Excellent work Mark! You should enter this as a collection at a contest.   Think it'd do really well.
If I had entered 7 at the show here a couple weeks ago, I would have doubled the entries.
in all honesty, none of these will be show winners, just some offerings for the styrene gods.
Amazing work, man.  My limit of the same type is two...
But I have only 1 P-40 kit.  That needs to have a little oil canning.
Kinda nervous about starting, really.
I think I would reconsider doing 7 again, maybe 3-4 at once. 7 takes a LOT of bench space. Although I will still argue that it’s more efficient to build 7 at once, even if it takes me 6 months, that’s still a better than one a month average. Last year I built 4 LSP’s, this year (2018), I built 4 by June, but have not finished any since then. I started a WNW kit that is 60% done, and I have the 7 P-40’s on the bench, and I recently added 2 zeros. If I can actually get the P-40’s done this year, with one Zero, I will have finished 12 on 2018. Which would be a very good year for me. 2019 is going to be the year of Multi engines, Cold War jets, and helicopters.
I don't count how many I complete a year.  But I really need to get cracking on my P-40.  It needs to be show ready by 24 August.   I want it to look like this:
So much to undo the work of the mad rivetter.
Gaz
That is so beautiful...are you doing foil? I have no clue how to do foil, I had tried years ago with the big metal foil sheets, it was a disaster. For me, I would probably do good old Alclad chrome, not perfect but acceptable.
Yes, I'm going to foil it.  It's really much easier than you might think.  I start with a piece of the thinnest, cheapest foil that is about 5"X7", apply the glue to the back side then let it dry.  Then I cut for each separate panel unless there are small panels together with no complex curves.  Once when foiling a 1/48 B-29 (that I never completed) I needed some pieces that were over 8" long, and they were a bit fiddly.  If you ever get the urge again, let me know, and I'll show you where I started.
You fellas that can get a suitable finish from Alclad and other metalized paints impress the hell out of me.  But my non-foil metal painting has been rather lackluster.  I still use foil for oleos.
Gaz
  • Members
Gaz
I actually enjoyed doing my Trumpeter P-40, just watch the upper cowl it's a little tricky.  Some aftermarket exhausts would be nice for it.
I agree, its a better fitting kit that the Hasegawa, the Trump P-40 was easier and quicker, just don't waste any time painting anything other than the top of the engine if you will have a lift off cowl, you cant see any detail below it..
  • 5 months later...
I'm going to be digging these off the SOD soon. Some of these guys are almost ready for paint. Need to sort them out and get cracking...
Yes...  off the shelf of doom.  Reminding me that my P-40 still sits unloved.
Gaz
Yes, it is quite literally a shelf in my stash closet with all 7 of them lined up, awaiting my motivation. I sometimes hear them calling me from the closet, begging for paint.
Paint me....   oooohhh  Paint me....     Won't we look awesome on display...  oooohh
  • 9 months later...
You are nuts, sir, but my kind of nuts!! All that chopping away on the M to F conversion looks very familiar. Forgive me, but I think you need one with a Russian engine......
Family photo again. 3 ready for paint, 1 in progress, 1 waiting for its turn. 2 more are still on the SOD and need more sanding than I want to do right now.
