Rowdy Posted December 29, 2020 Posted December 29, 2020 Dear all, Started with rivets on the Focke Wulf A8/R2 kit from the hand of Revell. Loads of work to do before starting the assembly! First I want to rivet everything 14
KevinM Posted January 2, 2021 Posted January 2, 2021 So Rowdy what's exactly the process for riveting? tape the line?using the recessed panel lines? it all looks really good nice and straight.Kevin 5 1
Rowdy Posted January 2, 2021 Author Posted January 2, 2021 4 minutes ago, KevinM said: So Rowdy what's exactly the process for riveting? tape the line?using the recessed panel lines? it all looks really good nice and straight.Kevin Hi Kevin, Thanks!! I’m using a rivetting and a rescribing tool, and a aluminum hook which I use to make the straight lines with. But not all the lines are straight as this is me 2nd complete model which I do The base of these new Revell kits are quit good, some panels are not in the correct place as we may believe the Kagero drawings. I Always start with the panels which are placed on the right place in the kit, these are direct the starting point for al the rivets. 4 2
harv Posted January 2, 2021 Posted January 2, 2021 It really surprises me that neither Revell or Hasegawa kits have no rivets.....harv 4
Bomber_County Posted January 2, 2021 Posted January 2, 2021 I to find intriguing, nice neat riveting, around compound curves do you use a flexible guide.... 5 1
Rowdy Posted January 8, 2021 Author Posted January 8, 2021 First photo etch stuff is coming together! 11
Martinnfb Posted January 8, 2021 Posted January 8, 2021 Precise work, I will follow with interest. Cheers Martin 4 1
SapperSix Posted January 9, 2021 Posted January 9, 2021 Fantastic Build!! The photo etched flap work looks very clean. 4 1
Kaireckstadt Posted January 9, 2021 Posted January 9, 2021 12 hours ago, SapperSix said: Fantastic Build!! The photo etched flap work looks very clean. Really awesome Rowdy and great job with the riveting and the brass flaps! Cheers Kai 4 1
Kaireckstadt Posted January 10, 2021 Posted January 10, 2021 18 hours ago, Rowdy said: Flaps again... Looks perfect. This is really and add for mine which I should think about... 3 1
Rowdy Posted January 10, 2021 Author Posted January 10, 2021 Sprayed the flaps today. Primed with black, then sprayed a layer of silver, after that the RLM02. 7
Bomber_County Posted January 10, 2021 Posted January 10, 2021 1 hour ago, Rowdy said: Sprayed the flaps today. Great work, who does the flaps and PE you’re using? 5 1
Rowdy Posted January 10, 2021 Author Posted January 10, 2021 1 minute ago, Bomber_County said: Great work, who does the flaps and PE you’re using? Thanks! The flap set is from the magnificent Eduard! 4 1
AlanG Posted January 12, 2021 Posted January 12, 2021 Loving this build. Wish i had the balls to give rivetting a go. I 've done it in real life (joys of being an Airframe Technician) but never tried it on a model aircraft lol 7 1
Kaireckstadt Posted January 20, 2021 Posted January 20, 2021 2 minutes ago, Rowdy said: This evening I went... Cockpittin’.. That looks great! Beautifully weathered! 4 1
