Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 Some have asked me how the fit appears to be on this kit, so I thought I’d take a quick opportunity to show you. This is simple friction fit with tape to keep the sides together. many question? If the rest of the kit is as good as this appears to be, IBG will sell me at least a half dozen more. Y’all notice how we see group builds of massed I-16s at shows? This could be the next step up from that pleasant little build. 5 1
Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 I’m just going to put this here. This is one of the things that the resin kit had issues with. 9
smitty44 Posted March 28, 2020 Posted March 28, 2020 What does the Apollo capsule have to do with a Polish fighter? 8
Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 15 minutes ago, smitty44 said: What does the Apollo capsule have to do with a Polish fighter? Cough cough. A radial powered space capsule. COOL!!! 4
Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 Still more PE bending tonight, folks. Lots more pics tomorrow, but I can say that even though there is a boatload of PE, it all fits perfectly, and if you take your time, measure three times and cur once, it will fall together like a jigsaw puzzle. This is the nicest building kit I’ve worked on in a long, long time. 5
Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 Everyone is asking about the dreaded engine, which was the downfall of many a resin build. This one is utter sweetness with honey and tulip fragrance from your favorite girl. This an exact drop fit. No glue, no swearing, no muss, no fuss. Notice how all the exhaust pipes go into the collector, which is the front of the cowl, and then all the struts supporting the whole thing against the inner cone. This was the downfall of the resin kit. Each of those exhaust pipes is supplied as a vague elbow, your job, figure out where it all rides. A jig is best... 8 1
Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 Cockpit coming right along. If you’re not opening the gun doors, all the lower PE under the floor can be left off to simplify construction, but building it on this is seriously quick and easy. 7 1
HubertB Posted March 28, 2020 Posted March 28, 2020 4 hours ago, Clunkmeister said: Cough cough. A radial powered space capsule. COOL!!! Could be a Russian design .... Hubert 6
Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 7 hours ago, HubertB said: Could be a Russian design .... Hubert I have started cutting plastic 2-3mm away from the part, and the sanding and trimming it down. No more cavities! 5
Administrators Clunkmeister Posted March 28, 2020 Author Administrators Posted March 28, 2020 The proper use of PE allows you to get results in a scale like thickness, results like you can’t ever achieve with IM styrene or even resin. After ths drys a bit, I’ll mount the few bits of PE left, the other frame, then give it a shot of Alclad aluminum all over. Detail picking out after that. 6 1
BlrwestSiR Posted March 28, 2020 Posted March 28, 2020 The more I see of this kit, the more I'm liking it. It's definitely got the correct way to PE bits. Carl 4 1
Administrators Clunkmeister Posted March 29, 2020 Author Administrators Posted March 29, 2020 Honestly folks, so far, this has been one of the most effortless builds I’ve ever had the opportunity to build. Everything just fits. Perfectly. As in a “click fit”. That’s quite an accomplishment with a 1930s aircraft design. Don’t get me wrong, this by no means a beginners kit. And you’ll need to have a good visor and plenty of lighting, because many of the parts are extremely small . But take your time and it’ll all click into place. If it doesn’t, you did something wrong. So far, kudos and two thumbs up to IBG for designing this kit. 9 1
BlrwestSiR Posted March 29, 2020 Posted March 29, 2020 That's a very impressive looking cockpit Ernie. Are you going to paint it? 4
Martinnfb Posted March 29, 2020 Posted March 29, 2020 Beautiful detail Ernie, you make it look so easy . 4
Administrators Clunkmeister Posted March 29, 2020 Author Administrators Posted March 29, 2020 1 hour ago, BlrwestSiR said: That's a very impressive looking cockpit Ernie. Are you going to paint it? Absolutely Carl. It’s all over faded old silver on the interior, then pick out the details. 53 minutes ago, Martinnfb said: Beautiful detail Ernie, you make it look so easy . Martin, the kit is that decent, it even makes me look good. 4
DocRob Posted March 29, 2020 Posted March 29, 2020 Ernie, you make one of the few actual must buys, into a desperately needed one with your great work. Thanks for the wallet attack. Cheers Rob 3 1
HubertB Posted March 29, 2020 Posted March 29, 2020 1 hour ago, DocRob said: Ernie, you make one of the few actual must buys, into a desperately needed one with your great work. Thanks for the wallet attack. Cheers Rob Sorry for your wallet, but on the other hand you will not regret it. This is a kit that can be built OOB with great results. Probably a better mojo restorer than, say, a Hasegawa P-47. Isn’t it Ernie ? Mine is under way as well, and will be - almost OOB - as well. I say « almost » because I want mine finished as the Paris 1934 Airshow P11/IV prototype. So that entails adding wheel-spats, and going for a red-and-white livery. Hubert 6
Administrators Clunkmeister Posted March 29, 2020 Author Administrators Posted March 29, 2020 Hubert you stole my thunder. Haha. We think so much alike my friend, it’s almost uncanny. You and stirred the embers for racers that were glowing deep within and the P.11 prototype demonstrator is our classic Golden Age aviation done right. I’ll be doing a Rumanian bird as well, and one in NMF too. 4
Administrators Clunkmeister Posted March 30, 2020 Author Administrators Posted March 30, 2020 Absolutely zero problems so far. Not a shake the box kit, but if a top shelf fully detailed 30s finger could be, this is it. 6
Administrators Clunkmeister Posted March 30, 2020 Author Administrators Posted March 30, 2020 It looks one solid color, but it’s not. This is pretty accurate as far as coloration goes. I’ll do some more picking out around the gun mounts, then mount the panel. I already applied a fairly heavy wash to the floor plates, and since I want to keep it fairly correct, I’m not about to go overboard on color just to get it to look “cute” 4
Administrators Clunkmeister Posted March 30, 2020 Author Administrators Posted March 30, 2020 So this afternoon was a productive afternoon. The P-47 is ready for paint, and I worked on the P.11. everything, and I mean everything lines up. Except one compressed air bottle on the inner cockpit wall under the floor that interfered with the floor fit. I obviously got the location wrong, but I pulled it off and will figure out where it belongs. I fit the panel and the headrest, and taped the sides together around it to get the alignment right. The very top of the headrest has a very slight spot where a Sprue attachment point still shows, (my bad), so I’ll prep that better tomorrow and close up the fuselage for good. So far, I’m loving this build. I’m going to also give the seatbelts a slight wash. I used the kit PE belts, and I truly, truly detest PE belts. These look semi OK, though, so for a kit review, I give them high marks compared to some of the junk we see in kits. 7 1
Bomber_County Posted March 30, 2020 Posted March 30, 2020 Ernie, really neat and tidy building, looks fabulous as ever..... 3 1
Administrators Clunkmeister Posted March 30, 2020 Author Administrators Posted March 30, 2020 52 minutes ago, Bomber_County said: Ernie, really neat and tidy building, looks fabulous as ever..... Thanks Phil. For once I had some bench time to actually produce something. Feels nice, actually 5
GusMac Posted March 30, 2020 Posted March 30, 2020 Lovely job Ernie. The seatbelts do look pretty good for PE. I truly hate PE belts especially for jets but no-one seems to do the paper type for anything much post WWII 4
