Hey guys
  I've been working on the Tri-drive Pete. I recently bought another Pete, the 1/24 AMT Long hauler (repop of the Italeri kit), got it for a great price $50.00 bucks. So anyway, I started cutting it up and I now have a high roof, large opening cab to sleeper 378, I think? I also made one of the hoods into a extended hood 379. Here's some pics for you to look at.
20210507_172204.jpgthis view shows the stock 378 hood, modified cab with raised roof and modified 63" Unibilt sleeper with enlarged cab to sleeper opening.
20210507_172320.jpgfront view of the cab, you can see the interior and seats that will know be able to recline into the opening, more room for tall drivers.
20210507_172653.jpgrear view of the cab opening and back of seats.
20210507_172627.jpgthis view shows the cab roof and the modifications I made to increase the opening to the sleeper.
20210507_172602.jpgthis view shows the modifications I made to the cab roof and opening.
20210507_172543.jpgthis view shows the raised roof of the cab.
20210507_172816.jpgthis view shows the modifications I made to the opening in the sleeper.
20210507_172943.jpgview of the sleeper from the drivers side.
20210507_172922.jpgview of the sleeper from the passenger side.
20210507_173631.jpgthis view shows the sleeper attached to the cab.
20210507_173610.jpgview from the front.
20210507_173539.jpgview from the drivers side.
20210507_173520.jpgview from the top.
20210507_173501.jpgview from the passenger side with the hood.
20210507_174209.jpgthis view shows the setup on the tractor frame.
  My dilemma is, I'm thinking I might want to use this cab and sleeper along with the 379 exhd to make more of a tandom show truck, and use the stock cab with either a 36" bunk or a flat top 63" sleeper I made form the othe sleeper that I had (it didn't quite come out the way I planed, the corners aren't round enough, my opion) on the Tri-drive. I will post pictures of the 379exhd and flatop sleeper tomorrow.
This is the motor I'm going to use for the Tri-drive, instead of the Cummins NTC-400 thats in it now. It's a Cat C15 twin turbo from Moluminum.
20210507_174904.jpgturbo side view.
20210507_174824.jpgother side view.
This are pictures of the  engine that I got from Jamie at Moluminum of it finished.
20210318_094631.jpgwell that's it for now be back with more updates soon.
Ron G
AWESOME engineering, Ron.... how was the Cat kit to build? Any issues? It looks fabulous, and were the decals included? Or did you get the set from Jerry?
Hey guys
Jeff:  I didn't get any decals from Jamie @ Moluminum. It went together ok, but make sure you get pictures from Jamie, because there ain't no instructions! Doe's he have decals for this, I didn't see them on his site?
Mark: thanks it's still a work in progress.
As I said yesterday I would post pictures of the 379exhd and 63" flat top sleeper, so here are some pictures.
20210508_134925.jpgthis view shows the final setup for the 1/24 Italeri Peterbilt 378 Tri-drive.
20210508_135105.jpgrear view of the rig.
20210508_135210.jpgfront view of the rig, these are just sitting together for pictures.
20210508_141003.jpgthis view shows the Unibilt 63" large opening sleeper, 379 raised roof cab with custom made lower extensions and the 379exhd hood.
20210508_140853.jpgview from the front.
20210508_140823.jpgdownward view.
20210508_141100.jpgpassenger side view of the 379 setup. This will be going on a stock length kit frame (maybe) with 4 single Auslowe aluminum fenders, custom made Texas drop bumper and a s$%t load of chicken lights.
20210508_141631.jpgthis view shows the modified 63" Unibilt sleeper that I tried to make into a flat top.
20210508_141610.jpgview from the rear of the flat top sleeper. I think the rounded corners on the top are not round enough. What do you guys think?
Ron G
  On 5/8/2021 at 6:14 PM, CrankyCrafstman said:
Hey guys
Ron G
Expand
Agreed. They would deserve a bigger radius.
Hey guys
 I've been working on the Peterbilt 379 exhd custom. I decided to leave it stock at 246.0" W/B. I have the frame assembled and I started in on plumbing the air suspension system. The air brakes and fuel lines will come next.
20210515_181817.jpgthis view shows the scratch built rear air bag height control valve and the air lines to the rear airbags.
20210515_181756.jpgthis view shows the scratch built front airbag height control valve and air lines to the airbags.
20210515_181731.jpgthis view shows the whole rear section.
20210515_182050.jpgthis view shows the three air tanks.
20210515_182028.jpgthis view shows the main supply air tank on the bottom and the 2nd service air tank on the top. The purple line goes to the airbags (this will all be painted in the frame color).
20210515_181948.jpgthis view shows the 1st service air tank.
20210515_182146.jpgthis view shows the 2nd service air tank and the inline air filter to the airbags.
 The next 4 pictures show the hollowed out universal joints that I did to add some more realism to the build.
20210515_182407.jpgI took out about a scale 1.5" - 1.75" out of the ride height, so the truck sits a little lower to look cool!. Well that's it for now be back with more updates soon.
Ron G
Thanks guys
I have the brake lines almost done, I ran out of the purple wire I was using for the air lines, so now I have to switch to green, but it's all going to be painted the frame color so it doesn't matter.
20210519_150500.jpgthis view shows the rear area if the truck.
20210519_150609.jpgthis view shows the rear brake modulator and the height control valve.
20210519_150548.jpgthis view shows the front brake modulator valve on the left and the rear brake anti-lockup modulator on the right.
20210519_150427.jpgthis view shows the Cummins NTC-400 and the front brake line, I used braided line for these.
20210519_150249.jpgthis view shows what this truck is going to look like when it's done.
20210519_150229.jpgview from the rear showing the polished aluminum rear fenders and the rear light bracket, I have red, amber and clear lights for this.
20210519_150157.jpgview from the front showing the custom made "Texas" bumber and the 10" stacks, I still have to figure out how to make the lower curved part of these, I think I'm going to try Plastruct elbows and paint them chrome.
20210519_150446.jpgview showing the hood open. Well that's it for now be back soon with more updates.
Ron G
Thanks guys
  I did some work on the interior. I add some very thin grey velour with adhesive backing to make the carpet.  I got these off of Amazon, I got 2 sheets 8 1/2 x 11 of grey, dark charcoal, dark brown, medium brown, light brown, beige and dark wine red. It works great for carpeting on 1/25-1/24 models, and it sticks pretty good.
20210524_171224.jpgthis view shows the arm rests I added to the inner sides of the seats, also the seat backs that I added. The velour carpeting looks kinda beige, but it is light grey.
20210524_171205.jpgthis view shows the clutch, brake and gas/fuel pedels that I added.
20210524_171148.jpgthis view shows the small blue wire that I added to the shifter column and the retainer I made for it from some 1/64" tape.
20210524_171128.jpgI plan on carving some seat cushion detail into both seats. You can just barely see the pencil lines I added to the seats for this purpose.
  I have both photo etch sets for the 1/24 Italeri Peterbilt 379/377 from Czech model trucks, so the instrument panel will be photo etch along with the steering wheel center, shift and air knobs, plus all of the exterior photo etch, alot of bending :wacko: but it will be worth it in the end.
Ron G
Hey guys
 Small update, I have been working on the interior.
20210525_164950.jpgI have the interior almost done. I added some carpet to the door panels.
20210525_165133.jpgthis view shows the Czech Model Trucks instrument panel, air knobs, glove box and gear knob installed.
20210525_165106.jpgthis view shows the detail I added to the seats, I did this with a 0.1 mm Molotow black marker and paint, a little hard to see but if you zoom in you can see it.
20210525_165339.jpgthis view shows the Czech Model Trucks 4 spoke steering wheel center I added to the kits steering wheel ring. I still have to add some clear acrylic gloss to the gauge faces.
 Well that's it for now be back soon with more.
Ron G
Thanks guys
 Some more work done on the interior.
20210526_172922.jpgI totally remade the bed. I used two of the kit mattresses glued back to back to make it thicker (this trucker, like me has a bad back...lol).  You can just see the pillow that I made with a piece of foam rubber for a pillow and covered in a piece of paper towel for a pillow case.
20210526_172857.jpgthis view shows the blanket, made from blue paper shop towel, and both sheets, made from paper towel.
20210526_172836.jpgthis view shows the bed support structure and it covers the bunk heater area (that you won't see).
20210526_172820.jpgthis view shows the other side of the bed support structure.
20210526_172801.jpgbottom view of the bed support structure. I have to paint all of this.
20210526_172734.jpgthis view shows just the bed, sheets, blanket and pillow.
20210526_172716.jpgthis view shows the carpet added to the sleeper floor.
 Now I have to figure out what color to paint this rig. Dark blue with light blue frame? Red with black uppers and fenders with black frame? Pink with purple poka dots...lol. Give me some ideas guys?
Ron G
