  On 3/21/2024 at 2:04 AM, belugawhaleman said:
Thanks Carl.
No, I don't think using debonder will be worth the effort. Plus, I did something perhaps really stupid by spraying it with accelerator after
Trying to wipe the glue off.... It did seem to remove some glue at first before hardening into a real mess. Kind of serves me right as I was getting
frustrated and irritable trying to glue the engine screen shown in my picture.
I should have put the model aside....cooled down a bit. Instead I became
careless, an invitation for accidents. Anyway, I ordered a new kit at a good
price and I'll try again. Until then, I'll start a new kit. I'm looking at Takom's
Little G13 Swiss Hetzer.
Expand
Paul
I've had a few of those spills and even one that seemed worse. After I gather up the troops, walked away for a good few days, I went to work and fixed the mess I created. Once the CA was more then completely dry, I carefully wet sanded the entire area until it was smooth but now was a bit concave. I lightly filled in the offending sink marks with a few light layers of Tamiya White Putty, let dry between layers and gently wet sanded. Took a good few days but the repair work well and the build was saved. Give it a try and I'm sure the kit can be saved. :construction:
Mark
Looking forward to the start of the build. I normally start a build as you are, sorting through the parts, getting assemblies squared away and cleaning up the parts so when I'm ready to go, a lot of the preliminary work has already been done.
:construction:
Well, after the SMK fiasco......I started another kit build.
The Tamiya Churchill.. An ancient kit, it has required some putty
on the turret but has, so far, been a quick build.
  On 3/25/2024 at 12:59 PM, Peterpools said:
Looking mighty good and hopefully the SMK is on the back burner and scheduled for repairs down the road.
Expand
Well Peter, the replacement Takom SMK arrived today. I'm going to something a little different with this one. The most common picture
of this tank shows a clean tank; no tools, cables, or storage boxes. These
items added by Takom seem spurious... It's possible that these were added
when this tank was sent to Finland where it was disabled by a mine and
later recovered. I will however add the star decal We'll see. I'll use PVA to
add the photo-etch this time!
Thanks;
Paul
Slight progress on the Churchill build......
Road wheels (rollers?) On , and front fenders on. The fenders were a bit
tricky as there's nothing (tabs) to locate them. I would back them up with
styrene strips if I were to do it again...  Anyway,  before I go back home
for a bit this weekend, (still at Mom's) to put some paint on, I'll perhaps
start on the Friuls. One thing for sure, kit technology has come
a long way since 1974 !
  On 3/28/2024 at 6:05 AM, dodgem37 said:
1/25 Tamiya IDF Sho't Kal Gimel
Sincerely, Mark
Expand
Lovely work Mark, I see tremendous effort  placed into this build. The rear deck, armour, stowage , gun , pretty much everything seems to be altered of scratch build. Phenomenal. I would love to see more in the gallery.
Martin
  On 3/28/2024 at 4:02 PM, PeteinLincs said:
A mock up of my latest Star wars scratchbuild. Hopefully it will end up as a troop transporter.
Expand
That looks neat. For a moment, I thought the utility knife was going to be a wing of some sort.
  • Haha 3
A complete revamp. Moving around the paint racks, tool organizers and fitting a proper spray booth. Not necessarily in that order.
Most folks here would say my bench is a bit cluttered, others might call it an unmitigated disaster.
One a good day
Bench 1:
Bench 2:
Staged to assuage the pitch fork carrying members of the Tidy Bench Club:
Partway through the mods.
Paint booth in place. This invoiced taking down drywall, putting in ducts and making sure it all worked properly.
Getting there.
One a good day
Bench 1:
Bench 2:
Getting there.
Expand
I knew there was a bench there somewhere…………how long until you have 5 in progress projects on said bench……….😮😮😮😮😮😮
  • Haha 8
Looking better, Carl. Although I am not sure the TV set is going to like the paint fumes (even if there is a spray booth) in the long run ;)
Hubert, Priest of the fork- carrying Tidy Bench Church 🛠️
  • Haha 4
A bit more progress on the Churchill...
I did a little more work on finishing the turret. Used gray Surfacer to check
for flaws and did some more filling and sanding. Satisfied with it now.
Also, started putting together the friul tracks for this thing. One side--73
links. Not too bad. Some clean up on a few links. Drilling, fitting and cutting
wire for the links. I found so far two bad links. I wanted to get more done
this weekend, we'll see.
That aluminum finish is spotless .
opened the box with EW-126 and realized that Das Werk made few major errors.
this aeroplane is documented on few photos and dimensional errors as I had to fix are unacceptable. Fuselage too long, tail section all wrong, belly landing gear compartment fairing missing.
well few hours of cutting, filling and sanding and she’s getting there.
