Hi All,
Here we go! Yet another Mosquito being build here on LSM while the kit is not even on the shelves yet.
This kit arrived wrapped in bubbles, no decals and no instructions. Got these in PDF from Jim to help me out, since I'm not big with puzzles.
Having already seen the sprues and kit at Telford the shock of all the slide mouldings wasn't big, but still impressive...
Borrowed a few Mossie books from Cees (since I'm not an RAF expert) and just bought an HGW Sutton harness.
My plan is to start with the instrument panel (some Airscale will help me out here) and see where I'll go from there!
Let the journey begin...
60FE5B3F-D159-43C0-8A8E-DC351EC5C200_zps
8182E07D-4B52-4432-845B-25FBFBFE413F_zps
Looking forward to this Jeroen. Have always had a soft spot for the Mossie since reading the 633 Squadron books as a kid. Really hope they do the fighter-bomber as well.
Gus
Hi Gus,
I'm sure they will :)
Cut some plastic. Adding details to various areas. Added instrument housings to the back of the IP, wiring, etc.. Added some detail to control column with spare PE. Using Airscale decals and PE bezels to detail the instrument panel. I'll use HGW seatbelts.
AA934FCE-30E7-4D82-BA35-20172460B44D_zps
B8B158B2-646E-4B34-896D-873469005CEE_zps
Not bad for an not-RAF-modeller ;)
In fact very nice. The leather cushions were either dark green, dark brown or dark black :D
Cees
Ok, made some progress n the pit this weekend.
Added:
- Airscale instruments
- Airscale bezels
- Airscale placards
- Lead wire and instrument housings from plastic rod
- HGW Sutton seatbelts
The pit construction is quite clever as you can see. The pit is assembled and slides into the one piece moulded outer fuselage.
The small discs on the inside of the pit are not ejector pin marks, but strengthening discs to accommodate instruments, wires, etc... (thnx Cees!)
74DC50BB-272A-4CD6-9756-1BAC34DACAE8_zps
A7A61F21-6325-4200-AEA1-4DBB965F3BD7_zps
4F4E2AC3-B2F5-4825-9206-920F4DDD525F_zps
261DAC02-9ACD-48C9-9DB6-065DED2CBCDC_zps
Coming together real quick. The wing builds just as fast too.
Liking this one LOTS.
It's certainly coming on all right!
(Never knew that the design of the tail wheel was to solve a "shimmy" problem! Why the hell don't supermarkets use this on their trolleys !!!!!)
Hi Guys,
Sorry to have been so quiet over here! It's been busy at work, but this weekend managed to squeeze in some bench time.
Used chipping agent by spraying all the green parts a light green. Then darker green and chipped that layer.
D89007D1-AF1B-45A0-BC5E-69D2DC7706A8_zps
08211AB7-4EEE-4839-BFA7-ACE95A00405B_zps
2BBBDE08-EC86-4C8F-8BA3-FC7E5E3B896B_zps
I'll add some additional wires to the engine.
Gear is Alclad followed by matt varnish and AMMO wash.
9D751690-AF2A-404D-8EAD-C536B1104794_zps
F7C7128B-EDA2-47B5-9AC5-0387551DE484_zps
Love your paintwork Jeroen. I think I should try your approach in painting the sub assemblies/parts first instead of gluing everything together and paint afterwards.
