CF-18 439 Sqn Tiger Meet
Thanks folks! Progress is coming along nicely. Better than I had thought it might.
I installed the resin intakes. By leaving the front half unglued it was easy enough to bend them apart slightly and slip in each intake. Before I did that, I painted the interiors in white and added the engine fan faces.
Here you can see both intakes in place and the front still unglued.
Once the CA dried, I aligned the sides and houses them together.
Next up was the fuselage sides. To get the edges lined as best as possible, I inserted a piece of sprue to act as a spreader bar. This was temporary as it lifted the gear bay high enough so I could glue it to the side but too far from the top.
I then glued the side panel in place along the MLG bay and fuselage bottom only. PXL_20210829_204036755.thumb.jpg.e07c2738722aec6a86934a8afafb90dd.jpg
This left a small gap along the sides.
But once the bottom seam was dry I inserted a knife blade and pushed the spreader bar loose. The fuselage gap then closed up.
Once this side dries, I'll see if I have to do the same on the other side.
I closed up the front fuselage halves as well. This was straightforward without any issues.
These resin-intakes are a great addition and the view through them to the 1st compressor stage is awesome. Will buy these for mine too (if they are available).
I really like your approach how to solve the problems. Will keep your postings in mind when I build mine.
Curious to see the next update!
Great work on the intakes and of course the absolutely gorgeous looking pit. It's a good idea to strengthen the joins on such a big bird, to have a better control of the gaps and a sturdier plane in all. You may start to raise a tiny bit of interest in me into a plane, I never had any love for, shape ways. Keep on with your good work Carl.
1 hour ago, mark31 said:
nice going on the hornet.
Mark
Thanks Mark!
Thanks Rob! I've been more of an F-16 fan myself and my favourite oil burner is still the Tomcat but the RCAF did so many unique schemes that they've slowly won me over with the Hornet.
Thanks gents!
Got the second vertical side of the intakes glued in place.
I still had to do some sanding but it wasn't too bad. There's a bit of CA for filler too around the intake join but again, not much
Now onto a bit of re-scribing the odd panel line or two.
The CF-18 is back on the bench. I finished off engraving the panels lines that were sanded off. I'll double check them when I get to primer.
I took a look at the resin replacement vertical tails that I have. They're nice but one was a hit warped and has a bit of mould slip.
The big difference between it and the kit ones are the omission of the centre radar fairing.
I used a thin chisel to shave it off.
Then, once it was flush I had to scrape away the base plate of the antenna.
One more to go.
