BlrwestSiR Posted June 15, 2020 Posted June 15, 2020 Truly impressive looking build. It's really coming together now. Carl 3
Axeman Posted June 22, 2020 Author Posted June 22, 2020 Ok. The one remaining gear shift (really not sure what it is for) I have broken and repaired 3 times. Hopefully that will be the last. Worked on the seats with a brown layer underneath, then hairspray and a coat of nato black, lighter on the raised areas. Pin washes on the cover and cable structures as well as installing the cabling on the rear. Applied engine dirt and grime on one side. More to come. 8 1
Axeman Posted June 25, 2020 Author Posted June 25, 2020 Did more weathering on the engine. Still more to do by the fan. Next I finished up the seat as well as the weathered the back of it. The exhaust stack (white styrene) I am planning on replacing. The kit part is not that good for detail. Did some more weathering at the bottom of the track area and around the inside of the front wheel. That is it for now more to come. Still have some dirt to add as well as the cabling between the front and the back. 7
Axeman Posted June 29, 2020 Author Posted June 29, 2020 Did some more weathering around the engine and fuel stains around the fuel cap. Glued the cover for the engine, attached the tracks and tested the blade and driver cover. I keep testing different ways to apply the pigments. Getting near the end of the build. Also, finally put up the paint racks this weekend. Gives me more space around the desk. 6
Jeff Posted June 29, 2020 Posted June 29, 2020 what yellow did you use, it looks to be right on.... love the weathering.... 2
HubertB Posted June 29, 2020 Posted June 29, 2020 Beautiful work ! These earth-movers really make for interesting modelling subjects Hubert 3
Axeman Posted June 29, 2020 Author Posted June 29, 2020 Hi Jeff, I used a mix of XF-3 yellow and a little XF-64 NATO brown. Mission models has a construction yellow that I tried to get close to. I did not use it as I was afraid of to big of chips using that paint. The chipping color was the nato brown and black. If I would do the chipping color again I would you just red brown or the nato brown. The cover on the engine and the roof cover I used a lighter yellow oil paint trying to get a faded affect. 3
Jeff Posted June 29, 2020 Posted June 29, 2020 2 hours ago, Axeman said: Hi Jeff, I used a mix of XF-3 yellow and a little XF-64 NATO brown. Mission models has a construction yellow that I tried to get close to. I did not use it as I was afraid of to big of chips using that paint. The chipping color was the nato brown and black. If I would do the chipping color again I would you just red brown or the nato brown. The cover on the engine and the roof cover I used a lighter yellow oil paint trying to get a faded affect. Thanks, and it is a Masterful job of weathering................. so many techniques to try............ 2
CrankyCrafstman Posted June 29, 2020 Posted June 29, 2020 Hey Axeman Great build! I've been using this to help on my 1/25 AMT Caterpillar D8H and it sure has helped. Thanks Ron G 3
Administrators JeroenPeters Posted June 30, 2020 Administrators Posted June 30, 2020 Really cool weathering. Lovely 3
Axeman Posted June 30, 2020 Author Posted June 30, 2020 Hi Ron, glad I can help. More weatherIng to come with pigments 3
Jeff Posted June 30, 2020 Posted June 30, 2020 This is REALLY good stuff, Tim, I am going to try and use this thread as a tutorial guide to weathering..... for my Cat 1
Axeman Posted July 1, 2020 Author Posted July 1, 2020 Building my own exhaust stack. Looks better that the kits. added some weather with pigments around the tracks and the blade. 4
Axeman Posted July 3, 2020 Author Posted July 3, 2020 Well, the carpet monster struck. I lost one of the clear plastic head light covers leaving only 3. Developed an alternate plan to show it as damaged. Use brass tubing to make the socket where the light would go and fittings around it. Also found a photo etched ring that fits the outer rim of the housing. Just need to paint it. Glued the cabling supports in the front and rear and tested the cross beam bottom. 5
Jeff Posted July 3, 2020 Posted July 3, 2020 For my 2 cents worth, I would leave the ring as is, because there would be a gasket there and /or the paint would or could be rubbed off due to the gasket rubbing the paint off light housing over the years, I think it looks spot on ...................... as is... 1
Axeman Posted July 3, 2020 Author Posted July 3, 2020 Do you think the wiring for the lights went down the inside of the poles or outside. I have not found any pictures with the lights as they have them in the kit. 3
Jeff Posted July 3, 2020 Posted July 3, 2020 2 hours ago, Axeman said: Do you think the wiring for the lights went down the inside of the poles or outside. I have not found any pictures with the lights as they have them in the kit. All the old ones I ever operated had all sorts of wires and stuff twisted around the outside of the pipe, and under the roof, usually not tied up quite tight enough for a guy to hang himself if not careful getting onto the machine.... 1
Axeman Posted July 14, 2020 Author Posted July 14, 2020 Well, it is finally done. Created my own exhaust stack. Added wiring for the lights running the wiring under the floor plate and have it connected to an on/off switch. Added dirt to the tracks and dozer blade. Here are some pictures of end result. Tim 5
CrankyCrafstman Posted July 14, 2020 Posted July 14, 2020 That looks absolutely amazing Axeman. Ron G 2
Bomber_County Posted July 14, 2020 Posted July 14, 2020 That is absolutely gorgeous, love the weathering......wow........congrats 2
Axeman Posted July 14, 2020 Author Posted July 14, 2020 Thank you. It took a lot longer than I anticipated. 2
