Came out good after primer, I rescribed all the lines, re-riveted some areas, and got everything masked, I sprayed the first layer down. This will be what shows through the chipping, so I wanted a very dull looking silver.
First time using Alclad’s Klear Gloss. It was unusual it smelled like mineral spirit based, but mixed great with lacquer thinner, also cleaned up easy.
13 minutes ago, Bomber_County said:
Looks great, your re riveting is flawless, congrats
Not all my riveting, i just fixed the riveting I sanded off the seam lines and wing joints.
I realize the rounded placement is not correct, but it’s the only way to get them and the words to fit without cutting either, and it’s what the guy I’m building this for wants.
I had a near disaster at the end, and I have finally learned my lesson! Never use a water based wash if you used chipping fluid. Even under multiple coats of clear lacquer, the water can still activate the fluid. However, I was able to put an additional coat of lacquer (3 coats) and all is hidden. This happened to me 3 times now. You would think I would learn....
Testors spray can Dullcoat to the rescue. 40 years later and the stuff is still awesome, but, damn that stuff gives me a headache!
  • 4 weeks later...
On 1/29/2020 at 12:24 PM, Ryan said:
I still have my teenage poster of this in my garage.
It's funny to take in the art work here, from the 78' pinto rust barnacle to the shell casing that somehow left the barrel of the gun intact. :)
Of course none of that I noticed as a young lad, I didn't even like Iron Maiden...just bought it for the Spitfire imagery.
Are you also going to do the scraping of the iron maiden letters in the imagery in the bottom left of the canopy frame right side of the aircraft  also the bullet hole through the goggles and a skull on Eddie left side Temple
  • 4 weeks later...
