Trumpeter TBM-3
As it turns out the turret fit was no sweat although you have to have the glass "dome" in place. It won't "drop in place" after the lower portion is cemented in place. The worst problem was the firewall/forward fuselage fit. I had to cut two of the mounts to allow it to line up correctly. And of course we ALWAYS knock some pieces loose when fitting, etc. :wacko:Easy fix though.
Due to some poor fit I had to pop off the engine and firewall and remove the remaining two supports. They aren't needed unless you are opening the accessory panel. I also left off some of the parts for the rear fuselage as they are practically invisible when the fuselage halves are joined. Just use the necessary stuff and forget about all the superfluous parts.  More photos soon.
Damn Trumpeter and their uberfiddly crap! Working (or TRYING to) on the wings. There are several PE pieces to attach to the wing stubs and outer wings. Also some silly soft "hinges" for the ailerons with more PE fiddly bits. For me they have a pretty high cuss-factor. My all-thumbs clumsiness doesn't make it any easier. Okay, rant over. :wacko:
