P-40 / Kittyhawk Mk I 112 Sqn Neville Duke - GA-V / AK578
wings and stuff...
as i said i glued bottom on first, then added the top pieces
the gun cover parts are moulded as rectangular inserts but there is no panel line on the real thing...
5DF3280A-300D-4770-92FE-74D59BCF2467_1_105_c.thumb.jpeg.1c33844dd0e939a7e3e3ba1818187678.jpeg
i had thought taping round where i don't want scuffed was clever and whilst the idea was laudable, you can (as i did) end up just shifting / creating another problem
1EC1EEE6-FB41-4A04-AF69-7E660E603271_1_105_c.thumb.jpeg.b8c509883294124b9f48a3e4325e6740.jpeg
this is mr dissolved putty laid on with a small flat brush, thinned with some Mr Levelling Thinner; sands quite nicely as you would expect
56588B8F-08D0-4C8D-B374-26ECFD063066_1_105_c.thumb.jpeg.f77622530ee6916c300c409bfbff8fca.jpeg
29449ACD-443E-48A4-B927-C82ECCDBE3E9_1_105_c.thumb.jpeg.23ca4d4f69e3547e27d421cffecbdfef.jpeg
a note about the wheel wells - the CMK inserts do not fit well - they were just too small to fill the round wheel well hole which was sooo frustrating as these birds would have had canvas covers
as you can just see above i ended up going without them
they are painted (at present) the US equiv of Sky - i have taken a stab and used MRP RLM76
my conundrum is whether the wells should actually be Interior Green - I am beginning to think that they should be
they will be a pain to paint and weather correctly again, but it shouldn't be impossible
i could even go with some cheeky hair spray chipping as well
the landing gear blister thingies were glued on only *after* i was satisfied with the wing root and leading edge inside of the blister
i was dreading this area but luckily it did not turn out too bad
0555897A-817C-4348-B62E-FB27A02BCFEB_1_105_c.thumb.jpeg.2fe45379c8045612f2c46bb94161c718.jpeg
DE606987-529B-43CB-AA4B-6820B7CDF784_1_105_c.thumb.jpeg.ee36838ace473312d41bd383666c450f.jpeg
here you can see the wheel wells...hmmm
anyway moving on
early P-40s like this one did not have bomb racks; some research and i was told that the bottom was just flush, so more filling and sanding
144E3278-E975-4E36-AE75-B4E3C836ED7B_1_105_c.thumb.jpeg.22feed25d5e9aa84c610b4db4703bc24.jpeg
7C8B8679-5742-4EB5-9FD4-E78561330198_1_105_c.thumb.jpeg.3ba23e35e1c36332dba95eccab58694f.jpeg
that's all for now
i am off to the pub
  • Like 11
12 hours ago, Anthony in NZ said:
Awesome work there, truly one of the most detailed explanations of assembly of the Hasegawa kit.  Shame about the canvas covers as I have those too....hmmm
Great inspiration
Cheers Anthony
thank you
in retrospect i should maybe have persevered?
another reason i was hesitant was that the hassy kit links the wheel well construction with a wing spar which aligns the dihedral
going slightly 'off piste' with my construction method meant i was quite keen still to be able to take advantage of it
next time - and that will be a long time in the future! - seeing as i didn't have any problems in that area, i might have another go at using the covers
i actually tried to trim them and fit them in *on top* of the normal wheel well, but just ended up cutting them to sh*t because i was going about half-arsed lol
anyhoo...
not sure if i mentioned this before but i found it a bit of an eye opener to cut bits of sanding sponge off and use forceps / tweezer thingies to get in and sand quite 'forensically'
F2CD66D1-F718-4A76-85F4-E95216ABCA38_1_105_c.thumb.jpeg.23bab33a9635b339cced94629ffaa13d.jpeg
if i had used this approach earlier in the build i would have either got better results or at the very least achieved the same in less time / with less effort
i found that i had not attached the front canopy correctly - the fit was fine on dry fit, this was entirely user error - so i had a small area requiring filler
again probably not showing anyone anything new, but i found putting masking tape either side of the slit i was trying to fill, then brushing on some Mr Surfacer 500, allowing to dry, then sand the area on top of the masking tape off (rough grade fine for this), remove sanding paper and then use technique as shown above provided a fairly quick and very pleasing result
E6C4652E-BA13-45AF-9EB2-BAE5F78914FF_1_105_c.thumb.jpeg.69730a0a86938f615c754ee05d8306fc.jpeg
propeller blades
hassy have some really f*cking annoying raised lines to signal where the yellow tips should be
D2A0BCAB-5FDF-4D90-B86E-B1615A71E21C_1_105_c.thumb.jpeg.d61b4ec02fda5f86e0e84c5d358e6eb4.jpeg
9B53841F-6A18-47BC-842D-813440601B66_1_105_c.thumb.jpeg.7882cb584b464cdfdf8248d78cd28dfa.jpeg
silver sprayed on rear edge for chipping
12A2823D-9F8B-4989-A4B5-9CC13C22E976_1_105_c.thumb.jpeg.1b5d3c2c254e11e5da75944b61508b86.jpeg
quick bit of masking then yellow goes on - none of this 'must lay done a grey blah blah' (it's MRP - you can spray anything over anything!)
46F6B0EF-82A0-49A4-9479-E2D8ECC3830E_1_105_c.thumb.jpeg.36630abcf6d618080a771b8637d5b8d7.jpeg
hairspray then goes on, then various colours all mottled on (not on the yellow) to give the blades some depth
one of the things i try to do now is not just have 'slabs of colour' - so literally any old colours to hand can work, it doesn't need 'over thinking'
then water and stubby brush for some chipping
results were so so because i sprayed direct from can and think the hs went on a bit thick
but still reasonably pleasing
967981B2-A25C-4D73-B798-9786EA0506CF_1_105_c.thumb.jpeg.89274c623d4003ad32082ea0b22ce7de.jpeg
ADF78E8F-E808-49E6-B5FC-72C8E1680AD8_1_105_c.thumb.jpeg.d486d39ed325edc26a222633574ae179.jpeg
the chipping through the yellow is hard to pick at anything other than close up but as you can see from above is indeed there
5BCD5345-04CB-4B0D-8074-52ADB6D197A1_1_105_c.thumb.jpeg.d352fca93dbb968769564937edf4c5c2.jpeg
the front side - here you can see what i mean about depth and variation...the bigger the scale, the more you need this approach in my view or you just end up with that 'big toy' look
437A3474-E1FA-48A8-B182-EA294E32CAF1_1_105_c.thumb.jpeg.8bac1a4282cda2da5cc723b92d92a67b.jpeg
same sort of approach for the spinner
i don't think the panel line around the prop hole is correct but i have no interest in investigating further on this one!
some sanding and polishing as my part was scratched to sh*t in the box (my bad on that)
3ADEA00B-1432-41F8-9537-BFF3D6A3B95C_1_105_c.thumb.jpeg.811703ab8a9494e03ca69d35d989cc64.jpeg
half way through the various mottles... looks a bit dodgy here but to naked eye finished article looks similar to prop blades, just slightly different
all pics are iphone btw and for some reason when i drag and drop to LSM on my Mac it says they are exported in low quality etc so sorry about that
E43CE091-F18D-4603-AC04-3B0326821A44_1_105_c.thumb.jpeg.1be9eda2e6ef13db7f0e9924bbf0a67e.jpeg
final update for today i think
the horizontal stabs went in and were VERY tight
i found that putting both wings in about half way and then pushing them together worked - with a bit of grunt they snapped in very nicely
but putting in one wing first and then trying the other and i found that no amount of force would make the second go in
just a small amount of Mr Surfacer 500 for underneath where the gap was slightly larger...and then some light sanding and all good
D7BD0FF4-6304-4C19-8AC8-45A8978E2CB0_1_105_c.thumb.jpeg.b409b48645f1c83e91004d7087c95576.jpeg
500 not needed on top - i probably could have got away with just sanding tbh
031C0A5B-9D7B-458F-AC70-83252D3E80EE_1_105_c.thumb.jpeg.5a5ed9dcadf100e6826cb59cd9345a84.jpeg
catch you all later
time for some gardening!
finishing (I think) the prop blades
I have the Barracuda decals but i only ever use decals when there is no alternative
luckily there is - HGW wet transfers from my P-47!
no idea if the text is correct for a P-40 - probably not - but 1) at least it is for a Hamilton prop and 2) even in 1/32 you cannot read the text unless under magnification
8207393D-9CEE-4459-BD0D-68500BA39601_1_105_c.thumb.jpeg.41f2c1c954c35a7dfba6c151945d844d.jpeg
tools used shown below, plus a small bowl of water
A20047AD-7D5A-4DD0-B25A-14C3182C7D80_1_105_c.thumb.jpeg.cd16e5ebe8f0a4ab10643c8d73ab49f0.jpeg
54871312-C7CE-4EE7-9F66-2C10598DC2C4_1_105_c.thumb.jpeg.9e2daacaa3791f62d260eceb131e2cfc.jpeg
for those who haven't used these things before, fear not - it's dead simple...
fyi paint surface is smooth, not because of gloss coat or 'the F word' but because I sanded the surfaces of the primer coat, and MRP goes on super smooth.
dip in water just like a decal, then slide the transfer off the backing paper and put in place on top of either some Mr Mark Softer, Micro Sol or similar.
use cotton bud / paper towel to press down and push out all the fluid from underneath ensuring a good 'connection'.
below shows transfer in place still on the carrier film.
94023E55-00F4-48F2-940D-5EED8AF68A57_1_105_c.thumb.jpeg.f7346662d17573a3a2be556b1deac013.jpeg
i usually wait 6-8 hrs or overnight (hey it's like I'm using enamel paints lol) then use a toothpick to scuff an edge and remove the film
depending upon the strength of setting solution, you may get a faint 'ghost' where the film was, but i found this disappears either by wiping the area with a damp paper towel / cotton bud, and if not then certainly by the time you apply final finish - MRP matt varnish in this case.
the finished article is literally as if a tiny person painted the data on - there is no ridge or film - none of the dreaded silvering bs you roll the dice with decals etc etc.
610AAD38-2E1A-4668-89B2-F393210E7B4E_1_105_c.thumb.jpeg.f5a7a2eda1e9f4a354545c3077cd6017.jpeg
1A9D0109-203B-41EC-95B6-68DCB4ABC27D_1_105_c.thumb.jpeg.babffeafadc48e88f52447c3dfac60f4.jpeg
the finish is pretty bullet proof so you can apply oils, enamel washes etc over the top
i have also seen guys sand bits away to simulate wear, but have not done this myself yet
i used HGW wet transfers on my P-47 as well - there is no hiding place on a NMF for decal carrier film - and they performed flawlessly
anyway, hope the tutorial helps a few people 'break their wet transfer cherry' :)
cheers
Nick
Looking good, I have just used the HGW wet transfers on my PCM Tempest and they are easy to use and work great, vastly superior to decals, for me as I am useless with decals.
Dennis
Great tutorial, and you are lucky, that the HGW's worked so good for you. I had lots of problems with these last week, which almost ruined my actual Hellcat build. I did everything according to the manual (or like you described) and had lots of wet transfer lifts, while removing the carrier film very carefully. If the stay on, like on my prop too, they look great, but to my eye, the product does not have reliable results, specially the larger wet transfers, like the cat fangs and eyes were problematic. The stars and bars and small stencils worked better. I switched to decaling then. I tattooed my Mig-31 with myriads of stencils and had only little lift probs, but on two different occasions, the wet transfers were not usable or to put it positively, they are for the friends of heavy chipping ;)
  • Sad 1
Hey DocRob
sorry to hear of your issues with the wet transfers
i would not be afraid to contact HGW directly and explain what happened - maybe it was a dodgy batch etc?
HGW concede that they have not yet mastered the process for multi coloured decals which are very involved eg some intricate nose art
i recommend them only because they do seem to have taken the fear / unpredictability from the stencilling / small decals
best
Nick
Thanks Nick, the biggest problems were indeed with the bigger and multi colored wet transfers, with the exception of the large US insignia, which went on problem free.
On the MIG, I used them only as stencils and they performed well, with only tiny lifts, which would be normal on a big grey Soviet beast.
With the Hellcat, I removed the wet transfers, which was not so easy, because they adhered very well, exactly 1 mm beside a lifted part and fitted the supplied Cartograph decals over, as best as I could.
I will give them one more chance, possibly, when I build my F-4B Phantom, where they could make life much easier, as you can apply stencils grouped in places.
Anyway, your P-40 build is exceptional and fun to follow. Keep up the great work.
On 6/3/2021 at 6:03 AM, Wingco57 said:
Great progress Nick. The P-40 used the Curtiss Electric prop, but don’t tell:)
:hsmack:
he he no worries
yes of course you are right and I am a numpty lol
it should look reasonable enough once the prop hub is on
in other news I have received a better copy of one of the two known photos of this airframe and I have now been ‘converted’ to believe that the spinner is red, and not black as I had previously believed
so I guess I have some respraying to do
cheers
Nick
One method I have found that works well is water soluble Vallejo Plastic Putty. Just squeeze a bit along the seam you want to fill then wipe off the excess with a wet Q-tip. Comes in very handy and negates the need for sanding, etc. :)
Not too much progress recently
I’ll go with the Quickboost landing gear doors primarily because they don’t have the shitty ejector pin marks (the kit parts are actually very sharp).
The small door will fit very nicely, but the larger door will be fiddly to attach - neither upgrade nor kit part has a large mating surface and I don’t think the engineering is very good here.
these doors will be us sky grey eventually  - as will the main parts of the oleos - but I thought I would do some hs chipping first
the tail wheel doors will stay interior green
