent the evening working on the turret. I lost one of the handles for the commander's hatch so made one from wire. I used the purple to add some bling to the tank.
From there, I added the rest of the turret details. One oddity is that RFM give you enough periscope guards on the PE fret but only 4 plastic ones which is 1 short. So I ended up using a mix of the two.
I then added the gun barrel and mantlet.
Finally the spare track armour.
Here's how things look at the moment.
So into the home stretch.
4 hours ago, BlrwestSiR said:
Thanks Gaz!
Really like the results of your work!
Will lead to a beautiful model when finished.
5 hours ago, GazzaS said:
Details look great, Carl.  Would love to hear a bit more about the purple.
Thanks Gaz!
Actually the purple wire was all I had in the right diameter for the handle.
2 hours ago, Bomber_County said:
Looks great, wonder what the weight of the real thing was.......
That's a good question Phil. I know they got heavy enough that it was frowned upon in some units as they were concerned about the increased strain on the drivetrain as well as the increased ground pressure (hence the duckbills).
Geez , Carl, you are a machine..................at this rate , we may have to change your name...... Carl "John" Kung :rofl:
as always, awesome results and a great tutorial on the tracks.... I always learn something from you....
  • Haha 3
I got the muzzle assembled and attached to the gun barrel. There was a small seam line so that needed filling.
I then worked on a bit of stowage. I had some resin bits left from a Legend set so I used those with some PE belts from Eduard.
I also did a bit of a wash on the hull. Not sure if it shows up in the pics or not.
I added a couple decals for the Governor's General Horse's Guard. There's supposed to be a name but the location was covered by the spare tracks so there was no point. In any case, I accidentally threw it out before I could dip it in water and apply it so probably a good thing. :lol:
I added the stowage, gave the tank a light overspray of flat earth for a slightly dusty look and she's done.
One day I'll get the courage to do some figures and add crews to my tank kits. Otherwise, time to call this one done.
Gorgeous looking Sherman, Carl.
Especially the weathering and the add ons are quite realistic! Love it!
I hope that I can build my Tiger as beautiful as you did with your Sherman’s!
