brahman104 Posted July 5, 2021 Share Posted July 5, 2021 Ye gods!!!!!!!!!!!!!!!!! I've literally just found this thread and holy crap am I impressed! I need to go through this is slow time and try to get my head around this amazing work! Craig 1 Link to comment Share on other sites More sharing options...
Fidd88 Posted July 5, 2021 Author Share Posted July 5, 2021 Crikey, my thanks, that's just made my day! It's nothing most people couldn't do. I taught myself to use Fusion 360 CAD early on, which allowed me to send .stl files to 3dprintuk, who then sent the "bits" back in the post. I then discovered that SLS Nylon, was both dimensionally very accurate, and crucially, could be tapped with threads down to M1 threads, allowing sub-assemblies to be screwed together, rather than glued. This has two benefits, it allowed for more efficient "nesting" of parts, which reduced the cost of printing larger parts, but it also allowed for the reversal of assembly if I got into a jam with the build sequence. This turned out to be vital, as in effect, it was akin to building a real turret, but with "4 foot long" screw-drivers, so tool access was a major consideration in the sequence of the build. Other than that, building them was fairly straight-forwards, other than making the compound-curved perspex panels for the cupola, to get the true shape of it. The other related problem was learning to draw compound curves in CAD, which was tricky. This meant that certain features such as the chordal brace stiffeners and the ammo feed-chutes were repeatedly drawn until they were got right. I never really managed it with the chordal brace stiffeners - the green structure that goes from the arch to the top of the main supporting silver side-piece of the turret. Fusion 360 can still be downloaded and learned for free, although with some functionality unavailable. Have a go! It takes around 2 months of practice and working through tutorials to get quick and accurate with it, and maybe another two months to really master compound curves. There's a very helpful set of forums if something defeats you... If there's anything you want to know more about, just sing out. My Youtube channel which has multiple films documenting the build can be found by searching YT for "Fidd88". I fear I'm no David Lean, and some are pretty dull, being made more to remind me than for public consumption, but some are interesting. 4 Link to comment Share on other sites More sharing options...
Fidd88 Posted July 8, 2021 Author Share Posted July 8, 2021 Hi all, Lots of recent practice flying my little foam E-flite "Apprentice" - basically a Cessna 150/172 style high-wing monoplane, but with no operable flaps, undercart or variable-pitch prop. It has a wing-span of around 5 feet, and all the modern bells and whistles in the form of gyros, "panic buttons" and so forth that make learning so much easier these days. I've been flying 2-3 times a week, and can fly and land it even in strong gusty wind conditions without breaking anything although once in a while I have to throw an approach away rather than trying to rescue an approach that's gone pear-shaped. This is mainly because the landing patch is only half the size of a tennis-court, with high uncut grass of 3+ feet all around, so "landing long" just isn't an option. It's not unusual to hear a little whisper as the wings ever so lightly brush the tops of the high grass in the undershoot! Now that I've cracked landings, both into and cross-wind, I'm now conducting low and slow manouevering flights to really work on rudder and aileron coordination and accurate trimming before I start to look around for more complex model. At the moment I'm getting 10-12 minutes a flight, and reckon I should manage 14 minutes before the battery gets to 50%, if I don't hammer the throttle too much. Brilliant fun, but I need to get back in the workshop! 2 Link to comment Share on other sites More sharing options...
Fidd88 Posted September 13, 2021 Author Share Posted September 13, 2021 Hi all, The last few weeks have been busy on the RC flying side. I've done over 100 hours on the "Apprentice" with only one crash. I'd been getting more confident and doing aerobatics, and forgot to switch the control-defelection from high-rate to low rate before landing, which would give fine control instead of the rapid inputs required for aeros. I'd made a pig's ear of the approach and so went around in the normal way, however because of the rate still being high, the aircraft went suddenly vertical at about 15 feet, before executing a very pretty power-on spin-entry - and then ploughing into the ground. The engine-mount, fuselage and tail all suffered damage. After a couple of weeks I've replaced and repaired all the damage, and should be ready to re-maiden it tomorrow. I've also been building a Dynam Hawker Hurricane, which has flaps, retractable undercart, and should presently be able to carry a gimble mounted FPV camera. I'm getting some stencils made to paint all the roundels, (rather that using the stickers) and will be converting the insignia and letters to that of a 303 Sqn example. I've also added yellow prop tips to the 3 bladed prop, and will add "oil-leaks" and other weathering. Pics to follow in due course. 6 Link to comment Share on other sites More sharing options...
Bomber_County Posted October 13, 2021 Share Posted October 13, 2021 Did you join the BMFA as they have levels to achieve for insurance, clubs etc……. Link to comment Share on other sites More sharing options...
Fidd88 Posted October 13, 2021 Author Share Posted October 13, 2021 Yes, I'm a member of the BMFA for my regular RX flying, but also of the LMA as the Wellington project is a much bigger airframe than they deal with, so I'm also a member of the LMA for design scrutineering for that project. We had a phenomenally busy Club Night here, with some 20 pilots turning up for flying - likely one of the last Wed Evenings that'll be flyable until the other side of Winter now, so everyone was having a last flit. I'll still be flying on the weekends, MET permitting. I need to get on with getting the Hurricane airworthy now, and start learning about FPV flight once I've got the measure of LOS (line of sight) flying the model in the normal way. This evening I drew up the proper exhaust stacks for the Hurricane - Dynam supplied me with ones for a later marque of Hurricane/Spitfire with the 6 stacks a side, rather than 3 (doubled) with the "fish-tail" end section. Not easy to draw. Pics to follow when printed and fitted. I need to buy a new TX, and a Crossfire unit for extended range, which should make the control connection to the TX bomb-proof at the ranges I'll be flying. It also bumps the video reception range to well over 4km without drop-outs. Being Digital video it lacks the extreme range of the older analogue jobs, but it's not legal to fly FPV beyond line of sight in this country, so much more than 1km isn't needed for this size of model. So my possibly erroneous understanding has established. Probably! By the by, I came across an very interesting youtube channel of a Texan model-maker, working in metal, who is currently producing a series of model metal-working machines - lathes etc. Amazing stuff, as it all works! I'd love to gave a small watch-maker's lathe/mill but there's no way I can afford it as well as other tools and materials I know I need for the Wellington. See: 1 Link to comment Share on other sites More sharing options...
Fidd88 Posted October 24, 2021 Author Share Posted October 24, 2021 So lots of time in the workshop recently re-painting the Hurricane from it's factory colours, with a deeper shade of duck-egg blue and dark earth/dark green with Alclad paints. Still to do is all the insignia which will be airbrushed rather than using the bloody horrible stickers that came with it, before finally applying (after a suitable test on polystyrene) of the Alclad gloss varnish (metal areas of the airframe) and Alclad matt varnish for the "fabric" covered parts. After which the weathering/oil-stains etc can be done. I've also bit the bullet and purchased a Tx16 transmitter, and will shortly by a crossfire unit for extended range. For now, the kit canopy will be used, but that will be replaced with an optically clear one for FPV flight in the Spring. The proper "Fishtail" exhausts have been 3d printed but are yet to arrive. Contrast this picture with the stock image above. I think it's an improvement so far! 2 Link to comment Share on other sites More sharing options...
Fidd88 Posted October 30, 2021 Author Share Posted October 30, 2021 So had an enjoyable 3 flights today with the "Apprentice" after spending the last few days finishing the painting of the 303 Sqn. Nowhere close to your standards for such a big model but like decorating the house the "4 foot rule" applies! (if u can't see a blemish in the paintwork, it's a "pigment of the imagination"! 1 Link to comment Share on other sites More sharing options...
Fidd88 Posted October 31, 2021 Author Share Posted October 31, 2021 And here's a couple of pics of the completed model. The paper tag on the prop is to remind me to address some problems with the clevises before flying it! The stained and holed jumper is my "workshop jumper"! 7 1 Link to comment Share on other sites More sharing options...
GusMac Posted October 31, 2021 Share Posted October 31, 2021 Looking really good. Glad to see someone else who keeps their best clothes for modelling! 😁 I'm sure my wife would love to throw out half of the clothes in my cupboard. 1 4 Link to comment Share on other sites More sharing options...
Fidd88 Posted November 4, 2021 Author Share Posted November 4, 2021 Here's a couple more stills. All markings done with multiple stencils to "build up" the eventual roundel etc, oil paint pin-wash and "metal" distressing of panels frequently removed for servicing or rearmament. 4 1 Link to comment Share on other sites More sharing options...
harv Posted November 4, 2021 Share Posted November 4, 2021 ......harv 2 1 Link to comment Share on other sites More sharing options...
Fidd88 Posted November 4, 2021 Author Share Posted November 4, 2021 Cheers. When I move from line of sight flight to FPV (first person view via real time video transmision from a pannable/tiltable camera, I'll replace the current canopy with a 3d printed one capable of opening in the normal manner, with optically clear window panels. The current one is far from optically clear, and is therefore no good for FPV flight. Many FPV pilots of warbirds simply omit the window panels but keep the superstructure of the canopy. I'd prefer to avoid that if possible. 3 Link to comment Share on other sites More sharing options...
Fidd88 Posted December 9, 2021 Author Share Posted December 9, 2021 Hi all, Lots happening "behind the scenes" lately. I've been assisting - with advice and some CAD files- a chap modelling an FN5a (lanc nose turret) model in circa 1/6th scale, in the hope he can side-step some of the traps I fell into making mine. Usual problems connected with extant drawings being incorrect geometrically, and lack of plans. If I get his permission, I'll post the results of his work here. Additionally I've bought a Radiomaster TX16s transmitter, and equipped the switches with pretty colour coded plastic gaiters to make it look as if I know what I'm doing. In truth it's because I'm getting a bit senile and despite my models not needing a tenth of the number of switches with which this beast is equipped, it should reduce the frequency with which I select "undercart up" only to see the nav-lights come on instead, when I have a "senior moment"! I can't get to grips with programming the transmitter, which by all accounts is less fun than root-canal, owing to the battery being on back order since God was a boy. I am looking forward to that. The clevises on the Hurricane cannot be replaced as those appear to have been lost in transit. Bugger. That's okay though as it's far too windy and generally unflyable, and the workshop, currently, is colder than a witch's tit, so not conducive to spending time there. It has a heater which turns money into noise, but does not appreciably warm it up. Am still leaning about FPV. Just as I get the hang of it, some new protocol, camera or widget comes out, rendering all previously hard-won insights into this arcane branch of modelling irrelevant, and the incantations begin again! Naturally the newly named winter storms have been battering us. Usual attrition of fence-panels, and fun-filled evenings trying to get them back the house from 8 miles away inexpertly lashed-down on the roof-rack at 20mph lest it fly off. God I hate winter. At least this time I had the presence of mind to store it in the workshop, nice and dry, instead of what happened last year when it got wet, swelled and had to be planed to get it to fit in the slots in the concrete posts. Those of you who have had to plane wet wood will understand my reluctance to play that game again any time soon! It's enough to even make one take up plastic kit modelling, so it is. 🤯 1 1 Link to comment Share on other sites More sharing options...
GusMac Posted December 10, 2021 Share Posted December 10, 2021 Yes, flying fences have been prolific up here as well. Closely followed by the flying trampoline tally. Has no-one heard of staking the damn things down! 2 1 Link to comment Share on other sites More sharing options...
Peterpools Posted December 10, 2021 Share Posted December 10, 2021 Amazing work Keep 'em comin Peter 2 Link to comment Share on other sites More sharing options...
Fidd88 Posted December 10, 2021 Author Share Posted December 10, 2021 23 minutes ago, Peterpools said: Amazing work Keep 'em comin Peter Cheers, nice to hear from you in NY, as a nipper I lived in Westchester County for a few years, at "Waccabuc" - Dad and his legion of unpaid and bonded kids - restored a very large clap-board house from the 1880's, which when we bought it was held together by the holes the wood-worms had left! The name "Pound ridge" rings a bell in that area, is that where you're from? 2 Link to comment Share on other sites More sharing options...
Fidd88 Posted January 5, 2022 Author Share Posted January 5, 2022 As the weather isn't flyable just now, I turned to converting the box my TX16S transmitter came with, into a carry-case, using seat-belt material, a hot-glue gun, and cutting up one of the two neck-straps the transmitter the transmitter came with. You can buy "proper" Radiomaster cases, but I prefer mine as it's a bit stronger v crushing loads, but perhaps less protective to being dropped. I shall strive mightily not to drop an hundred and sixty quid transmitter! It worked well, with the hot-glue gun providing a very strong bond to the seat-belt material, and it looks fairly smart if one can overlook some over-enthusiastic use of said glue-gun! I've had a crash course in using it, and now have Edge Tx rather than Open Tx loaded, which means all the touch-screen works. Loud cheers! The Hurricane is stall waiting for a mate to 3d print a part, but has had some additional weathering paint applied, so now looks suitably battered and less "foamy"! Still waiting on a bunch of parts to make the detachable portion of the upper fuselage and cupola. The intention is to make one as suitable for 3rd person flight, and the other for FPV, so I can later elect to alternate between the two modes of flight. One will have PO Pruneski, my plastics pilot figure in the cockpit, the other will have the gimballed camera, and all the perspex cut away to just leave the framework. I may in time detail the cockpit on the FPV one. Still working on the Wellington geodetics, have now figured out 4 different ways of producing the curved geodetic channel, so now it's a matter of picking the right method, with least risk of failure in flight or manufacture, and what I can afford... Anyway, that's recent progress. I know all this is moving away from the normal posts here, but I figured I'd keep all my posts in one place! I will come back to the more mainstream modelling in due course, interspersed, I hope with some footage of flight. Link to comment Share on other sites More sharing options...
Fidd88 Posted February 14, 2022 Author Share Posted February 14, 2022 More filthy flying weather here in England. I've set out thrice for the field in recent day, only to turn back as I run into persistent rain/drizzle 5 miles from my house. There's a peculiar local weather-system whereby relatively warm humid air comes up the Severn estuary and turns to very low oragraphic cloud over the Cotswolds (hills), dumping continuous rain. It's one of the things that always amuses me about Bristol Airport, it was a WW2 airfield especially chosen for training pilots, as it has the most reliably bad weather anywhere in the UK. And now it's a commercial airfield! You literally couldn't pick a worse place for an airfield! Anyway, I've been grounded as a consequence. 😢 I've been fighting with the electronics on the Hurricane, which is an exercise in nailing jelly to the ceiling. The transmitter has hundreds of settings in the software, and switches etc, and there are dozens of wires and jacks on the model. If anything is not quite right it doesn't work as advertised. I had an "event" where the prop suddenly span-up as it sat on the workbench, uncommanded. Fortunately I had a hand to the leading-edge and was able to arrest it's progress before the prop' hit the vice at the end of the bench, only just because it took off across the bench like a scalded-cat! Somewhat chastened by that, I've been building a foldable carriage for models, which means I can work on them at bench height at the field, instead of bending down to do so. This has provision for the tail to secured in place by velcro tabs, so next time the prop' develops a mind of it's own, it'll not be frightening the life out of me! Pics to follow. In the meantime please join me in making all manner of rash promises to the weather-Gods in order that I can get airborne again! Link to comment Share on other sites More sharing options...
Fidd88 Posted February 25, 2022 Author Share Posted February 25, 2022 Hi all, The last few weeks have been "a game of two halves" as we say here. The first half is continued strife with the electronics in the Hurricane, but as yesterday was the first time I managed to go flying the RC "Apprentice" foamie, the 2nd half looks to be improving after being grounded for well over 5 weeks now. I was climbing the walls! It was, it must be said, a bit of a silly day. The wind at surface level was 35-45 knots or so, and bitterly, bitterly cold. I'd gone dressed with my heavy Royal Navy submariner's jumper, and a heavy hooded duffle-coat, and even then was only just barely warm-enough, The flying was "lively" to say the least, with the model geostationary at 70% throttle S+L heading upwind, extreme turbulance from the trees in some places, and a really marked wind-gradient whereby the wind at 300' was a good 20 knots faster. Approaches had to be flat at 8 feet or so, so as not to find oneself going backwards on finals! It was nevertheless some much needed and highly entertaining flying, especially climbing up to 300' way upwind, then turning the aircraft back towards me, which of course rendered some epic ground-speeds! And so home for hot-coffee in the workshop thawing out in the workshop and recharging batteries. Good fun. Silly, and unwise, but good fun! I've finally sourced some appropriate electronic jacks, so I can now shorten some of the sillier overlong cables in the Hurricane, and so reduce the rats-nest of cabling required to be stuffed out of the way. But first I need to get it all working properly. The new folding support for assembling the aircraft at bench-height at the airfield worked fairly well. Needs a few adjustments such as a container to put batteries, leads, and rubber-bands in, but otherwise is there. Pic to follow, I'm quite pleased with it, as when it's folded flat in the boot of my car, it also functions to prevent the model being damaged by movement as the car goes around bends etc. I hope all your projects are going well. I've been helping a few lads with various turrets, and hope to do some remedial work on mine shortly. I want to get rid of the twisted fabric covered wire which holds other wiring to parts of the turret, and will use very thin strips of very thin lead instead, painted to resemble electrical tape, and see if I can get all the lights and lamps/gunsights working properly! 2 Link to comment Share on other sites More sharing options...
Fidd88 Posted March 5, 2022 Author Share Posted March 5, 2022 Hi all, I'm absolutely elated here. Chuffed to bits. There's been a "show-stopper" on the Wellington build for the last year almost, which has completely stymied further progress. In the standard geodetic joint, which occurs all over the airframe, there are two butterfly-shaped fittings in the middle of the joint. I'd looked into having these produced by a CNC milling-machine, and that proved madly expensive, even from China. You can see the joints here: Making these as a 3d shape, came out at over $16.000! I then looked into casting them, but for the numbers I need, and the amount of post-casting work it was not feasible either. Last night I realised that if I extruded the basic shape, but made it wider than it needed to be, then the "rail" could be secured to a CNC table without difficulty, and if the shapes were partially cut out, leaving 1mm thick tabs to keep the parts oriented properly, I could then drill the two holes in the "wings" of the butterfly. The parts could then be removed from the stock, cleaned up and then the final hole through the middle can be drilled whilst they are clamped in a jig. So theoretically, that should be much cheaper to make, as there's only a single CNC milling tool-path, rather than the multiple paths required for the $16,000 method. So I'm really pleased about that, as it's the final problem now solved before the build can commence. 2 Link to comment Share on other sites More sharing options...
Fidd88 Posted March 11, 2022 Author Share Posted March 11, 2022 Lads, there's something that foxing me a bit at the moment. On the square "checker-board" Polish insignia, as painted on the starboard nose a few posts above (or on the preceding page of posts) I've seen examples on film, on the internet and so forth oriented both so that the red squares on the marking are NE/SW as well as NW/SE. Can anyone cast light on why this is, and which do you consider correct? Was there, for example, a rule that has the marking in one orientation on the starboard side, and a different one on the port?? I'd really be grateful for a definitive answer here.... Link to comment Share on other sites More sharing options...
Fidd88 Posted August 30, 2023 Author Share Posted August 30, 2023 For any readers of this old thread, my apologies for the malfunctioning links to youtube films. Either my account was hacked, or it was cancelled by Google, I couldn't get a straight answer out of them as to what had happened. So none of the films are now available. 2 4 Link to comment Share on other sites More sharing options...
KevinM Posted September 3, 2023 Share Posted September 3, 2023 On 8/30/2023 at 12:25 PM, Fidd88 said: Either my account was hacked, or it was cancelled by Google, I couldn't get a straight answer out of them as to what had happened. So none of the films are now available. That is typical of YT these days it seems. Link to comment Share on other sites More sharing options...
FME erk Posted September 7, 2023 Share Posted September 7, 2023 I certainly miss your updates on the Wimpy but I guess you have to learn how to fly by going from single to twin engines flying . . . . Keep at it, I think you've got something there . . . . 1 Link to comment Share on other sites More sharing options...
