Administrators JeroenPeters Posted May 11, 2023 Author Administrators Posted May 11, 2023 Added the conpressed air bottles to the wingroots. Also adding pipes with lead wire. 9 1
Administrators JeroenPeters Posted May 12, 2023 Author Administrators Posted May 12, 2023 Planning on opening as much hatches as possible. Working on the fuel tanks and adding fuel lines that will be visible through the hatches 9 1
GazzaS Posted May 12, 2023 Posted May 12, 2023 Looks great. Do you plan on adding Schwartzer Mannen..? sorry for my sloppy and poor German... 2
Administrators JeroenPeters Posted May 16, 2023 Author Administrators Posted May 16, 2023 On 5/12/2023 at 11:02 PM, GazzaS said: Looks great. Do you plan on adding Schwartzer Mannen..? sorry for my sloppy and poor German... nope. No figures. working on all the hatches and thinning the plastic. 5 1
Administrators JeroenPeters Posted May 18, 2023 Author Administrators Posted May 18, 2023 Fitting the legs. Tolerances are really tight and you have to clean up everything carefully. 10 2
Administrators JeroenPeters Posted May 19, 2023 Author Administrators Posted May 19, 2023 I live a few miles from the Aviationmegastore. That’s a perk. 10 2
Administrators JeroenPeters Posted June 3, 2023 Author Administrators Posted June 3, 2023 Working on the gear. 6 2
Administrators JeroenPeters Posted June 27, 2023 Author Administrators Posted June 27, 2023 Adding a few missing panel lines on the wings and rivets. 6 2
Administrators JeroenPeters Posted July 23, 2023 Author Administrators Posted July 23, 2023 Opening holes on the bugger is nice and all, but requires lots of research and scratching to show what’s inside. 6 1
Administrators JeroenPeters Posted July 27, 2023 Author Administrators Posted July 27, 2023 Seatbelts added. Working on adding some missing detail behind the seat. Next up: scratching the mk103 cannon. ZM appears to have designed the mk103 cannon some years ago but never produced it. 7
Administrators JeroenPeters Posted July 29, 2023 Author Administrators Posted July 29, 2023 I made a boo boo on the attachment of the seatbelts. Fixed it and added the tensioning wires for the seat from EZ line. Also added some detail to another open hatch on one of the tail planes. 8 1
GusMac Posted July 29, 2023 Posted July 29, 2023 Great attention to detail to pick up and then fix the error with the belts. Never seen an arrangement like that before with tensioning wires. 2
KevinM Posted July 29, 2023 Posted July 29, 2023 1 hour ago, GusMac said: Great attention to detail to pick up and then fix the error with the belts. Never seen an arrangement like that before with tensioning wires. Same here Gus Nice details though. 3
Administrators JeroenPeters Posted July 30, 2023 Author Administrators Posted July 30, 2023 7 hours ago, GusMac said: Great attention to detail to pick up and then fix the error with the belts. Never seen an arrangement like that before with tensioning wires. Takes a bit of research to see where they were attached and hoe they worked, but this clearly shows them: 3 3
Administrators JeroenPeters Posted July 30, 2023 Author Administrators Posted July 30, 2023 Pedal to the metal! 7 2
BlrwestSiR Posted July 30, 2023 Posted July 30, 2023 Bigger than I thought. Amazing detail with the seatbelts as others have mentioned. 1
GazzaS Posted July 30, 2023 Posted July 30, 2023 You've really added a lot to this one Jeroen. Looks amazing. 1
