Martinnfb Posted April 3, 2022 Author Posted April 3, 2022 Dehumidifier would be my call for a storage place. Temperature is not much of an issue in BC, its the bloody humidity . 2
Jeff Posted April 3, 2022 Posted April 3, 2022 18 minutes ago, Martinnfb said: Dehumidifier would be my call for a storage place. Temperature is not much of an issue in BC, its the bloody humidity . It can get chilly, like -20 c and the dehumidifier is a good idea....and yes quite damp at times.... although where I am , it's not like at the coast..... 1
BlrwestSiR Posted April 3, 2022 Posted April 3, 2022 I'm with Martin, go with floor heating. In floor radiant is fantastic. And since you're building it from scratch shouldn't be too hard to incorporate. My y wife regrets not doing it in our kitchen when we reno'd. 2
Jeff Posted April 3, 2022 Posted April 3, 2022 7 hours ago, BlrwestSiR said: I'm with Martin, go with floor heating. In floor radiant is fantastic. And since you're building it from scratch shouldn't be too hard to incorporate. My y wife regrets not doing it in our kitchen when we reno'd. My buddy said that was the way to go, a closed circuit so to speak.... may have to seriously look into that 1
GazzaS Posted April 4, 2022 Posted April 4, 2022 Salamander? They crank out the heat and only use a bit of Kerosene last I knew. Seen them at lots of job sites supplying heat in the Michigan winter. 2
Jeff Posted April 4, 2022 Posted April 4, 2022 Thanks Gaz, that may be a consideration as well, although I would like to keep the temp at a fairly constant 60 f.... 'ish' if possible..... thanks for the input.... everything helps
Martinnfb Posted May 4, 2022 Author Posted May 4, 2022 Look mom, no brains” this just arrived to Canadistan. Ordered in January 5 1
Martinnfb Posted May 7, 2022 Author Posted May 7, 2022 Today was the day. Bed liner is in, substantial debt is on . Upon arrival I had to remove those hood decals so kids won't mistake my car for Santa's sled . It has pretty much all I wanted except for the LED lights that weren't available when I placed my order. Somebody was super excited . And it speaks Russian too. Because two is better then one And after some time of rubbing off the adhesive residue, it is somewhat presentable. Althou my special operation to eliminate the nazi orange will continue till further notice. 6 1
GazzaS Posted May 8, 2022 Posted May 8, 2022 59 minutes ago, Martinnfb said: Today was the day. Bed liner is in, substantial debt is on . Upon arrival I had to remove those hood decals so kids won't mistake my car for Santa's sled . It has pretty much all I wanted except for the LED lights that weren't available when I placed my order. Somebody was super excited . And it speaks Russian too. Because two is better then one And after some time of rubbing off the adhesive residue, it is somewhat presentable. Althou my special operation to eliminate the nazi orange will continue till further notice. Why is it Nazi Orange? 2 1
Martinnfb Posted May 8, 2022 Author Posted May 8, 2022 Just my poor attempt to be funny. Orange kills the beautiful sarge green clear coat. According to the current trends , if you call something "nazi" nobody objects your opinion, unless you are complete douche about that such as ......... can't recall Justin's name so quick, anyway Nazi Orange has to go! 3
BlrwestSiR Posted May 8, 2022 Posted May 8, 2022 Looks much nicer with all the marketing material removed. I've got Fox shocks on my mountain bikes so those are always a good sign. 3 1
DocRob Posted May 8, 2022 Posted May 8, 2022 8 hours ago, Martinnfb said: Today was the day. Bed liner is in, substantial debt is on You should widen your debt and invest in a soft top Martin. You seem to have fine weather now and it's pure joy to drive open topped. I have both tops, but the hard top is rotting in the garage, as I never liked handling the heavy and sensitive (mine are painted) targa parts. The canvas top is very robust and even stormy conditions are no problem with it. Your ride looks great now and I am a little jealous at your zillion gear automatic, where my JK has only five. In the flat country it should be sufficient, but with our steep mountains here it's often hit and miss. Generally I like the rough appearance of the JK a bit more, so I have to live with that . Cheers Rob 5
Martinnfb Posted May 8, 2022 Author Posted May 8, 2022 Thank You Rob, I was tempted to get the soft top, but I wouldn't use it. Calgary is 1200m over the sea level, located between Rocky Mountains and Alberta prairies . The weather can be unpredictable and savage, storms, hail, even a small tornadoes. Ranging from +30 to -30C. Hard top will seldom go off if ever. Having said that, I am getting a stainless steel SmartCap EVO top, roof insulation, mud flaps, decent rubber mats and rear bench dog cover to began with. 5
DocRob Posted May 8, 2022 Posted May 8, 2022 1 hour ago, Martinnfb said: Thank You Rob, I was tempted to get the soft top, but I wouldn't use it. Calgary is 1200m over the sea level, located between Rocky Mountains and Alberta prairies . The weather can be unpredictable and savage, storms, hail, even a small tornadoes. Ranging from +30 to -30C. Hard top will seldom go off if ever. Having said that, I am getting a stainless steel SmartCap EVO top, roof insulation, mud flaps, decent rubber mats and rear bench dog cover to began with. Makes all the sense in the world Martin. You must have caught one of the better days for taking the pics in your weather tormented home area . On my island the weather changes rapidly sometimes, so for me the soft top is perfect as it is opened or closed in two minutes and I often have to do it on my way, because of changing conditions. The main reason for closing up though is wind, as we have no freezing temperatures except on the highest summits in winter time. Driving open through light drizzle normally is no problem as astonishingly few rain enters the car. We have that very often, when passing the clouds. You seem perfectly prepared for winter conditions with only the exception of an ice bear frontguard with your Jeep. Love the color of yours, which would have been my second choice, if available for my model. Cheers Rob 5
Martinnfb Posted May 8, 2022 Author Posted May 8, 2022 I literally picked a moment between two rains to snap those shots. It was a rainy night as well. As I just installed the dead foot pedal and the truck was still wet. Oh, Island living must be so beautiful, ocean breeze , runs on the beach, surfing. Sarge green wasn't on the plane at all, originally I wanted Gobi colour which wasn't available, then it would be Stingray, but the hope around grey kinda killed it for me. So Rachael suggested to have matching colours, sounds silly, but she was right as always, green looks very imposing and changes hue in the light. Nevertheless, my first choice of colour would be Gator. 4
Martinnfb Posted May 11, 2022 Author Posted May 11, 2022 Special operation to eliminate orange was successfully finished in 3 days. bug deflector and anti glare blackouts were added as well . Undercoat is on . 5 1
BlrwestSiR Posted May 12, 2022 Posted May 12, 2022 Looks good there Martin. Hopefully the dog doesn't eat the seat covers. 1 2
Martinnfb Posted May 12, 2022 Author Posted May 12, 2022 Got them a special rear bench , hammock style cover from Amazon 3
HubertB Posted May 12, 2022 Posted May 12, 2022 15 hours ago, Martinnfb said: Got them a special rear bench , hammock style cover from Amazon Given the … « munchy » … nature of one of the dogs, maybe a stainless steel cover, or better yet, some ERA, would be more appropriate ? Just my Hubert 3
