Sasha As Posted October 22, 2022 Posted October 22, 2022 Dear community, I would like to share with you the results of the FW-190 A-8 R-2 from Revell in 32nd scale. The pilot Wilhelm Moritz commander of the IV assault group JG 3 "Udet" flew this machine in June 1944. Revell made a good model but one must be very careful when building, especially the engine bonnet is quite a problem if done closed. I used the "Big Ed" in the build. , metal barrels, "Res Kit" chassis. The other modifications were made to the cockpit, recess, landing gear struts, tank, pylon and model airframe. Many things done, the engine was a separate exhibit, then conscientiously hid it.))))) I riveted the model and it brightens up the look. Actually in the section "In hand" it can be seen. And all as usual primer, metallic, paint, highlighting rivets, vizering, varnish, oil, fuel leakage and exhaust. In the end I got the result which I am sharing with you. Enjoy the ride! 7 1
DocRob Posted October 23, 2022 Posted October 23, 2022 Very nice and convincing finish. The riveting enhances the look especially on the black cowling. I also like the slight shine in the black cowling, which gives it a more 'metallic' appearance. Cheers Rob 1
HubertB Posted October 23, 2022 Posted October 23, 2022 Very nice result indeed ! Well done 👍 ! Hubert. 1
Sasha As Posted October 23, 2022 Author Posted October 23, 2022 4 hours ago, DocRob said: Very nice and convincing finish. The riveting enhances the look especially on the black cowling. I also like the slight shine in the black cowling, which gives it a more 'metallic' appearance. Cheers Rob DocRob thank you! 1
Sasha As Posted October 23, 2022 Author Posted October 23, 2022 1 hour ago, HubertB said: Very nice result indeed ! Well done 👍 ! Hubert. HubertB thank you!
GazzaS Posted October 24, 2022 Posted October 24, 2022 Beautiful work, Sasha! Makes me want to build a 190. 1
Sasha As Posted October 24, 2022 Author Posted October 24, 2022 4 hours ago, GazzaS said: Beautiful work, Sasha! Makes me want to build a 190. GazzaS thank you !!!
Landlubber Mike Posted October 24, 2022 Posted October 24, 2022 What a fantastic model Sasha! Amazing job! I also really like your display base for it. 1
Sasha As Posted October 24, 2022 Author Posted October 24, 2022 3 hours ago, Landlubber Mike said: What a fantastic model Sasha! Amazing job! I also really like your display base for it. Mike thank you!
KevinM Posted November 4, 2022 Posted November 4, 2022 That came out very Nice Sasha the rivets give a certain look. 1
Sasha As Posted November 5, 2022 Author Posted November 5, 2022 12 hours ago, Irishman1 said: Beautiful job! Irishman 1 thank you!
Sasha As Posted November 5, 2022 Author Posted November 5, 2022 9 hours ago, KevinM said: That came out very Nice Sasha the rivets give a certain look. Kevin thank you!
k5ikl Posted November 5, 2022 Posted November 5, 2022 WOW!!! Outstanding build Sasha. Cheers, Jerry 1
CANicoll Posted November 6, 2022 Posted November 6, 2022 That Revell kit came out beautifully with your work. Such an interesting subject, and you really did a nice job with it. How did you find the Big Ed kit and how much of it did you use? Did you find it worth it in the end? Great photographs! Chris 1
Sasha As Posted November 25, 2022 Author Posted November 25, 2022 On 11/5/2022 at 6:21 PM, k5ikl said: WOW!!! Outstanding build Sasha. Cheers, Jerry Jerry thank you!
Sasha As Posted November 25, 2022 Author Posted November 25, 2022 On 11/6/2022 at 4:28 AM, CANicoll said: That Revell kit came out beautifully with your work. Such an interesting subject, and you really did a nice job with it. How did you find the Big Ed kit and how much of it did you use? Did you find it worth it in the end? Great photographs! Chris Chris thanks for the feedback! The set is really good, but of course there are downsides.))) Big Ed doesn't need to buy it completely. I took in parts and only what I needed as part of the work on this model. 1
