Lovin' it. That shade in the bomb bay looks perfect.
I hope you haven't glued those oil tanks yet ;)
Been busy reviewing but did manage to get some work done on the Mossie.
Tailwheel is done:
32B0AE6D-AC45-436D-85FB-D6E21EAC5B97_zps
Bought some proper mesh for the anti icing intake cover (right Cees?):
20F75F18-1A1C-4D4B-9814-FDF5BCBD5E5B_zps
5EF33CF3-278A-417A-8F40-9653571EEF99_zps
You're motoring! From here, the build goes very quickly.
Superb work as always. Those bays are sublime.
Been a bit busy with work, but managed to get one or two things done.
In the meanwhile Jim sent me his spare set of Miracle masks:
B6AE74D7-9F3C-46D3-97E2-AB5B13392CAC_zps
Started masking the traditional ay with cut tape. Bleh! Too much work.
Tried Vallejo fluid mask and it works like a dream. Flows along the frames.
38DAC5A9-DB0F-4D9B-8C0D-02D6B224673E_zps
4F3017BE-46A7-4B4B-BC89-62CA433BC6C5_zps
Here's where I'm at:
BF71CF91-AD3F-484C-B837-DA2BA6CE1C66_zps
I think you piqued me at just about every stage with this. Such a great looking build so far, but you should have spent 4 hours with masking tape on those canopies. You've just cheated!
Cheers guys,
Here's some more work on the Cookie. Sorry for scratching it Cees! I'm just a bit clumsy ;)
Sprayed the colored lines. Needs some washes and details still.
5F1B60F5-C76F-45E8-95E9-51AC27193816_zps
692ED6D0-330D-4B97-BEB8-828C45AAFEE0_zps
wonderful looking build Jeroen
am very interested in the masking fluid
presumably it needs rather prominent ridges in the canopy frame to work - do you think it would struggle on say a Tamiya Spitfire canopy / something where the demarcation is very subtle
like the cookie (everyone loves cookies don't they?!)
Hi Nick,
I have various kinds of liquid mask. The one i used here is the most thin. The mossie canopy has VERY thin and fine panel lines and raisings. Still it tends to flow capular along the edges. Let me spray and check for the final result, but if this works, I'm never going to cut a mask or use pre cut....
