Hi all,
As some of you may know, this time last year the modelling community lost 'Des Delatorre', a great inspiration and owner of the 'WW1 Aircraft Models' web site and forum.
Dave Wilson, who now runs the forum, has organised a memorial group build in honor of Des.
I thought I'd like to attempt a double build, consisting two Fokker D.VII aircraft and two figures.
A complete Fokker D.VII - Wingnut Wings Kit No:32027.
A 3D printed 'Aviattic' skeletal Fokker D.VII from 'ShapeWays'.
Anthony Fokker figure from 'Aviattic'.
Photographer figure from 'BlackDog Models'.
Mike
Hi all,
I'm making a start on the 'full built' Fokker D.VII.
Cockpit items (not yet completed) and flight control rigging and cockpit frame cross bracing.
Mike
Looking forward to see you perform one two of your magical tricks on building these kits :popcorn:
This seat is already amazing.
Just one comment : even though I am sure they are not that visible IRL, these molding seam lines on the frames would worry me ;) , but then it’s just me ... and maybe that is one (of many) reasons why my kit output is so abysmally low ...
You sure do some magic here. I love the internal wiring and the Lozenge effects. For my to build Fokker D.VII, I planned something similar, with the use of Aviattics Fokker figure, but without the stripped D.VII.
Hi all,
The first cockpit is nearing completion.
I still have to fit the instrument panel, compass, tachometer, shoulder harness and engine bearer frames.
Also finish rigging the various control lines and the hand throttle and gun trigger cables,
Mike
cockpit14.jpg.
Hi all,
The first Fokker D.VII cockpit is complete now and fitted into the fuselage.
I've added detail, such as instrument cables, grease pump and fuel pressurization pump pipes, under floor cross bracing, engine control rods etc.
I still have to finish it by adding the pilots shoulder harness, which will be attached to the seat mounting frame through the additional linen 'wind break' behind the pilots head,
Mike
Hi all,
The additional linen baffle (wind break) that was fitted to some Fokker aircraft is done.
The shoulder straps passed through slots is this baffle and down to be attached to the cross bar of the seat frame bulkhead, which had at the top the standard linen baffle.
The coloured shot below is from the Canadian restoration of a war prize Fokker D.VII. It was comprised of parts from different Fokker D.VII aircraft, including OAW built Serial No:6506/18, 8318/18 and 8502/18 and was partially restored in 1963.
The B/W shot is of a similar baffle fitted to a Fokker DR.1.
Mike
Hi all,
Now that the fuselage is buttoned up I've moved onto the engine.
As usual not an OOB build. Modifications will be (I hope).
    Complete timing gear
    Fuel priming cups
    Spark plugs (late type)
    Intake manifold nuts
    Ignition leads
    Engine control
    Coolant pipes
    Engine sump apertures
    Oil sight glass.
First off is the removal of the coolant pipe for the cylinder jackets, which is pre-molded in between each cylinder.
Also the conical vale springs.
Mike
Hi all,
The cooling of the engine cylinders was carried out by cooled water from the radiator being fed by pipes to the water pump, located on the bottom, rear of the sump.
This water was pumped through an outlet pipe and through interconnected stub pipes at the bottom of each cylinder.
The water was then pumped up through the
cylinders jackets and out through the interconnected stub pipes at the top of each cylinder, then forward to the front of the engine and back to the radiator for cooling.
The kit supplied cylinder block has the pre-molded coolant pipe for the cylinder jackets, but it looks unrealistic, as it extends through and between the separate cylinders, presumably to act as a solid fixing base for the cylinder block.
I've cut this pre-molded pipe away to separate the cylinders and replaced it with short lengths of 0.85 mm diameter plastic rod, with a chamfer at at end to fit the contour of the cylinders.
Mike
Hi all,
A magneto was located on each side at the rear of the engine. These were driven by the engine through a split drive shaft. Attached to each magneto were six ignition leads, which  were routed through support tube attached to each side of the cylinder block. Each cylinder ignition lead exited the support tube through an aperture and was then attached to the cylinder spark plug (two per cylinder). The pre-molded support tubes supplied in the kit seem under sized, so I replaced them with micro-tube.
The sump of the engine was essentially a ‘wet’ sump, as the oil reservoir was in the rear and lowest part of the sump. The oil was drawn from this reservoir by the oil pump (located at the rear of the engine) and distributed through the engine, after which it returned to the reservoir to be recirculated. The forward part of the engine sump appears to have been open, as can be seen through the open apertures and the front of the sump in the following photograph. An oil contents sight glass was located on the sides of the oil reservoir at the rear of the sump. Some engine installations had an oil tank installed in the engine bay and outside the engine, although this particular kit does not have this feature.  I've drilled out the apertures and created a sight glass on each side - the 'glass' will be made of PVA adhesive once the engine is built.
Mike
