Weathering is about done. The engine won't be sticking out this much. Still need to apply a super diluted black tone and make everything flat. I will loose some of the chipping effects in the process.
  • Like 13
  • Thanks 3
Oliver
There have been parts of your build I couldn't find the words to describe your work and this is another one - simply brilliant execution and the bar has been raised to a new level.
Exhaust painted . I was hoping to add the engine at the end of the build but it's not possible. I need to add few brass rods to support the engine.  This is dry fitted. StilL need to add all the wiring.  I may need to paint the orange paint around the edges to minize the masking.
it looks crooked in the photo( engine)
  • Thanks 3
2 hours ago, harv said:
Yes please....harv
Primed in light grey first then a light coat of  flat brown,spray flat white on top of exhaust  only to duplicate light accent. ( this will help lighten the brown a bit for your second coat)
Nato black in recess area only, second coat of flat brown then first coat of Red brown....let that dry several hours and add flat white to your Red brown to do more light accent on top then mix Clear Orange and orange and spray close to the exhausts end to simulate some variation of heat in the exhausts. Let that dry overnight then dry brush with flat brown mixed white (oil paint).
I will spray  one coat only of nato black ( highly diluted  90/10)all over the piece then spray thin coats of flat finish.
I hope this helps
oliver
  • Thanks 3
