Ryan Posted August 12, 2019 Posted August 12, 2019 Thanks guys, the cast finish is Model Air aluminum dry brushed over black. Iām cleaning up all the excess dry brush at this stage and defining the black portions of the engine. 4
DocRob Posted August 12, 2019 Posted August 12, 2019 11 hours ago, Ryan said: Sprinkled some Nats enthusiasm on myself and picked up my previously started 152. Nice, the engine is looking great. Will you show it? I tried to do my 152 with the cowlings removable and stalled with that after trying different variants. Be careful with the engine mounts assembly, when everything has to be glued into the wing/fuselage section. As per manual this is nearly impossible due to multi dimensional mounting points. Some more details about this are in my build log Cheers Rob 3
Ryan Posted August 12, 2019 Posted August 12, 2019 Rob, thanks so much for the link. I plan to show the engine and the other open features, well maybe not the tail, we will see. 4
Ryan Posted August 12, 2019 Posted August 12, 2019 Got some more detail painting done today.Ā Plug wires, shiny pipe work and in general refinement. Ā 6
BlrwestSiR Posted August 13, 2019 Posted August 13, 2019 On 8/11/2019 at 8:42 AM, DocRob said: Hopefully to be continued... Cheers Rob Thanks Rob! This one made it over the finish line. Although it took a couple tries on the weathering.Ā 7
BlrwestSiR Posted August 13, 2019 Posted August 13, 2019 2 hours ago, Ryan said: Got some more detail painting done today.Ā Plug wires, shiny pipe work and in general refinement Really nice work on the engine Ryan.Ā So hard to make black not look stark.Ā Carl 3
Ryan Posted August 13, 2019 Posted August 13, 2019 Yes your right, the final clears should even things out. Brush painting Model Air is really the way to go,Ā everything here is model air except the wash. MA isĀ a bit translucent, but lays on smooth. Clear coats should hide the uneven finish in the black. I hate using straight black, but I was able to switch back and forth when I made mistakes. The MA made it easy to fix errant brush strokes and there were plenty! Ā Ā 5
Ryan Posted August 13, 2019 Posted August 13, 2019 13 minutes ago, BlrwestSiR said: Thanks Rob! This one made it over the finish line. Although it took a couple tries on the weathering.Ā This is awesome Carl, never built a Corsair. 3 1
BlrwestSiR Posted August 13, 2019 Posted August 13, 2019 Most of you know I've got a car that pretty much qualifies as an LSM... After 12 years of ownership, I felt it was due for a timing belt change. Now I know why most garages wouldn't touch it.Ā Got some great help from a good friend and my neighbour too but it looks like it'll be a two day job as the crank pulley is stuck on tight. No more mid engine cars for meĀ Carl 4
harv Posted August 13, 2019 Posted August 13, 2019 Your really need to build one Ryan. It's an awesome kit. And Carl, where is your other skate ??.......harv 5
BlrwestSiR Posted August 13, 2019 Posted August 13, 2019 16 minutes ago, harv said: Your really need to build one Ryan. It's an awesome kit. And Carl, where is your other skate ??.......harv Ryan, I'm with Harv. It's probably Tamiya's best 1/32 kit.Ā Harv, I have to get this one fixed first before I worry about finding the other skateĀ 5
DocRob Posted August 13, 2019 Posted August 13, 2019 7 hours ago, BlrwestSiR said: Thanks Rob! This one made it over the finish line. Although it took a couple tries on the weathering. Wow, what a nice Birdcage. I like your subtle weathering and I imagine, that this is the most of weathering you ever did on a kitĀ . The kit itself is a true beauty, I built one myself years ago and because I left it in Berlin with a friend when I moved to Spain, I'm considering building another. If there is something like the best kit ever, these Tamiya F4's are pretty close and the earlier two or tri tone camos are a great canvas for weathering experiments on an airframe.Ā BTW, the ZM 152 is not on my personal list of top toĀ build kitsĀ . Cheers Rob 5
DocRob Posted August 13, 2019 Posted August 13, 2019 9 hours ago, Ryan said: Got some more detail painting done today. Your engine is looking great and will be a nice eye catcher on your 152. Like you I'm hardly ever use a real black for modeling, but my attempts using MA with a brush where not very successful. Are you planning a WIP? Cheers Rob 5
Ryan Posted August 13, 2019 Posted August 13, 2019 1 hour ago, DocRob said: Your engine is looking great and will be a nice eye catcher on your 152. Like you I'm hardly ever use a real black for modeling, but my attempts using MA with a brush where not very successful. Are you planning a WIP? Cheers Rob Thanks Rob, I probably should do a WIP. Ā 4
Martinnfb Posted August 13, 2019 Author Posted August 13, 2019 14 hours ago, BlrwestSiR said: Most of you know I've got a car that pretty much qualifies as an LSM... After 12 years of ownership, I felt it was due for a timing belt change. Now I know why most garages wouldn't touch it.Ā Got some great help from a good friend and my neighbour too but it looks like it'll be a two day job as the crank pulley is stuck on tight. No more mid engine cars for meĀ Carl Those jack stands are huge Ā 3
BlrwestSiR Posted August 14, 2019 Posted August 14, 2019 9 hours ago, Martinnfb said: Those jack stands are huge Ā They're 1 1/2 ton jack stands. The car is half that.Ā Maybe.Ā Ā With two passengers.Ā Ā And a dog. 3
1to1scale Posted August 14, 2019 Posted August 14, 2019 I am proud to announce my bench is clean and mostly organized, now the rest of my office needs the same. 6
1to1scale Posted August 14, 2019 Posted August 14, 2019 Bench clean for a couple hours, already have a new project sitting on it. Starting on the D-day group build. 6
