On 10/12/2021 at 3:35 AM, JohnB said:
Coming along very nicely Gaz!!! :)
On 10/12/2021 at 6:00 AM, Kaireckstadt said:
Copy John Gary. This one will be awesome when ready!
30 minutes ago, Martinnfb said:
Lovely detail.
Thank you, fellas.  Hope to get some done this weekend.
Hello again, everybody.  A bit of progress on the Marder.  With only a few detail parts to add on, I thought I'd show you how she looks partly painted...  and paired with a Tamiya Panther for size comparison.
The track assembly with wheels is only dry fitted as is the gun and shield.  That leaves the seats, travel-lock, and periscopes left to go.
I'd like to have some storage, but I'm not really liking the idea of messing with it.  The main reason is the tarp latches.  In just a few minutes of adding parts, three of them came off.  I should have deepened the holes with a drill...   but didn't as I was afraid of going through....   with a touch of laziness thrown in.
So, next time you see it, it should have it's three color scheme.
...photo-etch and the fragility of CA really makes me leery of trying too much.
Happy modelling!
...  a few hours and a few hundred epithets later....
I had a lot of trouble with dry tip.  Especially with the red brown and to a lessor extent the green.  I had to sand some overspray away and touch up with the base color.  Anyway...  it can have a rest.
Gaz
Cammo work looks spot on and perfectly done. Thanks for the size comparison pics as the difference in size between the Mardar and the Panther is more then I would have imagined. Sorry to read about your air brush issues - there always to be something to add to the mix.
Keep ‘em comin
Nice camo Gaz, I like it. Never made a free hand camo myself, a thing to keep in mind for one of my next builds. Can't wait to see the little rodent weathered.
Nice result Gaz. What paints are you using? I've had a few cusses with that problem using the Ammo paints.
Thank you, Fellas.
The paints are SMS acrylic lacquers.  Made in Australia.  I'm still trying to master them.
I love this camo Gary. And it’s execution is done perfectly by you. The Marder is so nice because of all the details visible from the outside. Your detail work fully pays off here.
Didn’t know how tiny the Marder was.
Thank you, Kai!  It's a great little kit, but like all armor needs company to give it scale.   Imagine sharing that space with four other men.  I imagine they stayed in reserve until needed so wouldn't always carry all of their equipment on the machine.  Anyway...there is tons more to do.
23 hours ago, GazzaS said:
Thank you, Fellas.
Thanks Gaz. Seen those paints mentioned but no real idea about them. Certainly give nice results
I applied a honey colored filter to blend the three colors a bit.   Added the final pieces and decals today...   though the four main assemblies are still only dry fitted.  Not sure How I'll squeeze the crew in.  Probably will have to put them in boiling water.  I'll do some light surface chipping before I hit it with washes.
Filters can do some magic and that's what happened here. The binding effect takes the paintjob to the next level Gaz.
Gaz, looks great, having just done the camo on the H it’s time consuming. I used Model Air , thinned and and added retarder and shot at low pressure…….now the fun starts…..
Gaz
Looking mighty sweet. The filter worked perfectly and being me, if I were building the Marder, I would be adding the crew (ooch that hot water is going to hurt)and into the display case. Beautiful cammo.
7 hours ago, Kaireckstadt said:
Looks awesome Gary!
3 hours ago, Martinnfb said:
Looking good!
Thank you, my friends!
Mild chipping and...   My first time doing all of the pin washes with enamels.  Not sure if I'm pleased or not.  They certainly don't flow as well as oils...   but dry a lot faster.
The details pop a little more...  Not sure how much weathering to do, really.  Maybe a little dust and dirt.  Maybe some rain marks.  But nothing too drastic.
If you'd like to go subtle on the weathering, you are on the right way, Gaz. Chipping is barely visible on the hull and I think, the result of the pin wash, doesn't look too prominent. To me, the scale reduction by 35 needs a bit of 'overscale' pronounciacion to look right.
All in all your Marder looks great, but I've never seen tracks so clean on a used tank.
Thanks Rob.  A long way to go on the tracks.  Still some touches to do on the Panzer Jager itself.
50 minutes ago, Kaireckstadt said:
This one looks great Gary!
I agree regarding your ideas for weathering taking into account where the tank was operated.
Thank you, Kai.
