HubertB Posted August 7, 2024 Author Posted August 7, 2024 Not a lot of apparent progress to report, but some I feel pretty smug about... A bit of background. Fisher seem to have completely forgotten one aspect of the Cutlass, that is the device that holds the arrestor hook in place (or if it was included, it is not in the parts I have, nor apparently in the instrcutions, but then some small details have been overlooked in the said instructions). This is what it looks like IRL. The photos are lifted from an IPMS NL walkaround, but beware that the F7U-3M displayed seems to have been cannibalised, or vandalised, over the years, and not every component is still present on this airframe. And this is my rendition of it, adding a few pieces that seem to make some mechanical sense, but are apparently not on the walkaround pics. The whole is less than 1 cm long, if you wonder ... I quite like my springs, made from 0.2 mm tungsten wire coiled around a 0.5 mm brass rod A few hours' work, not perfect, especially the alignment which is slightly off, but "good enough for govenment work" as the saying goes. In the meantime, I have started repairing the rear of one wing tip, which has been damaged in all the handling the Cutlass has endured so far. And the fins are now glued in place. Next should be mating the front and rear of the bird. TTFN Hubert. 10 1
GusMac Posted August 7, 2024 Posted August 7, 2024 Looks great Hubert. Certainly a helluva lot better than most government contractors here could manage. 😁 2 4
Peterpools Posted August 8, 2024 Posted August 8, 2024 Hubert Brilliant - awesome work on the missing arresting hook details. 4
ScottsGT Posted August 8, 2024 Posted August 8, 2024 I’d be in a straight jacket by now if I tried sinking this much detail into my build. Hell, I’m almost there as it is. 8
CANicoll Posted August 8, 2024 Posted August 8, 2024 Nice work and on the research as well... Can't imagine there are that many surviving Cutlass's out there for reference... 3 1
HubertB Posted August 8, 2024 Author Posted August 8, 2024 1 hour ago, CANicoll said: Nice work and on the research as well... Can't imagine there are that many surviving Cutlass's out there for reference... There are seven surviving airframes, most of which have been used as gate-keepers and have rotten consequently. The pics I posted are from a F7U-3 displayed at the NASM in Pensacola, and features many bogus features and / or missing components. It’s (wrongly) tagged as a F7U-3 M. I have used other pics for some detailing, like the landing gear bay, of BuAer 129554 (a F7u-3), which was supposed to be restored to flight condition. It has changed hands many times, and is now in Phoenix, AZ. I don’t know if it will ever be finished to flightworthy condition, bur whereas the hydraulic system could be updated to modern standards, and thus alleviate one of the main issues that plagued the Cutlass, the question of the engines would remain, and of the fragile front landing gear strut … It’s still the most reliable source for detailing the kit Hubert 4
CANicoll Posted August 8, 2024 Posted August 8, 2024 Have you tried a web search on "7U Cutlass blueprints"? I saw a lot of drawings, but not sure if any of those would be helpful to you? 3 1
HubertB Posted August 9, 2024 Author Posted August 9, 2024 20 hours ago, CANicoll said: Have you tried a web search on "7U Cutlass blueprints"? I saw a lot of drawings, but not sure if any of those would be helpful to you? Well, thanks for the tip, Chris. I am usually wary of drawings, as they can sometimes induce some mistakes, and most of these are no exception. But it yielded some pics of the plane I intend to model, which I had not found hitherto, and will prove invaluable 👍 ! Hubert 3
BlrwestSiR Posted August 9, 2024 Posted August 9, 2024 Very nice work on the tail hook mechanisms there Hubert. For small springs, I've found that a number of Japanese companies make them in various diameters and colours. Wave and T2M both come to mind. I think GSI does some as well. I'll grab some pics when I'm at my bench. 2 1
BlrwestSiR Posted August 17, 2024 Posted August 17, 2024 Hubert, I finally found my stash of springs. As you can see, they come in lots of diameters and black or silver. They're very flexible and I use a set of nippers to cut them to the desired length. 3 2
HubertB Posted September 15, 2024 Author Posted September 15, 2024 Whilst I was 3D-printing some parts for the Potez 25 TOE in the "Sandbox" GB, I also added on the plate some acccessories for the Cutlass, namely a tow bar, two wheel chocks and a boarding ladder. I will probably revisit the design of the tow bar, that looks a bit skinny now that it is printed. The Cutlass is on the back burner whilst I focus on the Potez. I had a tough time smoothing out the wing slats, as Fisher's design is less than optimal in the area, IMHO. Now that I have revived my 3D-designing and printing skills, I may have a go at redesigning the slats and their struts as an integral part. I had to cut off the struts from the kit in order to smooth the slats recesses on the wings, and, although I have already done some new struts using plastic strips, I am not keen on smoothing the inside of the slats and am not 100 % sure I can obtain a solid link between the plastic struts, the wings and the slats … Hubert 7
Peterpools Posted September 16, 2024 Posted September 16, 2024 Hubert, amazing work as I only wish printing was in my future but being realistic, it isn't. Looking forward to the Cutlass making its return to the bench after the GB. 2
HubertB Posted January 19, 2025 Author Posted January 19, 2025 Resuming operations ... in slow motion ... Now that I have finished my entry in the Sandbox GB, and my small interlude with the Rutan Quickie, back to finishing the Cutlass. I had left it on a frustration, i.e. the wing slats area... The way Fisher has chosn to represent them makes modellers' life a bit difficult. Part of the slats' "recess" on the wings is molded integrally with the wings, and then you have to glue an insert including the slats' arms in a slot in this area. It would be all good if the parts - the wings on one hand and the part-fairings with slats' arms on the other hand - were closely matched, with little adjustment, sanding and filling necessary. Alas, this is not the case (it may also be partly because I started the kit 10 years ago, and the resin has continued to evolve, and shrink in some places). So you end up with at best some nasty seams to fill and sand, and at worst with a step betwen the two parts, that needs to be filled, than sanded. and all of this with the slats' arms in the way 😡 ! In the end, I decided to go for a more radical solution, in three steps : 1) remove the slats' arms, sand and fill to have a smooth base 2) redo the slats openings in the smoothed leading edges. I had a bit of operator's error in their placement, so had to re-fill and re-do some ... 3) design and print some new slats, integral with their actuating arms ... Here is the result of this work. It does not look nice, but is in fact very smooth with only very minor blemishes still to fil and sand The small fairings on the top of the wing, that match IRL some slots in the slats, have been re-done with some plastic strip and smoothed with the wings' upper surface. The slats recesses were also accentuated to have a more visible separation with the wing's upper surface. It was a tedious job to scrape them whilst keeping a straight line ... And the newly-designed and printed slats, already primed and sanded to achieve a smoother finish than the raw printed appearance. Whilst I was in the surface treatment phase, I decided to do some extra work, which then pushed me in slow motion because I am definitely, with hindsight, not a fan of it : redo the structure lines which have been sanded away here and there, and then add some rivets ! I will go for a VA-83 NMF finish, and the rivets are sometimes faintly discernible. Fisher's resin is very hard (probably also because it has had 10+ years to cure some more) and riveting with a pounce wheel requires a significant amount of pressure to achieve even a small impression. I soon found out that holding a ruler with one hand, and applying pressure on the pounce wheel with the other hand was just too impractical : you need to move slowly to impress the resin, and the rule slips, or does not hold when taped in situ. So in the end, all the riveting was done free-hand. Some lines are totally straight, but then close examination of the pictures showed that it was also the case with the 1:1 aircrafts. There was no CNC machining back in the early 50's ! Anyway, some samples of the riveting work. It will be attenuated when I prepare the surface with steel wool for priming. Only time will tell - and show - if the hours spent were woth the aggravation ... When this was done, came the time to finally match the nose and main fuselage ! The fit of the Fisher kit is this area is challenging, and trials showed that some pressure would be needed to ensure that the fuselage parts matched both on the top - that was relatively easy - and the bottom, where there was a gap to eliminate with brute force But nothing that epoxy and a heavy duty clamp can't address : When the clamp was removed after a few hours for the epoxy to really set; the top had a small joint and minor step that was easily filed away (here with some Mr Surfacer 500 to better see what remains to be sanded and smoothed : On the bottom however, there was still a step between the front fuselage and the rear one (but no seam / chasm to fill) As the front fuselage has the front LG bay going to its end, the step has to be filled on the rear fuselage, rather than filed on the front fuselage. And as I will need to reinstate some panle lines and rivets, I wanted a hard surface. So, after afew minutes with CA glue and Colle 21 "magic dust", the main of the step has been filled, and the profile roughly re-established. Here as well, I have slathered some Mr Surfacer 500, so the pic is still ugly, but the bulk of the correction xork is done, and now it is just a question of sanding and finishing ... And that is all for now. I should be able to move forward with a brisker pace, now that the essential part of the tedious jobs is behind me. Hubert 7
HubertB Posted February 2, 2025 Author Posted February 2, 2025 Compressor stall … without firing any gun. I have to say that the combination of issues with the slats and the re-engraving of panel lines, plus the decision to add riveting proved to be somewhat of a mojo killer on the Cutlass. Or at least a driver of procrastination … Which means I have not spent a lot of time at the bench in the last two weeks, or not as much as I could have. I compensated by more reading, but it was Sci-Fi books like the 3-body problem trilogy or « Ball lightning », also from the same Cixin Liu … Still, I did some progress on finishing the surface preparation, which culminated with the gluing of the front windscreen, a necessary step to avoid any more sanding after priming, as it is not a drop fit that goes without any fitting and sanding … So, this morning was the time for priming. But, like the Cutlass initially, when the guns were fired, I experienced a compressor stall ! Or, more precisely, a burst pipe; only it’s a pneumatic one, not a hydraulic one, as it happened so often with the Cutlass … The pipe that connects the pressure gauge to the tank of my airbrush compressor had a cut at the level of one connection nut, and burst. So the compressor is now literally stalled, until I can install some new pipe, which I have already ordered. No pic to show, as there is not any interesting one to show, so more progress some time in the future … Btw, I had ordered and received the following book. Interesting reading, and some pictures I had not seen before. And it has somewhat changed my mind on the reasons of the failure of the Cutlass. Yes the J-46 was a poor engine, as Westinghouse tried to implement the ancestor of modern-jet engines FADEC, and it was just to innovative for the time’s technology (remember that FADEC development problems nearly killed the A-400 M program ?) , and had an insufficient military thrust, but the main issue was the lack of proper transition training for the pilots of the time, coupled with the specific problems of straight-deck aircraft carriers. Transition training led to the creation of NATOPS (and the Cutlass issues were a key driver behind this new approach) and the development of a twin-seat swept-wing fighter, i.e. the famous « Twogar ». And the accident rate of the Cutlass dropped dramatically, at levels lower than other contemporary Navy Fighters, with the introduction of angled-decks carriers. More when possible … Hubert 8
HubertB Posted May 4, 2025 Author Posted May 4, 2025 Time for a new update. After a few weeks (a lot more than I antcipated or wished ), there is now some paint on the Cutlass. Some pics of the process, just to mention that this was un unncessary step: I tried to introduce some variation in the scheme by addng some randomised black basing. But the truth is that I am probably neither skilled - or patient - enough tothen spray the upper layers in a thin enough enough way for the underlayers to show through. .. First a pic where the attach points for the underbelly rocket pack have been added, made of brass sheet drilled and filed to shape. These are fragile, and I have lost a few in the painting process (one to redo as of this morning's inspection) .. And of the pre-basing ... And as where she stood yesterday evening before I started applying some decals : The paints used are MRP White aluminium, duralumin, dark aluminium, chrome (to show some of the shininess very visible on the the NMF Cutlasses), anodized aluminium, plus Alclad Aluminium, dark Aluminium. The magnesium parts of the Cutlass were painted in Silver lacquer, which I reproduced using MRP silver, Alclad Super Silver. I used aluminium foil on the "Metalite" panels of the Cutlass (mostly, but not exclusively, the wings. These were an aluminium and balsa sandwich, and were VERY shiny on the Cutlass. After the basing disappeared under the layers, I introduced some variation by using different tones of the paints listed above, sprayed in different patterns ... The difference is visible to the naked eye, yet subtle, and hopefully reproduces some of the real life effects, and willl, hopefully again, show on the pics ... You can also see the blue-with-white-trim markings of VA-83 aircrafts in 1956, and sported during the Intrepid's Mediterranean cruise that year ...These gave me a lot of aggravation, a lot due to operator's errors and sequencing, but the final effect is striking . I will reproduce the CO's aircraft, coded 301, which had characteristic diagonal stripes on the wings and flaps' ends. TTFN Hubert. 7 2
ScottsGT Posted May 4, 2025 Posted May 4, 2025 Wow Hubert. You’re attacking this like a honey badger! It was a major battle to not lose interest in my build just to make it a mediocre finished product. Glad to see you tackled the hard to replicate bare metal finish. I was not brave enough. 2 1
DocRob Posted May 4, 2025 Posted May 4, 2025 I like the finish as well, Hubert. I think pre shading under NMF is not going to work very good, but you could post shade a bit, beside the panel accentuation you already did. I once used stretched metal sponge and sprayed very finely through it panel for panel to have a worn surface effect. I liked the look on my Mig-31 build some years ago. On the lower parts of page three, I described the method. Cheers Rob 1 1
HubertB Posted May 4, 2025 Author Posted May 4, 2025 1 hour ago, DocRob said: I like the finish as well, Hubert. I think pre shading under NMF is not going to work very good, but you could post shade a bit, beside the panel accentuation you already did. I once used stretched metal sponge and sprayed very finely through it panel for panel to have a worn surface effect. I liked the look on my Mig-31 build some years ago. On the lower parts of page three, I described the method. Cheers Rob Ah yes, now I remember it ! As: 1) I felt the variation did show, even if not linked to the basing 2) I am wary of adding yet another few microns of paint, especially as the whole aircraft has been gloss-coated with Aqua_gloss 3) I have started adding some decals, I will use this technique on my next NMF aircraft. But it's now filed and thank you for the reminder. Hubert 3
Martinnfb Posted May 5, 2025 Posted May 5, 2025 Incredible attention to detail Hubert. Captivating journey to follow. Cheers Martin 1
HubertB Posted May 11, 2025 Author Posted May 11, 2025 A smallish update, with workbench pics of the Cutlass. I have now finished the decalling. I created and printed the VA-83 specific markings, and used the Fisher decals for the rest. By the way, in case you wonder, the painting specs devised by the Navy and Cutlass were that the national insigna were to be "decals" on the 1:1 aircrafts. Which gave me a good excuse for not cutting masks ... I still have to add a last layer of varnish to seal everything, but am waiting for the additional parts add-ons. I am now in the process of painting the batch of small parts (some I had painted already, but forgot a number) and I had also to print yet another time the slats, as the large ones keep warping after a few days Unfortunately, it looks like this last set is going the same way ... . Oh well, not again ... Next "installment" will be with the mounting finished and all parts glued in place. Cheers for now Hubert 7
Landlubber Mike Posted May 11, 2025 Posted May 11, 2025 Looks really good Hubert, some really impressive work there! 2 1
