Thanks Jeff.
Useful photographs I must say.
I do believe that that particular vehicle was purchased by a film company and if it is also to be believed, it was actually used at RAF Scampton to refuel the dambusting Lancaster aircraft  . . .
You have to believe that this took over two hours to assemble.
The instruction sheet does not offer the best placement of parts onto the main frame. There are quite a few recesses in the frame and its not the biggest/clearest diagram. As you can see I have extended the chassis and as such I have used artistic licence in placing certain parts on the extended section regards the hawser wire.  I will be have to produced a larger fuel tank and a longer Air tank as those in the kit are smaller for the 4 x 4 Gun tractor.
The kit only provides the bottom section of the engine.
The one thing about AFV instructions, they aint very clear :rtfm: Ideally they could have had exploded views to clearly show where to stick stuff :2guns:
A bit of progress here with the suspension on the front, so many small pieces
Modifications to the cab with a roof sliding hatch and on the refueller vehicles there were two triangular windows cut out to aid reversing. I will need also to do the same for the 'Fire shield' inserted behind the cab.
Thanks for looking in . . . . B)
Completed the front axle and drive shaft last night. The fun begins when I try and build the two axles at the rear  :shock:
Just a snap to see how the cab is going to look  . . .  you dont see many ( if any) with the early style roof and sliding hatch being built even in the smaller scale B)
a couple of days off before I start again
David
Progressing with the rear twin axle combination. I need to complete the front axle with the wheels so I can then fix the height of the rear axles.
I think in photos of actual vehicles, the rear end is slightly down but that is probably due to the weight of the fuel in the tank so I am aiming to get it as level as possible.
The cab will be a point of interest and AFV do not let you down with detailing. Provision is there to have a number of window combinations and I will probably run with at least a couple of them being open.
I hope to get the 6 wheel chassis complete with the cab before starting on the tank and pump housing :book:
David
Some progress has been made . . . honest :D
First photo is a comparison of the Airfix OO scale and the 'massive' 35th scale
Next a shot of the drivers area, note the two triangular windows rear of the cab. There will be a 'Fire shield' to go behind the cab that will also have the triangular cut outs without glass. ;)
Near side of the cab with a glance of the double axles at the rear
The cab front. An etch mesh is provided for the distinctive AEC engine cover
You may be able to see the two triangular windows in the rear bulkhead, a mod for this vehicle to aid the driver when reversing.
The drive shaft between the two axles. I cast this shaft using 'Blue Stuff' and Milliput
View of the 6 x 6 chassis with the modified cab roof for the MKII version.
A few bits such as the windows in the cab to complete when the painting is completed, it also needs a new fuel and Air tank but the next challenge will be the 2500 Gall. tank and pump housing at its rear .
Thanks for looking in :rolleyes:
David
There has been some progress although not much, the builders are in the house so  . . .
A new vehicle fuel tank was put on the chassis made from a solid bar of plastic, fortunately the filler neck and gauge are from the kit parts
A new Air tank was also put in place on the near side . . .
The six wheels are now permanently in place, all square and vertical
I installed the photo etch grill which is something I have never used before B)
Those sharp eyed amongst you will spot the two styles of roof, the curved version with sliding hatch and the more usual with the arched roof, again with a slide hatch neither of which come in kit form with the kit B)
David
On with the tank . . .
The pump housing at the rear of
Five identical oval templates create the shape
More progress on the main tank . . .
Placing some sectional pieces in to keep it rigid
The miniature spirit level ensures it all flat
Also made a start on the tank supports, I intend to cast and produce several of these from milliput
I used 20 thou plasticard to wrap the tank frame,
and finally, the mock up on the chassis
thanks for looking in
David
David, that looks spot on...................... I need to 'try' to build a similar tank in 1/25 scale................. I will use your techniques and see if I can even come close.......some serious engineering here........ I LOVE this..... :wub:
Jeff Good luck with that.
I think the reason behind my success was that I used the same original to make the others rather than use the one that I had cut/shaped.
I marked it up as such 'This One'
Been pressing on with the main tank
I am making the master for the tank supports, again! The first version was a bit narrow when I checked against the tank straps so a bit more time will pass before I can cast those. Busy working on the pump housing at the rear as well . . .
David
Not much to show but some progress . . .
the rear housing for the pumps etc that sits at the rear of the main tanks . . .
More to come sooon :construction:
David
  • 1 year later...
I'm sorry to say that I did stall with the tank supports and struggled to find the best way to produce five such supports.
The original one that I shaped was two pieces of 60 thou. plasti-card.
I stopped after the thought of doing a support 10 times and trying to shape them all the same. I aint into resin so I didnt know how to cast anything like that so as i said, I stalled. I built some bomb trolleys for my David Brown tractor.
I looked up on YouTube vids for inspiration and found a material called 'Blue Stuff'.  My first attempt . . .
I had varying success after failures and eventually ended up with five decent tank supports  . . .
I decided to use some Epoxy resin to best secure them . . .
and with all five secured I tried to sit the tank on the chassis  . . .
I am now trying to get this completed before the end of December as I want to start the HK Lancaster in the New Year, so I have completed the access ladder and cracking on with the box housing for the pump system . . .
More to come in the following weeks,
Ian
I have managed to construct the framework under the pump housing at the rear of the tank.
There is a bar onto which a step ladder rest so the airman can reach up into the pump system, there is also a frame for the ladder stowage  . . . .
I'm just on with the tank strap buckles which are a bit fiddly . . . :o
rgds to all
Ian
