harv Posted July 2, 2020 Author Posted July 2, 2020 Martin, does it look that bad ? Let me know....harv 4
Wumm Posted July 2, 2020 Posted July 2, 2020 It looks a little out of alignment... But the barrel extending from the wing is straight, which is more important. The internal wheel bay details will hardly be seen. S 4 1
harv Posted July 2, 2020 Author Posted July 2, 2020 Yes, not straight. Nothing glued. Had a hard time laying it straight without glue. But it does sit straight....harv 5
Martinnfb Posted July 2, 2020 Posted July 2, 2020 Brutal. Bunch of plastic and tapes, annoys the hell out of me, LOL As I said pipe in pipe in pipe, nice stack up that keeps everything safe and strait. The mantel can be another thicker piece of tubing with some bolts on it. You know me Harvey, I will push you. 4 1 2
harv Posted July 4, 2020 Author Posted July 4, 2020 Well, does this look better Martin ?.....harv 7 1
harv Posted July 16, 2020 Author Posted July 16, 2020 So, should I use the whole QB gun, or put the brass barbells on the resin base ??.......harv 5 1
Wumm Posted July 16, 2020 Posted July 16, 2020 If I had the brass option, I'd graft them on Harv... S 3 1
Martinnfb Posted July 16, 2020 Posted July 16, 2020 It doesn't matter what I think you build it your way Harvey. This is like a Face Book's darkest chapter. 2 1
Wumm Posted July 16, 2020 Posted July 16, 2020 35 minutes ago, Martinnfb said: It doesn't matter what I think you build it your way Harvey. Then add a camera pod on an outer wing ETC rack, and call it ice build-up! 1 4
BlrwestSiR Posted July 17, 2020 Posted July 17, 2020 5 hours ago, Wumm said: If I had the brass option, I'd graft them on Harv... S Me too. The resin barrels tend to be fairly fragile from my experience. 4
DocRob Posted July 17, 2020 Posted July 17, 2020 If there's both, I choose brass, because I like to burnish it which leads to a very realistic Colour and appearance, better than paint and it's more rigid, specially on long protruding 20mm's. Cheers Rob 6 1
harv Posted August 13, 2020 Author Posted August 13, 2020 Ok, life has had me away from the bench. Working on the IP with 3 different Eduards sets. One set has imaginary toggle switches. So picking through for best color and instrument printing. So far, all I have done......harv 5 1
harv Posted August 16, 2020 Author Posted August 16, 2020 Small update. No knobs or levers yet.......harv 9
BlrwestSiR Posted August 16, 2020 Posted August 16, 2020 Looks good there Harv. Interesting that the Eduard panels are so different from each other. 2 1
harv Posted August 16, 2020 Author Posted August 16, 2020 Yes, I was surprised also. In fact, 2 of them are identical sets. The other was just IP and had separate bezels and dials were switched around....harv 3 1
harv Posted August 20, 2020 Author Posted August 20, 2020 Squirted som 66 today. Also 1/2 of a shoulder harness. All my eyes could take today !....harv 7
BlrwestSiR Posted August 20, 2020 Posted August 20, 2020 Nice work on the seatbelt Harv. Fussy little things aren't they? 2 1 1
