Thanks Gaz. I started to glue the bottom on one side tonight. It's the easiest starting point I could go. Have no instructions with this resin. It's a work in progress thing.....harv
I did get the bottom attached to the one side. The floor is not glued in yet, still fitting it. I'll have a bit of sanding and cleanup on the outside bottom....harv
Now that's definitely jumping into the deep end. Using an AM set and being the guy who gets to write the instructions as he goes. :unworthy:
Good plan on gluing the fuselage floor to one side. That should help with placing stuff.
Before I go any further,  there is something I need to cover about the resin parts,I.E.  the ceiling. When using this conversation,  it is necessary to move the ceiling up 7 mm. Fly got it wrong. All the parts for transmission are printed with the correct placement in mind.....harv
  • Confused 3
No pics, just dry fitting the sid windows. Haven't touched it for a couple of days. I have been dealing with severe pain in my left leg for a month. Turns out I had 2 blockages and needed a rotorooter job done on the veins. I'm much better now but sore as hell. So I'll be back to the bench in a couple of days.....harv
  • Sad 3
13 hours ago, harv said:
No pics, just dry fitting the sid windows. Haven't touched it for a couple of days. I have been dealing with severe pain in my left leg for a month. Turns out I had 2 blockages and needed a rotorooter job done on the views. I'm much better now but sore as hell. So I'll be back to the bench in a couple of days.....harv
get well soon Harv!
Fran
