Barry Posted January 31, 2019 Posted January 31, 2019 21 hours ago, chek said: No Note though Cees, it's not only a widening of the intakes, but they also rise to a point about level with the rear canopy fairing. Despite Frank's valiant effort, this omission was enough to spoil the look of his method for me. The whole intake of the Spey Phantom looks like it's been cranked downwards, and without the vertical rise, you can't get enough of that downward crank. Hi Chek, I do not understand "rise to a point about level with the rear canopy fairing" can you please elaborate? Thanks, Barry 2
Barry Posted January 31, 2019 Posted January 31, 2019 Here are a few more pics and drawings that may help. Cheers, Barry 1
chek Posted January 31, 2019 Posted January 31, 2019 33 minutes ago, Barry said: Hi Chek, I do not understand "rise to a point about level with the rear canopy fairing" can you please elaborate? Thanks, Barry This drawing from Tommy Thomason probably shows it best. The whole Spey turbofan nacelle from intake to jetpipe was through-putting much more volume that a J79 turbojet. The intake topside has an upward slope to approx station F13 on the drawing below Regular F-4J in black, Spey mods added in red, 2
Barry Posted January 31, 2019 Posted January 31, 2019 Chek, I thought that might be what you were pointing out. The F.S. drawing I posted is Tommy's as well. With the NO you posted with my picture my intake rise is pretty close is it not? Barry 4
chek Posted February 1, 2019 Posted February 1, 2019 3 hours ago, Barry said: Chek, I thought that might be what you were pointing out. The F.S. drawing I posted is Tommy's as well. With the NO you posted with my picture my intake rise is pretty close is it not? Barry Barry, yes the model in the lower frame showing the two fuselages looks pretty good to me and the intake rise looks about right. It will be easier to tell when it's been primered that the lines flow smoothly. My original point was directed to Cees, whose model was following Frank Mitchell's method which dealt well with the increased width, but not the depth as your model has done. I'm still holding out for the HKM version because I really wouldn't look forward to doing the home-baked conversion two or three times. 1
GazzaS Posted February 1, 2019 Posted February 1, 2019 Very impressive changes! I never knew the Brits had an F4 with a different engine. 1
Wingco57 Posted February 1, 2019 Author Posted February 1, 2019 Thanks chaps for the info. I think a lot of people are not aware of the many changes regarding the Spey-powered Phantoms. By the way, can anyone point me into the direction of some usable scale drawings? Cees 1
Barry Posted February 1, 2019 Posted February 1, 2019 6 hours ago, GazzaS said: Very impressive changes! I never knew the Brits had an F4 with a different engine. Both Phantoms built for the British the F-4K and the F-4M had Spey engines it was a part of the contractual agreement to purchase a non British built aircraft. There were other sub assemblies that were built in Britain as well. Barry 2
Barry Posted February 1, 2019 Posted February 1, 2019 4 hours ago, Wingco57 said: Thanks chaps for the info. I think a lot of people are not aware of the many changes regarding the Spey-powered Phantoms. By the way, can anyone point me into the direction of some usable scale drawings? Cees Cees, As far as I know no one has ever come up with scale drawing that were considered completely accurate. I have a number of drawing on the K/M but all leave something to be desired. Barry 1
Wingco57 Posted February 1, 2019 Author Posted February 1, 2019 Haha, nobody can blame me for not making the most accurate FGR then. I like that. Cees 1
chek Posted February 1, 2019 Posted February 1, 2019 3 hours ago, Barry said: Both Phantoms built for the British the F-4K and the F-4M had Spey engines it was a part of the contractual agreement to purchase a non British built aircraft. There were other sub assemblies that were built in Britain as well. Barry Also as a historical aside, Macair was considering the switch from turbojets to turbofans and the Spey (or a US built version) was to have been the powerplant for the swing-wing Phantom FVS project, had it proceeded. That was in the days when only the benefits in fuel efficiency from turbofans were seriously considered and the problems of integration (increased drag) hadn't yet been discovered. 1
Wingco57 Posted February 2, 2019 Author Posted February 2, 2019 Some more work done. The flaps were sawed in to enable the underside to be bent downwards later. Further work on the intake trunks. The top fillerpieces have been glued in. The flat pieces have a purpose and prevent the filler pieces from sitting too low. You see them cut away later. My take on the inner intake pieces. I assembled the cut off pieces and inserted a piece of plasticard in the join forcing it outwards. Later the missing pieces will be added from card and the insides smoothed with miliput. At least that is the plan. If it fails I will use the easy way....intake covers. Cheers Cees 8
Wingco57 Posted February 3, 2019 Author Posted February 3, 2019 Hang on...this might actually work. Cees 7
Anthony in NZ Posted February 4, 2019 Posted February 4, 2019 Cees, I totally am loving your work on this! This is the sort of modelling and conversions I enjoy. Keep up the brilliant work, I love each update and the ensuing discussions Cheers Anthony 4
Wingco57 Posted February 10, 2019 Author Posted February 10, 2019 It takes a lot of cutting, adding plastic and sanding to get a reasonable fit. But this is as good as it gets. Milliput will be used to smooth things out. Hope you like. Cheers Cees 12
Peterpools Posted February 10, 2019 Posted February 10, 2019 Cees Yikes! I'm in and will be following with intense interest. I'm strapped in and ready for the journey. I'm simply in awe of hoe you go about determining not only what the modifications are but how to engineering the work. Hopefully, some of your mechanical genius will magically rub off on those of us who are following. Like Dennis, I never realized the extent of the difference and modifications need for the conversion. Keep 'em comin Peter 4
Peterpools Posted February 10, 2019 Posted February 10, 2019 Barry Amazing work, just amazing Peter 3
Wingco57 Posted February 11, 2019 Author Posted February 11, 2019 Got me some goodies for the cockpit. And the intakes have been cemented in place. I feel a sanding and Milliput session coming up. Cees 9
Administrators Clunkmeister Posted February 12, 2019 Administrators Posted February 12, 2019 As usual, I look into one of Cees’s builds and find myself picking my jaw off the floor. Un-bloody-believable is all I can say. Blown away! 4
Martinnfb Posted February 12, 2019 Posted February 12, 2019 Everyone who builds Migs can relate to this level of madness. Phantastic work Cees, 2
GazzaS Posted February 12, 2019 Posted February 12, 2019 This is a cool build. I hope that it ends up looking appreciably different from a standard US F4. Otherwise, your efforts may be lost upon us dilettantes. Gaz 3
