How to run ignition wires?
TJTX
I use lead wire made by Plusmodel. It has a 0,3 mm diameter, is very easy to bend and strong enough to stay in place. I use a 0,4 mm drill for the holes and CA to fix everything. To simulate connectors and spark plugs, I use small amounts of white glue. The easy bending lead allows to pre paint the wires stretched out, before installing them.
2 hours ago, Ryan said:
Stick with me here, but next time I'm going to try EZ line.
I know its'not round in section, but it sure drapes nicely.
With some paint it might look no worse than an eduard PE set.
I tried it on both my WWI snipe and fokker, the problem is it’s a little too floppy, hard to get it to sit right, lead is very soft, but stays put. But it really depends on your application.
Good to know 1to1 thanks.
3 hours ago, DocRob said:
Some time ago a member here pointed to that sie https://anyz.io/. They have braided lines and also resin spark plugs. I never tried them but on my next shopping tour I will buy some of their stuff and try it.
Hey Doc
 I believe the anyz stuff is for 1/24 scale, the braided line is pretty big for 1/32 stuff.
Ron G
Hi Ron,
0,5 mm *32 = 16 mm, sounds not to bad. I will try that stuff and report. To me it is right if it looks right.
This looks like 16mm to me minimum :D
Hey Doc
 I just started wiring my 1/24 mosquito engines with the ANYZ wires and sparkplugs. BOY are these things small and very fiddly. I did noticed that they do have a .4mm wire that would be perfect for 1/32 engines, not sure what colors are available, you would have to check his site for that.
Ron G
I also looked at their stuff today. Looks very good, and you can get  the wire in color of your choice.
  • 1 year later...
I used 0.3mm solder wire for the Hercules wires on my 1/48 Beaufighter. Learned a lot with 2 for 28 cylinders....will use lead wire next time as others have mentioned, it's soft and malleable. The wire I used was a bit springy. Used PVA glue for the spacers on the pairs. The exhaust pipes (the Vector engines only came with intakes) were 0.8mm lead solder wire.
407363836_Enginesbeforeafter.thumb.JPEG.bae9e70c47f1350d36d7457b57e4efc6.JPEG437589626_Enginewithpaintedairframe.thumb.jpeg.6c9995128e3f7f382d6cdf899f76de7c.jpeg
