Apart from the magnificent work you did on the crew and Jeep as well the 335....
how’s your hand doing now? As I can imagine it’s not good to have a Willy Jeep driving over it!
On 2/12/2021 at 8:38 PM, JeroenPeters said:
Aaaalmost there. Heads are aded to the figures. The AK oils worked great on the faces.
Great result Jeroen and not only with the heads. The Do is a mouthwatering beauty and makes me want to start my one seater.
I used Abteilung oils for the first time on figures on my last build (two German WWI naval airmen) and loved the result. The approach is quite different, than with acrylics, but they blend so much better. If you use matte varnish, you even reduce the unrealistic shine. I was so happy about the result, that I decided to paint the figures completely in oil, which I will do more often now.
