Administrators JeroenPeters Posted March 20, 2020 Administrators Posted March 20, 2020 Time for a new project. I felt like building something not too complicated. But then i went and got: Eduard interior set Eduard exterior set Eduard wheels Eduard exhausts DN Models mask set HGW seatbelts 12
TJTX Posted March 20, 2020 Posted March 20, 2020 This will be exciting to watch. Your skills and this subject will fit perfectly. 4 1
harv Posted March 20, 2020 Posted March 20, 2020 1 hour ago, TJTX said: This will be exciting to watch. Your skills and this subject will fit perfectly. Yep, what he said !.......harv 2 1
DocRob Posted March 21, 2020 Posted March 21, 2020 Will follow with interest. I have the same kit in stash along with the AM and cracked the box open several times. Maybe your build is a go for mine too. Cheers Rob 2
Bomber_County Posted March 21, 2020 Posted March 21, 2020 Jeroen, another masterclass in the offing. I’ve seen the HKM built up but never the Zoukie Mura boxing...........?.......... 2
Administrators JeroenPeters Posted March 22, 2020 Author Administrators Posted March 22, 2020 Thnx guys! Added more photo etch to the pit. The HK seat lacks 4 small reinforcements at the underside of the armrests so i added them from small strips and sanded them into shape. 9 1
Administrators JeroenPeters Posted March 23, 2020 Author Administrators Posted March 23, 2020 If you add the bomb to the internal bomb bay the detail is sufficient. But when you leave it out you’ll need to spice it up. Here are the first of some added details. also found a long thin spring to make the hose that is connected to the control stick. the do335a instrument panel has a few instruments more than the b version. So today i swapped my b version from eduard for the Yahu instrument panel. 11 1
CrankyCrafstman Posted March 23, 2020 Posted March 23, 2020 OHH YUMMY! I want to do one of these or the ZM one, not sure which... so I'm watching and takin notes Ron G 5
Administrators Clunkmeister Posted March 24, 2020 Administrators Posted March 24, 2020 Awesome build. I have the ZM kit, and I’m not ready for that battle right now. 3
Administrators JeroenPeters Posted March 27, 2020 Author Administrators Posted March 27, 2020 Since this kit isnt out on the market yet i have to make do with a test shot sprue that has many flaws. Short shot parts. The rear seat had a large hole in the back of the seat and the leg rests where half gone. I cut out the entire back and made a new one from green card. The leg rests were made from 0.3 mm rod. 7 1
Administrators JeroenPeters Posted March 28, 2020 Author Administrators Posted March 28, 2020 Thnx! the rudder pedal had to be re-done. There is only one known photo of the rear cockpit. I made a new floorplate and used spare PE and plastic to make something more realistic 8 1
BlrwestSiR Posted March 29, 2020 Posted March 29, 2020 Somehow I completely missed that you were building the two seater. I thought for some reason this was the night fighter variant. Anyways, nice job on fixing the moulding defects. Carl 3
Administrators JeroenPeters Posted March 29, 2020 Author Administrators Posted March 29, 2020 4 hours ago, BlrwestSiR said: Somehow I completely missed that you were building the two seater. I thought for some reason this was the night fighter variant. Anyways, nice job on fixing the moulding defects. Carl I have the night fighter kit as well. Have built the B version before and am now building a test shot of the trainer sprue in combination with the A version. 7
Administrators JeroenPeters Posted March 29, 2020 Author Administrators Posted March 29, 2020 Gotta love that surface detail... since i’m using the Yahu instrument panel for the front pit, i cut out the center section of the eduard panel for the trainer pit. 9
Administrators Clunkmeister Posted March 29, 2020 Administrators Posted March 29, 2020 Such is the world of building test shots, Jeroen. As usual, you da man for the job. I can think of no more qualified for this duty. Looking great as usual!! 5 1
Administrators JeroenPeters Posted April 1, 2020 Author Administrators Posted April 1, 2020 Added Eduard Brassin exhausts to the engines. And Eduard photo etch. 9
Administrators JeroenPeters Posted April 12, 2020 Author Administrators Posted April 12, 2020 Opening up some panels 7
Administrators JeroenPeters Posted April 13, 2020 Author Administrators Posted April 13, 2020 Some work on the MG151’s. Replaced the ammo feeds, added electric cables and made the loading handles from thin copper rod. 7
Lothar Posted April 15, 2020 Posted April 15, 2020 That's a fascinating build and subject I'll follow with interest. As shame it seems the front row seats have all been taken by now Lothar 3 1
Administrators JeroenPeters Posted April 18, 2020 Author Administrators Posted April 18, 2020 Working on the ip now. Took some work to make the yahu panel fit the kit parts. Make the instrument housings from rod. Removed the moulded wiring and made my own. 7 1
BlrwestSiR Posted April 18, 2020 Posted April 18, 2020 Nice as always. What colour do you paint the wires? Carl 3
