BlrwestSiR Posted May 1, 2023 Posted May 1, 2023 I got the tracks for the E-100 assembled and painted. Fur came to supervise the paint job. First side is on. The tracks go together easily enough but also fall apart almost as easily. Made it a right pain to get it on. 7 1
BlrwestSiR Posted May 1, 2023 Posted May 1, 2023 I just glued the second set of tracks on and compared to the first set, they went on much better. The turret is up next and then paint. Next to the Panzer III I finished last week for a size comparison. 11 1
Peterpools Posted May 1, 2023 Posted May 1, 2023 Carl Looks might good and she does dwarf the Panzer III. 3 1
BlrwestSiR Posted May 2, 2023 Posted May 2, 2023 Couldn't decide on a camo scheme for the E-100, so I did both! First one, I did some ambush spots but didn't like the way they were turning out so I painted over them. And the other side. The circle dot camo was just taking way too long so I'm glad I started with the skirts. Made it easy to stop there. As for the hull, I'm leaving that in the dark yellow. Since much of the tank is a what-if, I'll just say it's a rebuild with recycled parts from previous ones. Yes, Fursnake was in my lap while I worked. Not that easy when she's trying to bite your airbrush. 5 1 1
DocRob Posted May 4, 2023 Posted May 4, 2023 Playing around with this one. Could be my next project. The DO-335 from Hon Kong Model. Easiest way to depict a twin engine fighter , but it's huge. Some clever engineering was incorporated along with very detailed plastic surfaces. The fit of the main parts looks good, the engine cowlings (front and side) can't be proper test fit, because they have hinges casted on, which need to be cut away for a closed bird. I'm not finally decided, I might open one side and leave the other closed. Cheers Rob 8 1
BlrwestSiR Posted May 4, 2023 Posted May 4, 2023 2 hours ago, DocRob said: Playing around with this one. Could be my next project. The DO-335 from Hon Kong Model. Easiest way to depict a twin engine fighter , but it's huge. Some clever engineering was incorporated along with very detailed plastic surfaces. The fit of the main parts looks good, the engine cowlings (front and side) can't be proper test fit, because they have hinges casted on, which need to be cut away for a closed bird. I'm not finally decided, I might open one side and leave the other closed. Cheers Rob Funny, I had the HK Do-335A kit out last night looking at the contents. I've got the ZM two seater in the stash as well. Big difference is that HK gives you the nose weights that you need to prevent a tailsitter and the ZM doesn't leave you enough room for the same because of the internal detail. 2
BlrwestSiR Posted May 4, 2023 Posted May 4, 2023 May the 4th be with you! So for all the Star Wars fans who get the reference, I did some work on my Millennium Falcon. I need to finish the decals for the entire lower side and then the weathering. Fursnake was not impressed that the Falcon was in her spot, ie- my lap. And tying into Star Wars day, I took my sons to see the 40th anniversary release of Return of the Jedi at our local theatre. While there, I realized I was 12, the same age as our oldest when I saw it in theatres for the first time. 3 5
GusMac Posted May 4, 2023 Posted May 4, 2023 3 hours ago, BlrwestSiR said: May the 4th be with you! So for all the Star Wars fans who get the reference, I did some work on my Millennium Falcon. I need to finish the decals for the entire lower side and then the weathering. Fursnake was not impressed that the Falcon was in her spot, ie- my lap. And tying into Star Wars day, I took my sons to see the 40th anniversary release of Return of the Jedi at our local theatre. While there, I realized I was 12, the same age as our oldest when I saw it in theatres for the first time. Yep, the cat does look pissed! 😆 1 3
PanzerWomble Posted May 4, 2023 Posted May 4, 2023 31 minutes ago, GusMac said: Yep, the cat does look pissed! 😆 Cat looks cute |!!! 4
BlrwestSiR Posted May 8, 2023 Posted May 8, 2023 (edited) More previously started kits, this one the Miniart Su-122-54. Then this happened: They're conspiring to not let me get stuff done. Edited May 8, 2023 by BlrwestSiR Fix typo 1 9
DocRob Posted May 8, 2023 Posted May 8, 2023 8 hours ago, BlrwestSiR said: More previously started kits, this one the Miniart Su-122-54. The SU facing the Tiger's. More cats than models on your bench lately, Carl and that's hard to believe . Cheers Rob 1 4
Bomber_County Posted May 8, 2023 Posted May 8, 2023 By the looks of it someone isn’t happy, it will end in tears…… 1 3
PanzerWomble Posted May 8, 2023 Posted May 8, 2023 54 minutes ago, Bomber_County said: By the looks of it someone isn’t happy, it will end in tears…… Yup - Carl ....he now has to fight two cats for the warm seat.🤣 3 1
BlrwestSiR Posted May 8, 2023 Posted May 8, 2023 2 hours ago, DocRob said: The SU facing the Tiger's. More cats than models on your bench lately, Carl and that's hard to believe . Cheers Rob Thankfully our dog doesn't come into the basement or he'd probably try to join them. And he's 115 lbs. 4
npb748r Posted May 8, 2023 Posted May 8, 2023 I have 2 on the go, Trumpy's 1/32 F-8 (as an F-8FN) and Eduards Bf108. The 108 is from the stash, I am focused on building and making a dent in this as much as I can this year. The F-8FN is from my shelf of doom. Nothing wrong with the kit but my nemesis in model building is not the building, I'm competent at that, it's the painting and finishing, where I am less so and I really struggle at times. This got stuck on the SoD due to the inability of the paint to flow correctly, sit correctly or cover anything properly. I applied so many coats and each one had issues I just gave up, I think it was too cold in my man cave for the paint. Anyway, it's got to this stage over the last couple of days, I just want it finished so it wont be a stunning work of art but it will be finished. 9
Martinnfb Posted May 10, 2023 Author Posted May 10, 2023 Jet lag is fading away, time for some fumes 7 1
BlrwestSiR Posted May 10, 2023 Posted May 10, 2023 Great looking Spitfire Martin. Are those the kit belts? 2
Martinnfb Posted May 10, 2023 Author Posted May 10, 2023 Yes indeed, everything is out of the box with the exception of the 3D printed exhaust That comes from Kopecky Models. 2 2
belugawhaleman Posted May 10, 2023 Posted May 10, 2023 Working on this little Skoda Turtle........Hobby BossBoss 1/35. 4
Bomber_County Posted May 10, 2023 Posted May 10, 2023 11 hours ago, Martinnfb said: Jet lag is fading away, time for some fumes Looking amazing……. 1
