Bent wing bird- Tamiya F4U-1A
31 minutes ago, Kaireckstadt said:
Looks absolutely convincing Carl.
The color of the cylinders is spot on!
Not easy to paint the crankcase due to necessary masking. Well done!
Yep....harv :popcorn:
The engine is coming together nicely. It's looking great oob. Despite this fact, I used the even better Brassin engine for my Birdcage, some years ago. The extra detail came with the price of having to mask all the black cylinder cover metal plates, which Tamiya luckily provided separately. My next corsair will be with the supplied engine too, if only for this reason.
Thanks Kai! I have an easier time masking things off than painting them by hand.
Thanks Harv!
23 hours ago, Peterpools said:
Got ya;)
nice start on the Big P&W
Keep ‘em comin
Thanks Peter! I'm still getting used to the idea of wiring these engines. But it seems to getting easier.
Thanks Rob! I haven't looked at the Brassin' engine but I do have their Merlins so if it's anything like that, it would be impressive.
Reading the instructions (the horror!), I realized I had to make the exhaust and intake stubs first before joining the two engine banks together. I started with the semigloss black for the intakes and then masked them off for the exhaust colour. I used the Tamiya mix recommended in the instructions for those.
They were then glued to the rear of the front cylinder bank.
At the same time, I painted the exhaust pipes and these were installed to the firewall.
I then started on wiring the ignition harness.
Test fitting the ignition harness and looking at reference photos, I realized some of the leads would go through the metal cylinder cover plates. Some go from above and others from below.
It took a while to get them all threaded through and in place but I got it done.
Then I gave the engine a wash using a random mix of Mr Weathering washes. I would Dan my brush in their thinner then in Multi Black followed by Ground Brown and apply to the engine. This way it's not a consistent shade around the whole engine.
I should be able to finish it next time.
Great job you did on the harness, Carl!
Fiddly job and awesome results!
  • 1 month later...
Well, it looks like I haven't updated this in a while. As a result I seems to have missed documenting a few steps.
I attached the engine to the frame and cowl flaps.
The engine then went onto the assembled fuselage. I then finished the assembly of the wing centre section. This was attached to the fuselage and that's where I am now.
