Impressive work again Tom. Those gasp look like crevasses! Hopefully everything will line up well after filling and sanding.
Good evening guys and gals...
Another Sunderland update for you, which has mainly involved filling, sanding and scribing. But from a good old fashioned vacform, who'd expect anything less?
The rather unsightly joins at the wing roots have been taken care of over the course of this this week. The first and most challenging task was to eliminate the nasty step seen in the previous update where the wing profile didn't match that of the wing-mounted root. My go to filler for these sort of tasks, P38, soon made short work of that and after an initial sanding session, you can see the extent of the work having been done at the forward wing root:
I've since spent a fair few hours finetuning the shape and profile of the roots, and also added the obliterated panel detail back. The wing and root profile now match perfectly, and I can confidently say, 'job done':
DSC_0195
DSC_0196
DSC_0198
The undersides still need some detailing but the join was fine here, and as you can see I've boxed in the bomb runners ready for further detailing in due course:
DSC_0204
I've also added the openings for the double-landing light set up on the port wing:
DSC_0193
It's starting to take shape quite nicely now...
DSC_0209
DSC_0206
Next up is making something resembling Sunderland stabilisers from these:
Until next time,
Tom
43 minutes ago, GusMac said:
Super work with the filler. How quickly does that P38 filler cure?
It’s usually dry and ready for sanding within 30 minutes. It’s great stuff!
Tom
you have done a great job on the wings.
looking forward to see more.
And im learning alot about vavform kits.
Mark
 Howdy folks,
I've been busy working on the stabilisers of the big Sunderland of late. As usual, the first job was to scribe on the panel detail:
I did contemplate removing and scratch-building the elevators, but there is some really finely moulded rib detail that is actually well worth keeping. I'll need to add the hinges and with a dark wash along the hinge line when painted, I think they will look fine.
Each section was cut from the backing sheet and sanded to shape, ensuring the correct depth and thickness. As you can see, the fit was pretty good when test-fitted:
Given the fact that the stabilisers are likely to get whacked periodically during the remainder of construction, I wanted them to be nice and sturdy so I have added a plastic card spar, as well as the usual scrap sprue treatment along the leading edges. I've also opted for a brass tube spar system that will fit through the fuselage and offer a really strong set up:
The stabilisers were then trimmed carefully and added to the rear of the fuselage - careful consulting of plans ensured they are in the correct position:
DSC_0280
DSC_0281
The careful trimming of the mating surfaces, along with the spar structure ensured only a lick of filler was needed along the fuselage to stabiliser join.
She's starting to take shape now:
DSC_0294
DSC_0284
DSC_0285
DSC_0289
DSC_0288
She lacks a bit of stability at the moment, so I better get cracking with the fin...
Until next time,
Tom
16 hours ago, Bomber_County said:
Stunning Tom, we need to see a size comparison for this behemoth….
Here we go - here's my daughter (she's 5) 'modelling' it for you...
IMG_1587
All the best,
Tom
4 minutes ago, Peterpools said:
:omg:
Holy Cow, BIG doesn't come close - how about: GIGANTIC, COLOSSAL  and even GALACTIC!
Incredible, just incredible.
That's a few ways to describe it, Peter. Interestingly, my wife has a few others - that I won't repeat here, being a family site and all... 🙄
  • Haha 5
Tom
Got ya! Painting the Sunderland is going to be a project all unto itself and I'm wondering how many 'gallons' of paint are going to be required:hsmack:
42 minutes ago, Peterpools said:
Tom
For my Lancaster I needed 20ml RAF Night, the same amount of Dark Brown and 10ml of Dark Green.
For the Sunderland I think you even need much more because it’s much bigger…
In defense of your wife, this is not the first build of this size you have done ;). I am sure she insists you store the finished kits far away from the living room :)
However, this one just eats up even more volume than the others...
  • Haha 2
Afternoon guys and gals,
Another update for you - can you tell I'm a teacher on school holidays? :)
I've been working on the last of the major airframe construction which has been the vertical stabiliser. Here's how it comes in its raw form:
As usual, I had to scribe on the surface details and then I set about making some internal reinforcements. Being such a massive fin, I made some beefy spars from plastic card and used some old scrap sprue to reinforce and help the bonding of the leading edge. The spars were made to protrude from the base of the fin, as they would then be attached through the top of the fuselage and secured to the spar for the stabilisers using Araldite Epoxy glue for a really solid joint:
The fin was then blended into the upper fuselage with car body filler, polished and then the missing and damaged panel detail reinstated. Unfortunately, the distinctive curved fairing at the lower rear of the fin was missing in the kit, so I fashioned the basic shape of the fillet from plastic card and blended everything in with filler - see the red arrow below. This will still need some more tweaking when I work on the turret as it's actually quite a complex shape at the back end:
DSC_0309
I've also added some Evergreen ribbing on the rudder in an attempt to match the elevators - this has since been sanded right back and is much more subtle:
DSC_0306
It's now looking more and more like a Sunderland:
DSC_0304
DSC_0300
DSC_0299
It's good to get the main construction done and I've been on a bit of a roll... the next logical step will be the engines so I'm off to do some head-scratching about how I can convert a 14-cylinder Hercules engine (from the Revell 1/32nd Beaufighter) into a 9-cylinder Pegasus. Should be fun!
Until next time,
Tom
Tom
Awesome progress as always - amazing work. Loads of scratch work and model engineering to bring the vertical stabilizer up to speed and installed.
Beautiful work Tom. Really looks the part now all the major airframe components are together. :unworthy:
Copy that! Absolutely impressive!
Tom, like I told Cees with his project, this is simply stunning beyond words.
The two of you inspire me and have taught me so very much in regards to the actual simplicity of scratchbuilding once you get past the mental block and have a good set of drawings.
A large scale Sterling and Sunderland, at the same time, on a model forum…. I can’t think of too many placed that happens at.
Just flawless work.
