CANicoll Posted December 25, 2022 Posted December 25, 2022 Peter: "Now if I could only actually remember where I put things - that's the challenge these days. " That is increasingly my problem, too!! Merry Christmas! 3 2
CANicoll Posted December 26, 2022 Posted December 26, 2022 13 hours ago, Peterpools said: Chris Nice paint station organization - everything is where it should be. I still haven't set up my 1530 Artogragh Spray Booth and am using a small portable unit I bought from Micro Mart. What's holding me back is the dual venting/ducting. How did you hook up yours? I have to remove the ducting from the window when done and still haven't figured out a good system. Sure wish the spray booth would have come with the ducting but it didn't. I'm guessing from the phots, you have a 1530 Artograph dual motor setup as well. One thing that is a point of constant aggravation is the pressure gauge that comes with almost every compressor, is too darn small to read clearly. I finally went to Home Depot and picked up some flexible dryer vent hose to use with the dryer vent to exhaust my spray booth. I have the old MicroMark single fan booth which is 20x15. With the foam board I can block out the rest of the window so even on the coldest of days I can use the spray booth without freezing myself out of my hobby room. Do you have one or two ports off the back of your booth? 5
Peterpools Posted December 26, 2022 Posted December 26, 2022 21 hours ago, CANicoll said: I finally went to Home Depot and picked up some flexible dryer vent hose to use with the dryer vent to exhaust my spray booth. I have the old MicroMark single fan booth which is 20x15. With the foam board I can block out the rest of the window so even on the coldest of days I can use the spray booth without freezing myself out of my hobby room. Do you have one or two ports off the back of your booth? Chris When I was using the Artograph 1530 in my old studio, I actually just pushed the exhaust stubs right up against the window screen. After the renovation and moving into my new studio and being so much more aware of the health issues, I wanted to vent directly out the window. I think you way will work for me and this weekend, I'll hit HD and buy the flexible dryer vent hose. See how it goes 2
ScottsGT Posted December 27, 2022 Posted December 27, 2022 I used a 1’ tall piece of 3/4” ply with a dryer vent mounted in it. Also mounted lip on the outside so I can close the window down on it and it won’t fall back into the room. When the lake winds pick up I do have to pull it out since I didn’t make the lip tall enough. It has blown out of the window on me once. (Back into the house). 3
CANicoll Posted December 27, 2022 Posted December 27, 2022 This is my solution and I do the same - close the window on it. So far so good! 2 2
belugawhaleman Posted December 27, 2022 Posted December 27, 2022 On 12/25/2022 at 4:44 AM, mark31 said: Just fun That missile means business! 2 1
GazzaS Posted December 27, 2022 Posted December 27, 2022 Riveting is not riveting... if ya catch my drift... 4 3
Peterpools Posted December 27, 2022 Posted December 27, 2022 Chris and Scott Thanks Guys, I think I now have enough great ideas to build the vent the right way and keep it portable, so it's only in the window when the booth is in use. When I'm done (in a week or so) I'll post a few photos. 4
Peterpools Posted December 27, 2022 Posted December 27, 2022 Gaz Not quite sure. Is it the existing rivets are raised and the ones you just did are punched? 2
Bomber_County Posted December 27, 2022 Posted December 27, 2022 Had a tidy up on Christmas Eve………time to for some benchtime…….. 6 1
GazzaS Posted December 27, 2022 Posted December 27, 2022 8 hours ago, Peterpools said: Gaz Not quite sure. Is it the existing rivets are raised and the ones you just did are punched? No, Peter. All are recessed. Just a hole size difference. Unfortunately, rivet wheels aren't the best tool in the world to replicate rivets. 3
Peterpools Posted December 27, 2022 Posted December 27, 2022 Gaz Just hard to see, but I now understand 1
GazzaS Posted December 27, 2022 Posted December 27, 2022 50 minutes ago, Peterpools said: Gaz Just hard to see, but I now understand Hard to see indeed. Even with my glasses on, many of the rivet holes are so tiny. But to risk going over them again is an invitation to disaster. 3
Peterpools Posted December 27, 2022 Posted December 27, 2022 Gaz How right you are - sometimes it's best to leave things as they are. 2
ScottsGT Posted December 28, 2022 Posted December 28, 2022 Bench cleared, cleaned and ready for the New Year kickoff! And someone wants to be fed. 4 2 1
GazzaS Posted December 28, 2022 Posted December 28, 2022 slapping some plastic together... maybe paint tomorrow after work. Maybe not... 6
HubertB Posted December 28, 2022 Posted December 28, 2022 13 minutes ago, GazzaS said: slapping some plastic together... maybe paint tomorrow after work. Maybe not... So, it’s paint SBD (Still Be Decided) ? Hubert 3
GazzaS Posted December 28, 2022 Posted December 28, 2022 2 minutes ago, HubertB said: So, it’s paint SBD (Still Be Decided) ? Hubert Foil and paint, sir. 3 2
ScottsGT Posted December 28, 2022 Posted December 28, 2022 4 hours ago, GazzaS said: slapping some plastic together... maybe paint tomorrow after work. Maybe not... Work? What is this work thing you speak of? 3 1
Peterpools Posted December 28, 2022 Posted December 28, 2022 11 hours ago, ScottsGT said: And the goodies for it. Scott Going to be a great entry and looking to follow the whole way. 2
