ajaycad Posted June 17, 2020 Posted June 17, 2020 Finally finished...........this was a bit of an experiment as this is the first model that I used AK panel line enamel washes rather than oils. Paints are a mixture of Tamiya and Gunze Barracuda resin seat, the belts were either RB Productions or HGW, I cant recall which I had major problems with the fit of the radiator cowling and the lower engine panels, however that was my error as I didn't follow the instruction manual sequence when fitting the engine and radiator assemblies. I should have known better !! 1
nmayhew Posted June 17, 2020 Posted June 17, 2020 always a stunning looking beast and this is no exception not sure i am a huge fan of the wash in the rivets showing so aggressively in the white of the stripes, but i can't fault the execution did you use HST for the chips? also wondering if / how the 'step strip' (or whatever it's called) weathered or chipped? the pictures are too dark btw - not doing justice to your work! PS show us the bombs as well please - can only see the edge in a pic or two
Spitfire Posted June 17, 2020 Posted June 17, 2020 Only seeing one photo up there, is there a problem. Cheers Dennis
nmayhew Posted June 17, 2020 Posted June 17, 2020 so do i now - and it's not one of the originals if that helps?
ajaycad Posted June 17, 2020 Author Posted June 17, 2020 Yes, I did think the wash in the invasion stripes was a little too aggresive, If you look at the underside of the stbd wing, in the last picture, thats probably about the right level, but this was a bit of an experiment with the AK enamel washes, and overall I'm quite pleased with the end result, Airfix have definately elevated themselves up the league table in recent years. AK chipping fluid for the chipping effect. Alclad white aluminium sprayed over the wings and fuselage, chipping fluid, then top coat. Same effect for the black non slip panels at the wing roots. Minor chipping around access panels using a Prismacolour pencil. Pictures courtesy of my 12megapixel phone camera.........I agree, not ideal I plan on taking some photos outside when the weather improves, should correct the low light issue Some bombs..... 1
GusMac Posted June 17, 2020 Posted June 17, 2020 Not seeing any images?! They've obviously been visible, so not sure what's going on.
Spitfire Posted June 17, 2020 Posted June 17, 2020 All I see apart from one photo is a road sign like a UK "no entry" road sign
ajaycad Posted June 17, 2020 Author Posted June 17, 2020 I've reposted the images..... Hopefully! 3 1
DocRob Posted June 17, 2020 Posted June 17, 2020 Great looking Typhon, I actually like the weathering and wash on the rivets. I wish mine will come out equally good some day. Cheers Rob 2
Bomber_County Posted June 17, 2020 Posted June 17, 2020 Absolutely stunning, then weathering is spot on........congrats on a fabulous build..... 2
GusMac Posted June 17, 2020 Posted June 17, 2020 Wow, that looks great. I've got one of these in the stash with a bunch of AM but haven't had the courage to start it yet. Not sure if this is encouraging or disheartening as I'm sure mine won't look that good. 2
Administrators Clunkmeister Posted June 17, 2020 Administrators Posted June 17, 2020 Dangit, I can't see the pics! And the Tiffie is one of my favorite aircraft, and the internet is here holding out on me!!! 1
Administrators Clunkmeister Posted June 17, 2020 Administrators Posted June 17, 2020 Ok, a few have come through for me. GOOD LORD!! That's incredible. Like others here I'll join in and say "AMAZING WORK"!!!! 1
GrahamF@Iconicair Posted June 17, 2020 Posted June 17, 2020 looks Fab, Love the interior painting especially. Graham 1
