ScottsGT Posted November 29, 2022 Posted November 29, 2022 1/144 C-17 on the SOD. Putting in some time until the group build starts. Easiest way to paint these tiny wheels and tires white/black? I have 14 to paint. 🤪 ok, my brain was turned off. Took me all of 5 seconds after I posted to remember I have a cheap set of hole punches and the wheel on this 1/144 kit is exactly 1/8” in diameter. Doubled up tape, tapped it with a hammer and peeled off the top “mask”. When I did it directly on the wood it wouldn’t stick to the plastic. I guess either the tape picked up wood fibers or the wood stole the sticky. 5 2 1
biggtim Posted November 29, 2022 Posted November 29, 2022 Good lord, why would you torture yourself like this? 2 5
ScottsGT Posted November 29, 2022 Author Posted November 29, 2022 On 11/29/2022 at 9:12 PM, biggtim said: Good lord, why would you torture yourself like this? Expand Man, I started this kit right when Revell came out with it. According to the box, that was 2008. It’s been neglected long enough. You think the kit is bad enough being this tiny? You should see my crappy work I did back then that I’m having to fix now. But between large scale builds I spend a little time on it. One day I’ll cross that finish line. 5
HubertB Posted November 30, 2022 Posted November 30, 2022 My tip : make it an inflight display… HTH 😂 Hubert 3 7
Martinnfb Posted November 30, 2022 Posted November 30, 2022 Easiest way is to paint the centers white, never mind the overspray. And then with diluted back, using the capillary effect wash the edge of the rim around. Let it dry and finish it off with a few brush strokes. 6
CANicoll Posted December 11, 2022 Posted December 11, 2022 On 11/30/2022 at 1:50 PM, Martinnfb said: Easiest way is to paint the centers white, never mind the overspray. And then with diluted back, using the capillary effect wash the edge of the rim around. Let it dry and finish it off with a few brush strokes. Expand Definitely!! The capillary action is a huge help here. And for wheels/tires this small, I'd hand paint, leaving the tire on the sprue at one attachment point (what will become the bottom) to make it easier to hold. 2
k5ikl Posted December 11, 2022 Posted December 11, 2022 On 11/30/2022 at 1:50 PM, Martinnfb said: Easiest way is to paint the centers white, never mind the overspray. And then with diluted back, using the capillary effect wash the edge of the rim around. Let it dry and finish it off with a few brush strokes. Expand Exactly how I do 48th and 32nd wheels. Jerry 2
ScottsGT Posted December 11, 2022 Author Posted December 11, 2022 Well I tried the capillary method. So little detail it got into the hub. Started punching out masks for the outside of the wheel. Inside won’t work so I’ll just dab on some white in the center 3
JohnB Posted December 11, 2022 Posted December 11, 2022 Looks like one of those high cuss factor things.......🤪 2
Peterpools Posted December 11, 2022 Posted December 11, 2022 Scott When I painted the wheels and tires on my 1/144 Embraer 190 for the last GB, I painted them both ways. I just went super slow and there were some capillary runs to clean up but it went pretty well. Of course, I think I only had six sets to do, way less then C17 has. 1
Administrators Clunkmeister Posted January 24, 2023 Administrators Posted January 24, 2023 I just can’t ever seem to get my roller in there that well.
ScottsGT Posted February 7, 2023 Author Posted February 7, 2023 On 1/24/2023 at 9:49 PM, CANicoll said: So... Did you finish the C-17? Expand If you look at my wet build progress pics you can see it still sitting on the top shelf of my bench. One day… 1
