Mark 'ozzy' Ostler Posted December 21, 2016 Author Posted December 21, 2016 Right, time to fix up rivet errors, re scribe, sort out gap between cockpit and fuselage. I used mr surfacer 1200 and I must say that I'm impressed with this primer, all corrections can be easily identified to remedy, and it has a silky smooth surface texture- superb in fact. I've decided to use tamiya enamel for the exterior as I like the way it sprays. I find acrylic too temperamental getting the viscosity right, never fails with enamel and I don't encounter blockages at the needle tip. I will make my own colour up for the lower surfaces (RLM 76) as Tamiya's XF 23 doesn't look right out of the bottle. Most of my paints are always tweaked for personal taste. First coat will be the upper RLM 75 followed by the lower RLM 76 and mottling. I need to work the mold line off the canopy pieces before I can mask, so that's where I'm at the moment...cheers. Oz
Members Mikester Posted December 21, 2016 Members Posted December 21, 2016 Mr. Surfacer is the business, looking good! 1
Mark 'ozzy' Ostler Posted December 21, 2016 Author Posted December 21, 2016 Cheers mikester, any tips to remove the mold seam off canopy, I need to order some micromesh polishing cloths and some compounds, and recommendations? Cheers. Oz 1
DocRob Posted December 22, 2016 Posted December 22, 2016 Hi Ozzy, scrape the seam away with a sharp blade, scraping as much as necesary and try to avoid damage beside the seam. The next step is polishing. I use a micro drill with polishing (cloth) head and a polishing paste, but you can use micromesh or these very fine Albion Micro Finishing Cloth Abrasive Pads-Set http://www.albionhobbies.com/flex-i-file-precision-abrasives/ with a range from 3200-12000 grit. Moist the pads a little to prevent from damage by loose abrasive material. After finishing the polishing process with the finest grid, clean everything up and dip the clear part into future or something similar as soon as possible, before the static functions as a dust magnet , voila seamless canopy all clear. 1
Mark 'ozzy' Ostler Posted December 23, 2016 Author Posted December 23, 2016 Thanks doc, I need to buy some bits & pieces so I will do this shortly. Tamiya's coarse and finish polish's are available (dubious about the coarse) with some micro mesh cloths are on the order list & some drill bits to install the Master radar antenae's. Moving closer to painting. Cheers. Oz
GusMac Posted December 23, 2016 Posted December 23, 2016 Hi Ozzy, can recommend the Micromesh clothes but I share your doubts about the Tamiya coarse polish. Used the coarse and fine on the canopy of my current Tamiya F-15C build but I'm pretty sure I could have gone straight from the highest grit Micromesh to the finish polish. It does look and feel freakily like toothpaste but as long as you keep it out of the bathroom you should be ok! Gotta agree about the Mr Surfacer as well, it's great stuff, especially the black 1500 if you want to go down the black-basing route. Never tried spraying the Tamiya enamels as they're hard to get in the UK but I find the acrylics spray much better when thinned with Mr Levelling thinner. The 'Owl' is looking great so far, looking forward to seeing the paint going on. 1
Mark 'ozzy' Ostler Posted December 24, 2016 Author Posted December 24, 2016 Hu GusMac, I've just found GSI Creos have a compound that is 3000 grit, the finer stuff is out of stock. Might even try some ultimate buffing sticks, if that doesn't work I'll try the micromesh cloths. As its Christmas I can't get anything sent to me until the 29th, so I can't paint till the canopy until it's sorted and masked, and I can't drill out the radar Stubbs until I get some appropriate sized drills. Post some photos a soon as the first coat of paint is laid down. Cheers Oz
Mark 'ozzy' Ostler Posted February 19, 2017 Author Posted February 19, 2017 Finally the PE radar antenae's are built and primed, holes drilled for installation. First paint colour applied but some repair work on a join is currently being undertaken. Oz
Jorge Márquez Posted February 19, 2017 Posted February 19, 2017 Very tempting the table and great work, pedneintes of the new advances that surely we will walk here in the construction of the Uhu. 1
Mark 'ozzy' Ostler Posted February 26, 2017 Author Posted February 26, 2017 Finally, the camaflage has been applied. Next step is to seal the entire model with Alclad clear gloss. Then I will start washes, filters and general weathering of the aircraft. The Fu 220 bottom radar antenae's were painted the wrong colours up, I will remedy that as well as other touch ups with the airbrush. The propeller hubs will be painted a darker colour of Tamiya XF-1 & XF-24 @3:1. I hope the XF 24 grey just warms the black for subletly, but I wanted to paint this owl with a darker paint scheme than the average. I am happy the RLM 75 is more prominent than the RLM 76. The Fu 212 radar antenae's will receive a coat of Matt Schwarz soon as well as the rear radar. The light lenses, gun sight, armoured windscreen plate will receive paint. Hopefully I will be able to apply the decals after some suitable replacements are sourced from web. Cheers Oz
Administrators JeroenPeters Posted February 26, 2017 Administrators Posted February 26, 2017 Nice! Looks like you nailed it. 1
DocRob Posted February 26, 2017 Posted February 26, 2017 Nice mottling, the paintjob just looks right. These antennas would scare me to death. When I do my Owl I will fit them at the last possible moment, metal or not.
coolboxx Posted February 26, 2017 Posted February 26, 2017 Looks very good, need some more pictures please...
Uncarina Posted February 28, 2017 Posted February 28, 2017 Sweet! Really nice work with the build, painting, and riveting. I'm following your lead with riveting, but I'm still on the lookout for references for this. Thanks for sharing your work. Cheers, Tom
kahunaminor Posted March 14, 2017 Posted March 14, 2017 1 hour ago, shark64 said: lovely airbrush work. Yes, yes, yes! The shots remind me of very much an aircraft under clear shallow water. I suppose that was the intended outcome in the camouflage. Great work and thanks for sharing it. Regards, 1
Mark 'ozzy' Ostler Posted March 14, 2017 Author Posted March 14, 2017 thanks for the favourable comment ! I wanted to do a darker type of camouflage colour for my owl. I'm working 72 hours a week so I don't get a lot of bench time at the moment! Since last photo I have applied gloss coat and some decals. Will post more photos on weekend, hope to make a start with weathering and pastels. Cheers. Ozzy
Mark 'ozzy' Ostler Posted March 15, 2017 Author Posted March 15, 2017 Thanks mikester, can't wait to invest some hours in building this weekend. My mojo is finally returning! 1
