The big three Mustang kitmakers
Zoukei-Mura
Revell of Germany,
Tamiya F-51
We’re looking them over, building all three at the same time, documenting the good, the bad, and the ugly. And there’s much of the first, and a bit of the other two.
Any guesses which one comes out on top?
The results will surprise you.  I’m not a panels open guy, I don’t like toylike features, and I like having both tails  All three manage to pick my butt at times
  • Like 12
What will be your judging criteria? Accuracy? Level of detail? Value? I look forward to seeing your results - I have two of the three in the stash.
I really hope you meant to write 'kick'...
S
  • Haha 4
  • Confused 1
What's the focus and who are 'we'? Interesting to see the detailed outcome. I have the ZM MK.IV boxing and hope for a trouble less buttoned up build soon.
A. Uract, to me, is in the eye of the beer holder.  All three kits have been praised for their accuracy, but there ARE differences, mostly with the stuff under the skin.
I didn’t have good luck with the fit of the Revell kit parts.  Scoop, interior structure was too wide and I had to sand it down to fit inside the fuselage.  Bad gaps on wing parts, etc...
  • Sad 1
ZM Mustang is hard no for me, lacking the mental strength :)
Still excited to see how it's going to build up.
  • Haha 6
I took specific care with the Revell by sanding the internal structure to the point of where I had to shim it up to fit the joined halves. Just like doing a resin kit. I was able to keep close clearances with the fit of the wing and scoop that way.
I did use a Yahu panel on the Revell, simply because I had one and wanted to try it.
So far so good for all.
21 minutes ago, Clunkmeister said:
ZM is impressing me.
Revell is astonishing me.
Tamiya is making me scratch my head.
Interesting to read that.
I've only built the Dragon P-51 so will be curious to see more of this.
That is surprising...
Because the Revell Fw-190 kit to me is a real head-scratcher. Wish Tamiya would do one...
S
