So one of my long-term goals is to do a Korean War F-86F vs Mig-15 in-flight dio
What I don't have is a good feel for available kits.  The only current/new tooling F-86 variant I've seen in 1/32 is the -D SaberDog, which is not what I want to build.
Trumpeter and HpH both have Mig-15 kits, but all I'm seeing for the F-86F is the older Hasegawa kit on eBay.  Any others out there that I'm missing?
Recommendations and ideas welcome!
Italeri makes a decent enough Sabre but I'm not sure if it's Korean vintage.
For the MiG, there's no question, HPH is by far the best of the bunch....
Funny you should ask about Mig-15, I just started working on the Trumpeter kit yesterday. I was preparing for the worst, but was pleasantly surprised. The fit is better than I expected. The exception being that you treat it like a short-run European kit. First thing I did was cut the locating pins off the front to rear fuselage joints, lightly sanded the surfaces flat against the bench on a piece of sandpaper, and glued the front and rear halves together while flat on the bench, working the seam a 1/2 at a time, I ended up with a pretty nice seam, l then trued up the sides with a sanding stick and took the burrs off the mating surfaces. I then went to work on the wings, to my horror, they were not even Mig-15 wings, they were 17 wings! I bought this kit off someone a few years ago, and they must have accidentally swapped a 17 sprue in the box. Luckily, I had another 15 in the stash. And grabbed those wings, then fit them to the body, it takes a little work, but if you sand a few strategic spots, they will fit pretty nice. I also fit a Lonestar resin cockpit and a squadron canopy. So far I have a grand total of 5 hours in it, and I’m ready to paint the cockpit, and glue the fuselage and wings together. All it takes is some basic sanding and a little care in assembly sequence, I have seen some nice examples built.
I agree that the HpH is a more accurate and detailedkit, however, you can get the Trumpeter kit, a cockpit, a canopy and decals for $60, $80 if you could the second kit I had to crack open. I’ll be posting some pics later.
As as far as the F-86, the kinetic is the better of the two I think. Hasegawa is old and low on detail.
https://www.ebay.com/itm/KINETIC-1-32-F-86F-30/123931626590?hash=item1cdae68c5e:g:CfgAAOSwNaBdmzIr
I believe the Italeri kit is the Kinetic kit reboxed. I haven't built either so can't attest to the quality and any short comings.
1to1, thanks for your take on the Trumpeter MiG. I tried to build one years ago and failed miserably. I might have to take another go at it.
4 hours ago, Ryan said:
The canopy framing is off if I remember correctly....its more of a Mig 17 frame.
It’s sort of close as a Mig-17PF, shape is ok, but the front windscreen should have 2 horizontal frames rather than 1 center. On the mig-15, the Squadron canopy is the only way to go.
Thanks to all - this is truly valuable, and you’re saving me a ton of headaches by allowing me to peek over your shoulders - I appreciate that more than ya know!
I might be the wrong guy to comment on whick kit is better in my opinion, because I'm one of those guys who's a bit of a masochict when it comes to building stuff.
Freakishly, I enjoy fighting a very accurate short run or resin kit more than I do assembling a vice building but somewhat inaccurate but easy building mainstream kit.  I'm not a researcher at heart, which puts me at a huge disadvantage. Guys like Martin, Tony, Jeff, Mark, Jeroen and Danny seemingly live for research. For me, I'd rather pet the sweaty stuff than sweat the petty stuff.
HA! - I get that about you!  :D
I kind of split the difference.  I love the short-run, finicky kits, but I also like to take a more mainstream kit and dress it up.
I'm not quite to the point where I'm ready to take on a scratch conversion, but I'm quite happy to fiddle around and fine tune when needed.  I tend to go a bit cross-eyed when trying to verify panel and rivet details, and I've neither the eyesight nor the dexterity to get to the level of finesse I see displayed here on a regular basis...
But Ima keep tryin'!
Now I'm far away from an Expert, but if you can take the Kinetic/Italeri's somewhat crude detail, it does build into a nice kit. There are also sometimes, some AMS parts available for it, including a cockpit.
I build a Canadian Mk.6 withou adding anything to it, and it looks like a Sabre!
5 hours ago, Sir Desmond Glazebrook said:
I advise you follow your urge and get a MiG 15 and a North American F-86.
IHTH.
Which protagonist is chasing?
That's a really good question!  Simple scale math means that this will, of necessity, be on two different bases.  My original thought was to re-create the positions and dynamics from a gun-camera scene of an F-86 downing a MiG-15 that I found online.  That said, with two bases (mounted? suspended? dunno yet), I can swap things up a bit and let them play, so to speak.  In practice, when we were flying against Russian pilots, the two were *very* well-matched and it was not ever a foregone conclusion as to who would be stalking whom...
Thanks for asking this - it just shifted my whole context!
You could always imagine a « face-to-face » set-up à la Rocky vs Drago (that was Rocky V, wasn’t it ?) poster ...
PS : oops, sorry, quoted the wrong post ;)
