Thank you all for the nice comments.I have primed and black base inverted ready for some paint. This way of black base I have seen done on a D9 elsewhere with great result. Also had a play with painting landing gear covers.
A quick update, painting  rlm 74 75 and 76. And my 1st go at Montex paint mask . Can't wait to paint the insignia hope that works out.
Ohhh, so nice! I 've been waiting patiently for my 190 fix and it was well worth it. Thank you for that, flawless airbrush control.
Martin
Martin
Cheers Martin, here's the defrost pipe before i bent it to shape
1 hour ago, DocRob said:
Nice paintjob, love the shining through effect of the final coat.
Cheers Rob, yes this effect i have seen, and thought it would be a great to have ago. Just hope i can pull it off once weathered.
  • Members
Really, really nice!  I'll interject that I've read most Sturmbocks had the cowl mounted MGs removed, sometimes the troughs were faired over as well.
Mike your so right, i missed that .i will remove for sure. Thank you.
Hi one and all,  another little update. 1st off painting insignia for me, have i crossed the line?. A joy to do ( i did do a little touch up here and their) but it's worth it! Hope you guys like it.
30 minutes ago, Bomber_County said:
stunning airbrushing skills, when I mask and then lift it off, the base comes with it:wallbash:..........what paints are you using.....
Hi BC, tamiya cut approx 50% with x20a tamiya thinner.
Primed with mr surface 1000 again cut 50% with mr colour leveling thinner gives me a solid  smooth base for paint.
Fantastic build and paint job. I'm just catching up with it now.
Paint masks really are the way to go in this scale. They can take a bit more prep sometimes but I feel it's usually worth it.
Love it, the treatment turned out great, the effect on the black cowlings is very well articulated. Are these rivets only highlighted or made by HGW?
