It’s definitely a nice kit that could even make me want to build a target model one day :D
And what a neatly ordered bench in the background :thumbsup2: !
Harv, I’ve started use the CA gel now. Gorilla do small tubes of the gel so you just use as much or as little. If you wipe the nozzle and put the cap back on they are good for months. Number of bottles of CA I’ve ditched. I did all the PE on the Tiger with this gel........
More bench time. Interior is coming along. A couple small parts to add. I like this build....harv
21 hours ago, harv said:
I like this build
Harv, that's the important part. Meantime, the interior is looking mighty fine.
Working on interior walls.  Not done yet. I will be in CA. For a couple of days so no updates till next week. Cheers.....harv
7 hours ago, harv said:
Well, the " fuselage " is closed up. I think it's going ok.......harv
Looking good Harv, time for the wings now :D.
Up till now, the fit has been good. But working on the nose pieces, not so much.....harv
. But moving on. Had to sand and grind a lot off the radiator  to get the roof to sit down, ugh. Then had to add thin strips to the Bach to cover som big gaps. The one pic with top on, nothing is glued on yet......harv
Another oddity to this kit is in a couple of parts, you are to cut rivets ot track sprues and glue where directed Strange.....harv
Only ever built one Takom and that was the Mark IV, you’re right there were one oddities. The track build up was if remember 5 parts per.......looking good Harv
