Not real happy with the fit of the PE. I ended up cutting off the bottom angled gauges on kit parts because the space between then was not wide enough for the IP faces to fit properly.  The Pe Would bunch up and not a clean bend. Need some touch up. Also on side rails, the front angle points broke off due to internal bubbles in the resin.ZM could have done much better if the whole conversion was IM.....harv
Just catching up on your build Harv. The IPs both look good to me.
It really is too bad the conversion wasn't plastic. It would have been so much easier.
Man,...
Harv, trust the resin. It’s a great medium to work with if you treat it right. Just remember it’s NOT styrene. It behaves differently.  But if you take your time, you’ll get stellar results.
It’s looking great, my friend!
trying to get the seats done and not happy. So fragile, and the side pins don't fit very well into the side rails. I have had to use several parts from the kit because of breakage. Dam I wish the would of done a better job on this conversion. Oh well, onward I shall go.....harv  :wallbash:
0130 and can't sleep. For some strange reason I have the war going through my head.  Anyway, working at the bench. Friggen seat belts....harv
I'm using the PE ones and they are a bit easier. Seats are almost done.Thanks........harv
Basic seats done. They came out ok,could have been better. Next the lap belts and headrests.....harv
