BlrwestSiR Posted January 9, 2021 Posted January 9, 2021 Ok, I started this two days ago as a low stress, no AM, OOB build. There's not a lot of parts, fit seems to be really good, no serious controversies around the camo/markings since they're fictitious. Easy peasy. 7 1
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 Ok, first step is.... ...the cockpit. No big surprise. The way Miniart engineered it is interesting. The tub is split into upper and lover halves with the upper half holding the side panels. The two parts test fit together. The seat is next. The instructions tell you to assemble the seat, then attach it to the armoured backrest. the seat bottom is keyed to fit into the floor so if you don't get them aligned correctly, that could be a problem. I ended up sliding the backrest in first and then gluing the seat together in place. 5
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 I then painted everything RLM66. Or at least that's what it said on the bottle. Looks green to me. Anyways, I then did the IP bassackwards. I painted it RLM66, then applied the decals. At which point I noticed that the panel around the instruments should be black. So I then painted the black. I added a couple Airscale placards to the panel to add some details. The PE seatbelts were next and then the cockpit was done. There might have been a control sticks and pedals added at some point but I don't have pics. Edit: here they are. 9 1
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 The front fuselage halves were then joined together and same for the rear fuselage halves. The rear is empty so simple enough. Then I assembled the rotatey-spinny bit. It's not mentioned in the instructions but there is a way for the wings to be geared together so they pivot at the same time. I may try it on a future build if I decide to get another one. 6
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 3 minutes ago, Martinnfb said: Looks like a fun build , I like it. Just now, harv said: Looking g good ! Tasty little build.....harv Thanks Martin and Harv. I am having fun with it. One of the versions of the kit even has Hydra markings in from the first Captain America movie. I'm still trying to decide what to use. 6
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 Here's the fuselage sections. The front and rear slot into each other. With the centre ring installed: No glue is needed to hold everything together which is nice and the centre ring can rotate. 6
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 Onto the wings. Again, not a lot of parts, mostly the rocket/scramjet bits in the wingtips. I painted the insides in dark iron then gave them a dry brushing with some Tamiya weathering master sets. I mostly used light gunmetal followed by a bit of burnt blue. It won't really be seen so I didn't go crazy. I glued the halves together and they're just drying at the moment. That's where I am as of now. So far so good. 9
harv Posted January 9, 2021 Posted January 9, 2021 Gee, only an hour and it's almost done !.....harv 1 2
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 43 minutes ago, harv said: Gee, only an hour and it's almost done !.....harv No kidding eh? 14
DocRob Posted January 9, 2021 Posted January 9, 2021 Nice and easy project, no rivet picking and the colour for the cockpit was misread by you, it's RLM 166, that's what 'what if' does to you . Cheers Rob 4 1
Bomber_County Posted January 9, 2021 Posted January 9, 2021 Carl, that was damn quick, perhaps we could all do with a quick build pick me up...... 3 1
BlrwestSiR Posted January 9, 2021 Author Posted January 9, 2021 Thanks Phil and Rob! RLM166 it is! I know there's a few folks on here who will build a Hasegawa kit as a refresh/palate cleanser but oddly enough I've yet to have a 1/32 Hasegawa kit go together that easily. 4
DocRob Posted January 9, 2021 Posted January 9, 2021 5 minutes ago, BlrwestSiR said: I know there's a few folks on here who will build a Hasegawa kit as a refresh/palate cleanser but oddly enough I've yet to have a 1/32 Hasegawa kit go together that easily. I built their Raiden some years ago, my only Hasegawa build until yet, but it went together like a breeze. It built up almost by itself with me concentrating on painting and weathering. Was almost to easy to build without PE and resin . edit: Forgot, that I built the P-47D in Eduard outfit as Dottie Mae. A good kit too, but needed some extra work on the cowl and in the pit. Cheers Rob 4 1
Kaireckstadt Posted January 9, 2021 Posted January 9, 2021 1 hour ago, Bomber_County said: Carl, that was damn quick, perhaps we could all do with a quick build pick me up...... Amazing how fast you are building this model. And it looks beautiful! I only manage one to two per year. Can I send some of mine to you for a quick build? 1 3
BlrwestSiR Posted January 12, 2021 Author Posted January 12, 2021 Thanks folks! It's been a bit crazy at work so I haven't had as much time at the bench. I finally had some free time so started on the paint. I filled in a couple small seams and sanded them back. I decided to give Jeroen's shading technique a try on the bare plastic. After all if it doesn't work out who's going to say it's inaccurate? The shape of the fuselage really makes me want to put a shark mouth on it. We'll see if I can find something suitable. Carl 5
BlrwestSiR Posted January 12, 2021 Author Posted January 12, 2021 Here's the lower camo colour done. 8
Administrators Fran Posted January 13, 2021 Administrators Posted January 13, 2021 I always loved the F.W. Triebflugel!! I have made in 1:72 Huma Model one but this in 1:35 is on my wihlist! 2 1
BlrwestSiR Posted January 13, 2021 Author Posted January 13, 2021 3 hours ago, Fran said: I always loved the F.W. Triebflugel!! I have made in 1:72 Huma Model one but this in 1:35 is on my wihlist! Fran, it's been a a great kit so far. The fit has been great and same with the engineering. 3
belugawhaleman Posted January 13, 2021 Posted January 13, 2021 looks like a well-engineered kit,and a fun build. I'll be watching. 2 1
BlrwestSiR Posted January 14, 2021 Author Posted January 14, 2021 I got the wings painted last night. I started with the light grey/blue. I then added the green to the outer edges. Then the burner can sections were masked off and I sprayed those in AK titanium. 6
BlrwestSiR Posted January 14, 2021 Author Posted January 14, 2021 I got the green onto the fuselage today. First I attached the canopy, masked it and sprayed the inside colour. Then I did the primary colour coat. I forgot to post a pic of the engine burners that I did yesterday so here it is. Quick test fit to see how the camo works together. 7
DocRob Posted January 14, 2021 Posted January 14, 2021 That weird thing looks fantastic with your paintjob, keep rolling. Cheers Rob 2 1
