Painted the propeller, "screwed the worm". I tried it all on the glider, there's a reason I chose this option. )))))
8 hours ago, Bomber_County said:
Stunning Sasha, can never get that swirl right, albeit I’ve only tried it once……
Bomber_County thank you!
8 hours ago, GazzaS said:
Love those rivet lines....    How did you do that?
Gazzas thank you! Doing this. After painting and drying, back side of 3000 sandpaper to rub the surface, not too much until the rivets appear. It is clear that after the primer is applied metallic. In this case, rolling the rivets for a natural look is very effective.
  • 1 month later...
Continued the work. Imitated the cab visor washer tubes. Made tubular rails at the base of the sliding cab lantern bindings, guide rollers. Guns blacked out, glued pneumatics . The antenna will be taut in any lantern position.
Beautiful work!  Love to see all of the close-up details.   Lovely weathering...   just right!
