Martinnfb Posted August 8, 2019 Posted August 8, 2019 Definitely Thai Air Force recon birds are pretty sweet. I don't want to hijack Carl's topic, so once you start yours, I will hang it tall there. Just for demonstration purposes two basic coats. 5
BlrwestSiR Posted August 8, 2019 Author Posted August 8, 2019 Well, the tape is off and... I'd say it's a much better result this time. 6
Martinnfb Posted August 8, 2019 Posted August 8, 2019 That looks ultra clean. Very inspiring work Carl. 3 1
BlrwestSiR Posted August 8, 2019 Author Posted August 8, 2019 Thanks Martin! There's a small bit of overspray I need to fix but otherwise there were no issues with the paint. No lift, no marking from the tape. It came off nice and clean. 4
crazypoet Posted August 8, 2019 Posted August 8, 2019 Sweet! That gives me hope for my own future NMF builds... 3 1
BlrwestSiR Posted August 8, 2019 Author Posted August 8, 2019 33 minutes ago, crazypoet said: Sweet! That gives me hope for my own future NMF builds... It may not be a true NMF but I think it comes close enough without all the headache. There was a C-119 at the shop one of the staff had done using the same paint and it had the same finish as mine. So definitely not a fluke. 5
BlrwestSiR Posted August 8, 2019 Author Posted August 8, 2019 Ok, I managed to get the antiglare panel and the radome painted. Were the wheel wells silver or chromate green? Those are up next. 4
Martinnfb Posted August 9, 2019 Posted August 9, 2019 Zink Cromate. An interesting discussion here 2 1
BlrwestSiR Posted August 9, 2019 Author Posted August 9, 2019 Thanks Martin! That's next to mask off and paint. Then I have to figure how to get the ejection seats in. 3
TJTX Posted August 9, 2019 Posted August 9, 2019 This is one slick looking rebuild. The paint work looks oh so smooth. 3 1
BlrwestSiR Posted August 9, 2019 Author Posted August 9, 2019 Thanks Tony! Like your Felixstowe, the redo was definitely worth it. Carl 4
Bomber_County Posted August 10, 2019 Posted August 10, 2019 Carl, you’re a braver man than me..........looking stunning ........ 3 1
BlrwestSiR Posted August 10, 2019 Author Posted August 10, 2019 Thanks Phil! I generally try not to give up on a kit unless it's well and truly pear shaped. Plus, if I feel that it's a bad enough flaw that I've paused on it, I've got nothing to lose by trying a re-do. 3
BlrwestSiR Posted August 10, 2019 Author Posted August 10, 2019 Quick weekend update. I masked off the wheel bays. At the same time, I did the tailpipe. 4
Administrators Clunkmeister Posted August 11, 2019 Administrators Posted August 11, 2019 Ooooh, I go away for a few days and miss the good stuff. Nice save, Carl! Awesome job!! 3 1
DocRob Posted August 11, 2019 Posted August 11, 2019 Great redo and well worth it, nice. Cheers Rob 3 1
JonathanReed Posted August 11, 2019 Posted August 11, 2019 Very nice save!! Looks awesome! Inspiring knowing how much i give up on projects and mess up! 3 1
BlrwestSiR Posted August 26, 2019 Author Posted August 26, 2019 Thanks for all the encouragement folks! Okay, time for a quick update. I got the tip tanks done and painted. Then it was onto the landing gear. I was concerned about the way the gear legs mounted but couldn't figure out a way to pin them so hopefully they hold up. I did drill out the wheels so I can pin them with metal wire. Need to paint them before I install those. 3
BlrwestSiR Posted August 27, 2019 Author Posted August 27, 2019 I painted and installed the wheels. Then the moment of truth: She's not a tail sitter! I then started painting the canopy by doing an initial coat of black. While that dried, I started on the decals. They're from Belcher's Bits, the same guy that made the decals for Ernie's Lanc. 5 1
